Thread Tools Search this Thread Rating: Thread Rating: 87 votes, 5.00 average. Display Modes
Old 04-09-2012, 07:46 PM   #61
ExitBuddy
My Ride: 2008 335i Vert
Who is the OE for the gasket set? Prices online are running between $17 and $35, with Reinz, Meister and Elring brands.
ExitBuddy is offline   Reply With Quote
Old 04-11-2012, 12:51 AM   #62
Deltasquadron2
My Ride: 325xi
What year was your 325xi?
Deltasquadron2 is offline   Reply With Quote
Old 04-15-2012, 01:06 PM   #63
haurelio
My Ride: 2001 bmw 325i
hi, i just finished and this was a great guide.
I bought the gasket and the groomets, while inspecting them closely i notice that the ones that i bough (victor reinz) where slightly different from the ones that were on the car. is there a reason why?
the one on the right are the new ones and the left one was the one that came with the car.
and this is a closer pic
ID:	446638   Click image for larger version
Old 04-25-2012, 11:28 AM   #64
haurelio
i'm still curious
Old 04-25-2012, 11:36 AM   #65
trj
My Ride: 325Ci
Originally Posted by haurelio View Post
i'm still curious
Same with mine as well. The victor reinz I bought were a little shorter compared to OEM.
But it doesn't leak any more, so I am happy. The old ones were as hard as metal
Old 05-09-2012, 06:11 PM   #66
jizzzoe
My Ride: is no longer E46 :(
Send a message via Yahoo to jizzzoe
Sub'd, thanks for the DIY!
My Steel Gray '03 330Ci... I miss you, baby!
MODS: Purely aesthetic… Shadowlined, Smoked and LED'd out!
jizzzoe is offline   Reply With Quote
Old 05-14-2012, 01:35 PM   #67
deukhong
My Ride: 2001 330CI
hi,
i'm new to the forum so... sorry in advance if this has already been covered.. but..
i see that you used these parts that i have in my shopping car as well...
OEM Valve Cover Gasket: 11129070990
Valve Cover Grommets (15): 11-12-1-437-395
but i was reading on bimmerfest wiki and this other guy used part number 11120030496
so... which one do i use?
i drive a 2001 330CI.
thanks in advance!
deukhong is offline   Reply With Quote
Old 05-15-2012, 08:59 PM   #68
ajhubbar
My Ride: 2000 BMW 323i
Just ordered all the parts to do the vcg and the vanos seals. Can't wait to get started, long overdue for this.
ajhubbar is offline   Reply With Quote
Old 06-07-2012, 05:31 PM   #69
teamE46
My Ride: 01 330ci
So if your missing a bolt, the bolt to hold the valve cover, and its not in he engine bay or on the ground but when you start the car there's a clicking noise that makes you think the bolt is inside? Where would you look? I've taken the valve cover off again but all I found was the washer. Where should I look?
teamE46 is offline   Reply With Quote
Old 06-07-2012, 05:42 PM   #70
Tex323GripIsKey
My Ride: 2000 323i Green
Originally Posted by Sweetness View Post
I used to drive fast and cowboy around, but then I realized that I can't even afford bumping into someone, so now it's slow and classy, with occasional spurts of speed. Fanatics might pick on each other from time to time, but we are all one great big family that looks out for each other in the end.
I pull up to meets, lean to one side, shakin my finger at all da playahaterz. Then I get back into my car and flash mah beamz.
323i brakes & rotors
Tex323GripIsKey is offline   Reply With Quote
Old 06-18-2012, 10:56 PM   #71
D P
My Ride: 01 330Ci
Just completed this DIY...thanks for taking the time making it.
D P is offline   Reply With Quote
Old 06-21-2012, 12:32 PM   #72
sweetbro858
Banned User
My Ride: BMW
Jesus man, just called BMW of San Diego to see if I could pick a gasket up real quick instead of online..... $57.58
wtf... dude must have been confused. these things go from 20-25...
sweetbro858 is offline   Reply With Quote
Old 06-21-2012, 01:53 PM   #73
Sansho
My Ride: 2001 325i
Do you have an M3 perhaps? Just looking at another discounting BMW dealer online, the M3 VCG (only the gasket) lists for $65 sells for $51 and the 325/330i one lists for $46 sells for $36. Of course you can go OEM for $24 from Autohausaz which includes the spark plug and VC gaskets. If you want the valve cover stud seals, that's another $5 at Autohaus.
Sansho is offline   Reply With Quote
Old 06-21-2012, 04:12 PM   #74
sweetbro858
Banned User
My Ride: BMW
Nah, non M. I just picked up the gasket and grommets from bma autoparts. Forgot to check autohausaz. Bma is still cheap though. Only $5 for the grommets? dammm.
Old 06-28-2012, 01:21 PM   #75
lulubboy
My Ride: 2002 BMW 325Ci
WOW just did this DYI. The old gasket was DONE and not rubber anymore. Hardest part was trying the get the cover back on... the gasket kept falling out.
Unfortunately during the removal, I broke one of the attachments to the cover... I think its the vanos attachemend? The plastic just cracked at the base.. Attached is a pic. Can anybody tell me what part this is and where I can buy another quick. Thanks.
lulubboy is offline   Reply With Quote
Old 06-28-2012, 01:31 PM   #76
lulubboy
Another question. During the DYI. I noticed the long plastic piece near the cabin filter area needed to be changed... The part where it touches the windshield, edges were all cracked/ baked. attached is a picture.
Old 06-28-2012, 08:19 PM   #77
lulubboy
Is the replaced gasket suppose to have some gap space as seen in attached pic? Everything bolted properly.
Name:	2012-06-28 20.00.54.jpg
Old 07-28-2012, 12:08 PM   #78
stuntin325
My Ride: 2001 325
I was replacing mine and then a hose broke can anyone tell me what kind of hose this is?
Sent from my HTCEVOV4G using Bimmer App
stuntin325 is offline   Reply With Quote
Old 07-28-2012, 12:09 PM   #79
stuntin325
My Ride: 2001 325
Old 07-28-2012, 02:28 PM   #80
nughaud
My Ride: '01 330CI / '11 335i
Looks just like it's the Vacuum Hose (part 4):
http://bmwfans.info/parts/catalog/E4...acuum_control/
You should be able to pick some of that up at any auto parts store. Just bring in part of the old vacuum hose and they should be able to match it for just a few cents or a buck.
http://www.bimmerspecialist.com/part...545%20323/8269
nughaud is offline   Reply With Quote
