BMW Logging Software - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 06-17-2012, 08:28 PM   #21
smooth1
My Ride: BMW FTW
Thank you.
smooth1 is offline   Reply With Quote
Old 06-17-2012, 10:39 PM   #22
BimmerBrakes
The Brake Newbie!
My Ride: 2005 ZHP BMW
Send a message via AIM to BimmerBrakes
Originally Posted by smooth1 View Post
The software has been made available with MS43 support to start. MS41, MS41.1, MS42, and MSS54 support is on the way. The software is FREE to check and clear codes, and clear adaptations. It's also free to playback datalogs taken by others (So your tuners can see real information from you), there's some sample logs to play with on the website. Enjoy!
www.bimmersoftware.com/BMWLogger
How about MS45?
BimmerBrakes is offline   Reply With Quote
Old 06-18-2012, 09:12 AM   #23
smooth1
My Ride: BMW FTW
MS45, MSS60, MSV70, MSV70-1, MSV80 etc, all use a completely different protocol and I'm certainly looking into adding support.
Old 06-18-2012, 09:27 AM   #24
Ballistic325
My Ride: slow and steady
Congrats on the software! Just wanted to register interest in a version for a version for the MS54 version.
Good luck!
Sent from my V9 using Bimmer App
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
Old 06-18-2012, 09:45 AM   #25
BimmerBrakes
The Brake Newbie!
Willing to help and test if needed
-Anthony@BimmerBrakes
Old 06-18-2012, 09:57 AM   #26
smooth1
My Ride: BMW FTW
Good luck!
Already have MSS54 support in testing.
Much appreciated.
Old 06-18-2012, 10:31 AM   #27
TerraPhantm
My Ride: M3 & ZHP
Would you be interested in an MSD80 tester? I've got a 535xi with that ECU. Also have an mss54 if you need another tester
Old 06-18-2012, 11:14 AM   #28
smooth1
My Ride: BMW FTW
MSS54 is covered, but I definitely appreciate the offer.
I should have added MSD80 to the list. I'm looking to add that as well! If I do need some testing I'll definitely let you know. From your other posts I know you have all the tools installed.
Old 06-18-2012, 11:58 AM   #29
e60fan
My Ride: 525i
MS45 support is needed. I have MS45.0 and can help you with something. Will be very good to have an Android version for comfortable test runs.
Also why lambda values have %? Lambda must be from 0 to 1.
e60fan is offline   Reply With Quote
Old 06-18-2012, 12:00 PM   #30
smooth1
My Ride: BMW FTW
Yes, MS45 is planned, but has a different protocol.
That's Lambda Integrator 1 and 2, not Lambda readings from the sensors.
Old 06-18-2012, 04:26 PM   #31
smooth1
My Ride: BMW FTW
Software update today includes many additions for MS43 and initial MSS54 support.
Add Idle Speed Duty Cycle
Add Idle Actuator
Add Secondary Air Pump Relay
Add Secondary Air Valve
Add ASC Initialization
Add DISA Relay
Add EKP Relay
Add Fuel Tank Vent Valve
Add Lambda Control 1
Add Lambda Control 2
Add Catalytic Converter Heating
Add DMTL Ventilation
Add DMTL Leakage Diagnostic
Add FGR Ready
Add FGR Rest
Add FGR Off
Add FGR Delay
Add FGR Tip Up
Add FGR Tip Down
Add FGR Accelerate
Add FGR Resume
Old 06-18-2012, 10:51 PM   #32
sunnyjay
My Ride: 01 330i
Keep up the good work and I look forward to testing the first release of your logger.
sunnyjay is offline   Reply With Quote
Old 06-19-2012, 12:23 AM   #33
smooth1
My Ride: BMW FTW
Thanks. It's available at www.bimmersoftware.com. There's a few guys already running around making good use of it.
Old 06-19-2012, 01:27 AM   #34
Brian N
My Ride: 2001 330i Jet Black
So all I need to purchase along with the software is the blue cable you link on your website?
I have a macbook air with os x lion installed is there any special install instructions I need for the program? Or should it just install normally? Last question my friend has a window's 7 laptop does your software run on that as well? He was worried it might be XP only.
Thanks again can't wait to start using this!
Brian N is offline   Reply With Quote
Old 06-19-2012, 03:38 AM   #35
daniel_f.
My Ride: 330iC
Very usefull software! Definately worth it
Is it possible, for auto drivers, to add the signal from the EGS to reduce torque?
so it could be possible to see the interaction between engine and transmission and calculate shift response im very interested in that
Old 06-19-2012, 08:58 AM   #36
smooth1
My Ride: BMW FTW
Yes, all you need is a cable and a license. The cable I linked to I have several of and they work well.
There's a video on the product page that shows the basics including how to install. Drivers will be automatically installed for you. The product page says Mac OS X 10.4 And Up, Windows XP And Up, which includes Windows 7. Would it be easier to tell if I listed them all? Also the licenses work on Mac OS X or Windows, so you can switch between them at any time.
Right now we're gathering DME information only, but that's not to say we won't be able to reach out to other modules in the future. This will, however, slow the logging rate down.
Old 06-19-2012, 09:17 AM   #37
daniel_f.
My Ride: 330iC
It is actually in the DME, but it comes from the EGS. It advises the engine to reduce torque to help shifting
Old 06-19-2012, 09:28 AM   #38
smooth1
My Ride: BMW FTW
Send me a recording while doing what would activate this bit. If it's there I'll find it.
Old 06-19-2012, 03:45 PM   #39
e60fan
My Ride: 525i
so no lambda values?
Old 06-19-2012, 04:18 PM   #40
smooth1
My Ride: BMW FTW
*Currently* for MS43 there's only lambda integrator 1 and 2, which can easily help you identify if you're running rich or lean throughout your logs. As you can see a few posts up I'm constantly adding additional items for logging.
