Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 05-04-2012, 09:10 PM   #61
Forcefed M3
My Ride: HPF Stage 2.75
Originally Posted by InDiGlOM3 View Post
watch out for turbo creep.
That's what I was thinking, damn boost creep. Looks great OP!
Forcefed M3 is offline   Reply With Quote
Old 05-05-2012, 03:32 PM   #62
Cipri
My Ride: E46 M3 2002
Originally Posted by Blocked Out View Post
Your ignition coils are going out.
Is it possible to have this error because of the AEM?
Other HPF/AEM guys do you have this type of error?
Cipri is offline   Reply With Quote
Old 05-22-2012, 04:31 PM   #63
Cipri
Dyno results
Name:	squid m3 e46.jpg
Old 05-22-2012, 04:53 PM   #64
Zak@ActiveAutowerke
Past Site Sponsor
My Ride: '94 325is
Nuts
Zak@ActiveAutowerke is offline   Reply With Quote
Old 05-22-2012, 05:22 PM   #65
02PRUV
My Ride: E46 M3 Turbo
With that curve you may as well of installed a supercharger. That would feel lazy for a turboed car.
Rides:
BMW E46 M3 Turbo 570rwhp @18psi (old setup)
BMW E46 M3 LSX 427ci 800hp N/A
Ultima GTR LSX 440ci 800hp N/A
VY SS Ute Turbo 1004.6rwhp @ 28psi E85
Ford Escort Mk2 2JZGTE 600rwhp @14 psi
04 Yamaha R1 154.3rwhp
ISUZU FZR550 tilt tray (GT35 Turbo)
02PRUV is offline   Reply With Quote
Old 05-22-2012, 06:01 PM   #66
Cipri
Would you be able to get the same torque?
My target is to have built engine and over 750hp.
Old 05-22-2012, 06:28 PM   #67
02PRUV
Be close. I don't get why it's so lazy though. It's not a big turbo with a small A/R rear housing. I remember when I had a GT35 on mine which is a 63mm wheel with a 0.82A/R rear I had full boost before 3000rpm. So why is yours so lazy?
Rides:
Old 05-22-2012, 07:47 PM   #68
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Looks like a SC car.
I wonder what the boost control settings are?
Old 06-05-2012, 04:39 AM   #69
Cipri
I use this car for drag so this is why I don't need full boost to soon.
In the wastegate I use the smallest spring 0.2 BAR.
Old 06-19-2012, 03:08 PM   #70
Cipri
Big problem, I can't connect any more to the AEM EMS, I receive the following error "Parity error". I was receiving this error right after install but it was only time to time, now it seems permanent - I tryied from 3 different laptops using 3 different cables and the same error is shown each time.
Car is not starting any more with the AEM plugged in, I changed back to old injectors and went NA using only the car ECU.
I have also sent an e-mail to Kirk from HPF, maybe they can help in some way...
What do you guys recommend?
Old 06-24-2012, 05:45 PM   #71
Cipri
All problems solved with the car.
Today I was at the track and got:
Best ET - 11.88, with 60ft 1.8x and exit speed 199kmh
Best 60ft - 1.7x
With the right suspension setup and weight reduction it should get me a 11.5x
Old 06-25-2012, 01:37 PM   #72
VicRod88
My Ride: e46m
Best 60ft - 1.7x
Active Autowerkes HKS Stage 2 Supercharger
VicRod88 is offline   Reply With Quote
Old 06-25-2012, 01:48 PM   #73
02black330ci
My Ride: spaceship
Best 60ft - 1.7x
Nice man, but what was the resolution to your problem?
02black330ci is offline   Reply With Quote
Old 06-27-2012, 04:13 AM   #74
Cipri
AEM was repaired by a local tuner which makes they'r own stand alone EMS and have alot of experience with electronics.
Old 06-29-2012, 02:36 PM   #75
DOC_Race
My Ride: 03 M3
Cool build. Way to snake the downpipe
DOC_Race is offline   Reply With Quote
Old 07-07-2012, 02:21 AM   #76
Cipri
1st place in the national drag championship my group
I'm thinking for some power upgrade:
- Wossner 8.8:1 pistons
- Pauter rods
- Precision 6766 or GT42
What do you guys say?
ID:	459688   Click image for larger version
Old 07-07-2012, 05:36 AM   #77
basar13
My Ride: Z4M, R8, 525xd, STI
Congrats
basar13 is offline   Reply With Quote
Old 07-07-2012, 05:41 PM   #78
02PRUV
- Pauter rods
Congrats.
Do it. Go a GTX42 instead of a GT42.
Rides:
Old 07-08-2012, 04:23 AM   #79
Cipri
Thanks guys!
Is it possible to install dual inlet turbines on single inlet manifolds? I can find GTX42 only with dual inlet housing...
Here is the movie form the event:
One crazy-funny vid about Romanian Drag Racing:
Old 08-12-2012, 12:32 PM   #80
zbarca2009
My Ride: E46 M3 VF570
I belive you are talking about the twin scrool setup, when you are talking about exhaust parts there is no inlet as inlet is specific to air induction.It's not a good idea to put twin-scrool turbocharger on a normal T4 flange as you will create a lot of backpressure in the manifold because of the middle split of the turbine housing. Bafta!
I /// M back...
VF570 inside
zbarca2009 is offline   Reply With Quote
