Thread Tools Search this Thread Rating: Thread Rating: 11 votes, 4.64 average. Display Modes
Old 04-03-2012, 08:39 PM   #1
redbull 325is
My Ride: 325xit/6
Send a message via AIM to redbull 325is
DIY e46 M3 Front Brakes on a Non-M
These brakes fell in my lap right as I was about to pull the trigger a decent pad/rotor 330i setup for my 325xi, so I decided to make them work
Research online shows that you need to mill the m3 caliper bracket 6 or 7mm to fit non-M e46 cars. I went with 1/4" (mainly because my machine shop isn't fond of the metric system)
After the first test fit I had to go back to get him to clearance out some of the remaining adjacent areas to clear the mounting tabs on the spindles.
Once that is done, proceed with normal brake install and pressure bleed with your favorite fluid
note: m3 brakes use different set screws than non-ms hence the presence of lugnuts in this shot. Need to order 2 of those puppies up.
Lookin' Good
First Impressions:
Brakes are still a bit squirmy as I haven't really had a good chance to bed them in thoroughly. Once I did get heat in them, however, they were amazing. Haven't had any spirited driving with them yet to see how far off brake bias is front to rear. -May DIY the rears here shortly.
Install should be the same for 323i 325i 325xi 328i 330i 330xi.
Royal Elite Club of 6 Speed Tourings - founder
redbull 325is is offline   Reply With Quote
Old 04-21-2012, 07:17 PM   #2
redbull 325is
My Ride: 325xit/6
Looks like the rear m3 brake mod will require swapping out for m3 trailing arms. interestingly enough 325xi should have the right parking brake to directly swap over to 330i rear brakes. I'll update this thread when I get more work done.
Old 04-22-2012, 02:38 AM   #3
steifan
My Ride: 325i '06, 323 Ci '00
323 is supposed to have smaller diameter discs front & rear so I do not
believe
that this method works as the caliper bracket probably has to be replaced entirely.
Stock disc sizes (source: http://www.schmiedmann.se/ )
323i, Ci:
Front: 286x22mm Rear: 276x19mm
323 Ci cabriolet, 328i/Ci, 325i/xi/Ci:
Front: 300x22mm Rear: 294x19mm
330i/Ci
Front: 325x25mm Rear:320x22mm
M3:
Front: 325x28mm Rear: 328x20mm
BMW 323Ci '00, Eibach/Bilstein Pro-kit/B12
BMW 325i '06, M-Sport
steifan is offline   Reply With Quote
Old 04-22-2012, 03:58 AM   #4
Dan330Ci~
My Ride: 330Ci Clubsport
Nice work, I take it you are using 330 discs? Or are they your originals?
You could use 330 discs but be sure to compare the minimum thicknesses of 330 vs M3.
I've been wondering about this for a while: do the M3 calipers have different connections to the brake hose? I have Goodridge SS hoses and would hopefully re-use them if I did this type of swap. The other problem I could forsee was that if the connection to the caliper is different, you may try M3 hoses but then the connection to the hard lines may be different
Steifan, I checked your sizes against ETK, I only found one minor error. I also added some other models for reference.
323i/Ci
F: 286x22 R: 276x19 (solid)
323 Ci cabriolet, 328i/Ci, 325i/xi/Ci (solid)
F: 300x22 R: 294x19
330i/Ci (solid/perforated)
F: 325x25 R: 320x22
M3 (perforated)
F: 325x28 R: 328x20
M3 competition package (perforated)
F: 345x28 R: 328x20
M3 CSL (perforated)
F: 345x28 R: 328x20
'04 330Ci Clubsport | Estoril Blue | 6MT | Black Leather/Silver Cube
Turner Motorsport | Ground Control | Stett Performance | Moroso | Powerflex | Meyle HD | Goodridge
Dan330Ci~ is offline   Reply With Quote
Old 04-22-2012, 11:16 AM   #5
redbull 325is
My Ride: 325xit/6
believe
This will work on the front as the spindles are the same on all these cars, only the caliper & carrier change. Since you are swapping these out for m3 units anyways it shouldn't change a thing (for the front anyway).
I'm using full e46 m3 system up front. I wouldn't try to mix and match caliper/carriers to different rotors as it could lead to offset issues and/or brake pads falling out of their housings when at minimum thickness.
I was suggesting it would be cheaper for 325xi people to use 330i rear setup as a cheap bbk since the xi already has the larger drum/parking break setup, which isn't the case for 323/325/328s than going m3 brakes which requires swapping the rear trailing arms (still working on this)
i used my factory brake lines up front with no issues.
Old 04-24-2012, 03:52 PM   #6
SamDoe1
My Ride: 4cyl of fury
Really? So the 325xi has the same rear end/hub size as the 330xi? Only difference being the overal diameter and thickness of the brake disc?
Old 05-08-2012, 07:03 PM   #7
redbull 325is
My Ride: 325xit/6
330s and 325xis use the same parking brake shoes and 325xi rear rotors are different from rwd rotors, leading me to believe that the 330i rotor and caliper will just bolt on.
Old 05-08-2012, 07:08 PM   #8
mtnbound
Town Clown
My Ride: 330Ci Vert, 325iT
Missed this the first go around - congrats, well done!
Sent from my HTC Flyer P512 using Bimmer App
Bay Area Top Dropper
Orient Blue 330 Ci Vert
mtnbound is offline   Reply With Quote
Old 05-24-2012, 11:37 PM   #9
metal massager
My Ride: frankenbi///Mmer
Thanks for posting the pics...just got my carriers machined and I put them on my 325 touring yesterday. Your pics made it very easy to show the machine shop and get exactly what I needed the first time.
metal massager is offline   Reply With Quote
Old 06-21-2012, 01:07 PM   #10
Snik
Snik's Avatar
My Ride: IR M3 Vert.
Redbull, any update on the rears? did you attempt anything, or find out more?
Do you ride a sportbike?
Old 06-25-2012, 01:09 AM   #11
lrinco01
My Ride: 01 Turbo M3, 10 'X5M
Send a message via Yahoo to lrinco01
Great info guys thanks
My wife just picked up a 323ci as her D/D and i was wondering if I could through my old OEM front/Rear brakes off my E46 M3 to give her better braking w/o having to spend a crazy amount of money upgrading them with a new set.
Leonel Aka " Rico"
BMWCCA # 403748
01 BMW E46 M3 / 6 SPD / Tiag / Imola
HPF Turbo....
Custom Built S54
Flex fuel
8XX rwhp
FOR SALE:
http://www.m3post.com/forums/showthread.php?t=727953
Custom Silver CF 6Speed E46 M3 sport steering wheel
http://forum.e46fanatics.com/showthread.php?t=1051908
lrinco01 is offline   Reply With Quote
Old 06-25-2012, 08:03 AM   #12
redbull 325is
My Ride: 325xit/6
not yet, been too busy at work, however i'm pretty sure that i'd have to swap trailing arms.
glad to help ya out
let us know if you get the rears on there!
Old 10-29-2012, 12:18 AM   #13
hondo78
My Ride: E 46 SPT Wagon
M3 Brakes on 325i
Redbull
I also purchased a set of M3 brakes and they are much bigger, and drilled rotors, I thought all were. These are around 15" in diameter, my calipers say M3 on them, did I buy something different>? I took a walk around Los Altos to take a looks see and all the M3s have drilled rotors on them, rears are same diameter too. What is different?
"If you want something you will make it happen, if not you will make an excuse"
hondo78 is offline   Reply With Quote
Old 10-29-2012, 12:19 AM   #14
hondo78
Thanks for the great pics, they are very helpful.
Old 11-03-2012, 10:46 AM   #15
chisel21
My Ride: 323i
Lookin' Good
First Impressions:
So if I understand you correctly, what you did on the front should work on my 323i, correct ?
How about the rears on the rwd ?
chisel21 is offline   Reply With Quote
Old 11-29-2012, 07:33 PM   #16
crazyxzer0
My Ride: 2004 330i
Send a message via AIM to crazyxzer0 Send a message via MSN to crazyxzer0
1/4th milling looks like plenty! I'm curious what you need to do to the ZCP carriers to do the same modification to get the 345mm rotors up front.
-Derek
Stoptech Front BBK|M3 LSD|GC Coilovers w/ Swift Springs|UUC TSE3 Exhaust|
My Build Thread
crazyxzer0 is offline   Reply With Quote
Old 12-23-2012, 03:31 PM   #17
m5t
My Ride: 325 Ci
Exactly the same what he has done to regular M3 carriers. CSL carriers are bigger in order to accommodate a bigger rotor, but CSL brakes have the same calipers as regular M3. So basically CSL brakes can be installed to regular M3 without any modifications, assuming you will use caliper carriers from CSL.
I have CSL brake set, so I tried out - the same 5-6mm should be taken off from caliper carriers in order to fit. I was thinking to get front hubs from M3 in order to avoid modification of the carriers, but that path is complicated, as you have to swap tie rods and front wishbones, maybe something else... also I'm pretty sure that will make 'front' wider... So I think the best way would be to mill calipers.
m5t is offline   Reply With Quote
Old 04-14-2013, 09:16 AM   #18
redbull 325is
My Ride: 325xit/6
Update on the rears:
You can bolt an m3 rear caliper to a non-m but it will sit too close to the hub and won't allow you to fit the bigger m3 rotor.
Old 04-16-2013, 10:51 PM   #19
DougL3NC
My Ride: 2000 323Ci
Your front calipers pictured above are on my car IIRC.
DougL3NC is offline   Reply With Quote
Old 05-27-2013, 06:43 AM   #20
Alun1976
My Ride: BMW Z4
I don't understand how your front rotors arent drilled? I was under the impression that all M3 front rotors are drilled?
Am I missing something?
Cheers
Alun1976 is offline   Reply With Quote
325i, bbk, diy, e46, m3 brakes
