Old 06-13-2012, 03:35 PM   #1
Andrew@Activeautowerke
Past Site Sponsor
My Ride: 135 Fbo+meth & E85
Active Autowerke 328/330 Stage 1 Supercharger -Limited Time Offer-
Active Autowerke Stage 1
Active Autowerke E46 328 Supercharger Kit Level 1
Active Autowerke's 328i supercharger kit provides a much needed boost in horsepower to your E46 328. Specifically designed to run with 91-93 octane pump fuel and your factory ECU, this system uses our dyno-tuned software adjustments to manage ignition, fuel, vanos, rev limits, etc - all programmed into the same onboard computer your 328i was born with. So the performance mutation from normal to 'extra-assertive' is smooth and dependable, and totally reversible to stock. Even our oil cooling upgrade is self contained and non-intrusive of the factory oil system. Nothing beats a complete bolt on supercharger system. Bottom line: you get to experience M3 performance in a 328i at an incredibly affordable price. This is a must for the true E46 enthusiast.
Key Features:
Rotrex C38-81 trim supercharger
8 psi boost level
CNC machined supercharger bracket with hardware
Self-contained oil system with front-mount oil cooler
6 higher flow fuel Injectors
Active Autowerke/Bosch bypass valve
High temperature silicone hoses with stainless clamps
All mandrel bent tubing for improved flow
Active Autowerke Air Filter (Some Models may use K&N)
Active Autowerke Dyno-Tuned Software
All mounting hardware, plumbing, hoses and clamps
Illustrated instruction manual & installation guide
2 Year Warranty with free tech support
Performance Specs
Power : 320 BHP @ 7000 rpm
Torque : 260 ft/lbs @ 5400 rpm
Boost Level : 8.0 psi
Active Autowerke E46 330 Supercharger Kit Level 1
Active Autowerke's 330i supercharger kit delivers instantaneous power and low end torque in amounts far beyond what the bimmer factory gods intended. Specifically designed to run with 91-93 octane pump fuel and your stock engine management system, this system uses our dyno-tuned software adjustments to manage ignition, fuel, vanos, rev limits, speed governors, etc - all programmed into the same onboard computer your 330i was born with. So the performance mutation from normal to 'extra-assertive' is smooth and dependable, and totally reversible to stock. Even our oil cooling upgrade is self contained and non-intrusive of the factory oil system. Nothing beats a complete bolt on supercharger system. Bottom line: you get to experience M3 performance in a 330i at an incredibly affordable price. No need to sacrificing drivability, comfort, integrity or amenities that you have grown to love. That's an evolution worth pursuing.
Performance Specs
Power : 365 BHP @ 7000 rpm
Torque : 270 ft/lbs @ 5400 rpm
Key Features:
8 psi boost level
6 higher flowing fuel Injectors
Msrp: $4695 +$125 shipping
Special Pricing:
$3,999 Shipped to the lower 48
Please Pm me or call 305-233-9300 to place your order today !
Andrew@Activeautowerke is offline   Reply With Quote
Old 06-13-2012, 04:04 PM   #2
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
Ohhhhh why subframe whyyy
| 435 HP 328Ci | RRT Racing | Designer Wraps | Active Autowerke | Vorsteiner | STATUS Racing |
Timeless Motor Group
Old 06-14-2012, 08:18 AM   #3
Past Site Sponsor
A blower would complement a fixed sub frame very well
Old 06-25-2012, 10:11 AM   #4
Past Site Sponsor
Sale Ends Friday The 29th !! Have you ordered yet?
328, 330, active autowerke, sale, supercharger
