Closed Thread
Old 06-25-2012, 04:19 PM   #1
HPF Chris
Past Site Sponsor
My Ride: 2002 M3, 2006 530i
Thumbs Up OIL TEMPS GETTING HOT - HPF Oil Cooler Group Buy!!
It's that time of year again where temperatures skyrocket!! If you own an E46 M3 than you've probably seen the oil temp gauge needle to the right of the centerline. Don't ruin your engine by overheating it. We've taken the E46 M3 factory oil cooler to a completely new level for all NA, supercharged and turbocharged M3's. This is a plug and play oil cooler that simply bolts right in and replaces the factory oil cooler. The factory oil cooler lines simply connect to our new oil cooler so no need for AN fittings or steel braided lines. This oil cooler also has brackets that are designed to work for NA, supercharged, and even provides mounting locations for the HPF FMIC to connect right up to it for our turbo guys. We also built ducting directly into the oil cooler to bring cool air up from below and to redirect heated air flowing across the radiator around the oil cooler and not through it. This oil cooler design also retains the factory fan shroud, A/C fan, A/C lines and radiator location and configuration. Installation is a snap and the average at home do it yourselfer can install this themselves.
HPF OIL COOLER FEATURES
400% Increase in Core Volume
Factory Core Dimensions: 23" x 1.5" x 2.75" - HPF Core Dimensions: 26" x 4" x 3.6"
Superior Bar and Plate Core Design
Powder Coated Radiator Ducting and Inlet Scoop
Polished Aluminum
Billet End Tanks
GROUP BUY SPECIAL PRICING (SAVE $200)
NA without ducting - $895 - Group Buy Price $695
Supercharged and Turbocharged w/ducting $995 - Group Buy Price $795
HPF OIL COOLERS IN STOCK TODAY
Call now to get on the group buy list AND SAVE $200 (503) 256-5600 or email sales@horsepowerfreaks.com
HPF Chris is offline
Old 06-25-2012, 05:43 PM   #2
PatmanSC
My Ride: 06 AW/IR M3
how long will the group buy last?
06 Alpine White/Imola Red M3 coupe, {Stage 2.5 P6766 open wastegate}
| M2-Motoring | HRE Wheels | Horsepower Freaks | Tecnocraft | Oink Fabrications | Toyo Tires | Mother's |
00 Phoenix Yellow/Red Recaro Integra Type R #00-0035 {JDM Conversion, Built B18C5, Ferea internals, Toda build soon}
PatmanSC is offline
Old 06-25-2012, 06:11 PM   #3
HPF Chris
Past Site Sponsor
The group buy will last until July 15th. I want a minimum of 10 orders by then to close it out.
Chris.
Old 06-25-2012, 08:44 PM   #4
gixxer
My Ride: 03 VFE DINAN5/04 M3
Is there any picture with the installation (even a mock up would do)? I would be interested in the version that supports supercharged one (AA) with ducting (AA).
need2buy: LTW flywheel + clutch ;
wish: HPF ;
Mod Journal
gixxer is offline
Old 06-25-2012, 11:58 PM   #5
Dreikraft
My Ride: slow m3
how easy to install?
... and are you going to be stocking the fluidyne radiator when it releases?
Dreikraft is offline
Old 06-26-2012, 12:08 AM   #6
Forcefed M3
My Ride: HPF Stage 2.75
It took me 45 min to do mine. I was in Phoenix during the summer and drove my car hard with this oil cooler. Temps never went past the half way mark!
Forcefed M3 is offline
Old 06-26-2012, 12:14 AM   #7
Dreikraft
My Ride: slow m3
ok.
i want the radiator more than the cooler but itd be nice to never see it hit noon.
whats it like in cold weather tho? (40f and below) can you even get it to 11o clock?
Old 06-26-2012, 12:18 AM   #8
Forcefed M3
Originally Posted by Dreikraft View Post
ok.
In cold weather it sits about 11:00.
Old 06-26-2012, 12:52 AM   #9
HPF Chris
Past Site Sponsor
Old 06-26-2012, 12:53 AM   #10
HPF Chris
Past Site Sponsor
Installation is quite simple and we will definitely be stocking the fluidyne radiator.
Old 06-26-2012, 12:54 AM   #11
HPF Chris
Past Site Sponsor
ok.
Mine likes to run a little to the left of centerline all the time hot or cold weather. Other people can chime in on theirs.
Chris.
Old 06-26-2012, 03:50 AM   #12
HighBoostin330
My Ride: 2002 Stock 330Ci
Any specials on the fan clutch like you had last year?
HighBoostin330 is offline
Old 06-26-2012, 09:11 AM   #13
lrinco01
My Ride: 01 Turbo M3, 10 'X5M
Send a message via Yahoo to lrinco01
Sweeeet! I ordered mine and can't wait TO SEE it installed and in Action! thanks KIRK!
Leonel Aka " Rico"
BMWCCA # 403748
01 BMW E46 M3 / 6 SPD / Tiag / Imola
HPF Turbo....
Custom Built S54
Flex fuel
8XX rwhp
FOR SALE:
http://www.m3post.com/forums/showthread.php?t=727953
Custom Silver CF 6Speed E46 M3 sport steering wheel
http://forum.e46fanatics.com/showthread.php?t=1051908
lrinco01 is offline
Old 06-26-2012, 10:29 AM   #14
Ky///m3
My Ride: 1988 E30 M3
Chris.
same here
2006 E46 M3 HPF stg II SOLD
1988 E30 M3 Touring Class
1995 E36 M3 I-Prepared Class
Ky///m3 is offline
Old 06-26-2012, 11:21 AM   #15
Commanderwiggin
My Ride: 900rwhp Turbo M3
Most often mine runs left of center under normal semi-spirited driving. A 15 lap session at streets of willow with ambient temps around 15'C was just right of center. 5 Laps in 40'C heat and was heading farther right...I don't recall how far as I was watching my coolant temps get near the red and backed off...it was retardedly hot that day.
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Commanderwiggin is offline
Old 06-26-2012, 12:36 PM   #16
HPF Chris
Past Site Sponsor
Coolant temps need to be addressed by other means. We run water wetter, the performance clutch fan and wire the A/C fan to be on all the time.
No more worrying about oil temps.
I'll do $115 on the fan clutch for this week only.
Chris.
Old 06-26-2012, 01:38 PM   #17
Commanderwiggin
I also run a perfect 50/50 mix with one bottle of water wetter, hpf fan clutch but no a/c fan on all the time...but at Vegas in the 40'C heat...I don't think that would fix it...any other time my temps have been perfect...even last year at Mfest my temps were better.
Old 06-26-2012, 01:51 PM   #18
Dreikraft
My Ride: slow m3
How do I wire the ac fan?
I'll take the f clutch for 115
Old 06-26-2012, 03:43 PM   #19
HighBoostin330
...I'll do $115 on the fan clutch for this week only.
Chris.
How do I jump on this deal?
Old 06-27-2012, 09:16 AM   #20
jayc
My Ride: 95 m3, 02 s4, 04 325
mE TOO!
04 Bmw X5 on 22"
04 Bmw M3 ESS S/C
08 BMW M3
jayc is offline
Closed Thread
