The Showroom
Old 06-29-2012, 02:14 PM   #1
bmw330ice
My Ride: 02 M3/14 Jeep UNL
Thumbs Up DIY* Rotora BBK Installation (Center Spotlight Media Content - Lots of Pics!)
Hello guys and gals,
As some of you know, I recently did a lot of DIY work on my car as well, which included upgrading the struts to Koni (Yellows), the springs to Eibach lowering springs, and the OEM brakes to the Rotora BBK. And I would like to apologize to Rotora for the delay; took me some time to get the lift installed in my parent's house, plus I had a death in the family. But without further ado, here is my DIY write up for the Rotora BBK on my 2006 330Ci.
I wanted to go ahead a post a DIY specifically on the Rotora BBK since it does take some work to make everything fit properly and figured everyone could benefit if someone decides to go the Rotora route.
Step by Step process (2006 BMW 330Ci - 355mm BBK):
Rear Brakes
Step 1
**Cut the dust shields, so that the new rotors fit.
DSC_0976 by Center SpotLight Media (SoloEuro), on Flickr
DSC_0978 by Center SpotLight Media (SoloEuro), on Flickr
**Brake dust shield cut and removed
DSC_0975 by Center SpotLight Media (SoloEuro), on Flickr
Step 2
**Place the rotors.
DSC_0979 by Center SpotLight Media (SoloEuro), on Flickr
Step 3
**Tighten the rotors with OEM screw. Socket wrench.
DSC_0980 by Center SpotLight Media (SoloEuro), on Flickr
** New Calipers
DSC_0982 by Center SpotLight Media (SoloEuro), on Flickr
Step 4
**Place the new stainless steal brake lines back where the old ones attached.
DSC_0983 by Center SpotLight Media (SoloEuro), on Flickr
Step 5
**Place and tighten caliper bolts. Use OEM bolts.
DSC_0985 by Center SpotLight Media (SoloEuro), on Flickr
Step 6
**Place loctite onto the end of the brake lines to secure it.
DSC_0984 by Center SpotLight Media (SoloEuro), on Flickr
Step 7
**Tighten the brake lines into the calipers. 13mm wrench.
DSC_0987 by Center SpotLight Media (SoloEuro), on Flickr
Step 8
**Place new brake lines up to the old hook-up.
DSC_0989 by Center SpotLight Media (SoloEuro), on Flickr
Step 9
**Tighten the brake lines into the old hook-up. 11mm wrench.
DSC_0990 by Center SpotLight Media (SoloEuro), on Flickr
Step 10
**Remove brake pad sensor and then cut.
DSC_0992 by Center SpotLight Media (SoloEuro), on Flickr
Step 11
**Strip the wires and then twist the end of the brake pad sensor wires. Then wrap the end with electrical tape. (This will make sure no error codes show.) Place brake bad sensor back in original spot, and make sure it does not hang. Secure it.
DSC_0994 by Center SpotLight Media (SoloEuro), on Flickr
Front Brakes
Step 1
**Cut the dust shields, so that the new rotors fit. Same as the back brakes, although I only cut the lower half.
Step 2
**Place the rotors.
Step 3
DSC_0999 by Center SpotLight Media (SoloEuro), on Flickr
Step 4
DSC_0995 by Center SpotLight Media (SoloEuro), on Flickr
DSC_0998 by Center SpotLight Media (SoloEuro), on Flickr
Step 5
DSC_1003 by Center SpotLight Media (SoloEuro), on Flickr
Step 6
DSC_1002 by Center SpotLight Media (SoloEuro), on Flickr
Step 7
Step 8
DSC_1004 by Center SpotLight Media (SoloEuro), on Flickr
Step 9
**Remove brake pad sensor.
DSC_1006 by Center SpotLight Media (SoloEuro), on Flickr
Step 10
**Cut brake pad sensor.
DSC_1007 by Center SpotLight Media (SoloEuro), on Flickr
Step 11
DSC_1009 by Center SpotLight Media (SoloEuro), on Flickr
Final product.
DSC_1010 by Center SpotLight Media (SoloEuro), on Flickr
Final product with wheels on.
* for clearance between calipers and spokes of the wheels, I used H&R 12mm hubcentric spacers for the front, and H&R 15mm humbcentric spacers for the rear.
DSC_1043 by Center SpotLight Media (SoloEuro), on Flickr
DSC_1044 by Center SpotLight Media (SoloEuro), on Flickr
Last but not least, I bled the brakes using DOT 4 brake fluid and the power bleeder from ECS.
I want to thank Chase (2000 328Ci) for hooking me up with Rotora, as well as Loren from Rotora, who helped me get everything ordered, shipped, and squared away!
Thanks for Looking!
-Shaun-
Instagram: bmwsoloeuro
-2002 Alpine White M3-
(www.centerspotlightmedia.com)
Flickr Photostream
bmw330ice is offline   Reply With Quote
Old 06-29-2012, 02:19 PM   #2
Snik
Snik's Avatar
My Ride: IR M3 Vert.
So once u cut the pad sensor, and twist the wires together no code?
That's it?
Do you have to cut/remove off the OE dust shield to fit or could u have only cut a part of it?
What size rims are u rocking?
Great write up BTW?
Do you ride a sportbike?
Old 06-29-2012, 02:33 PM   #3
bmw330ice
That's it?
Great write up BTW?
Yup! That's it! ...the twisting of the wires technically "out-smarts" the coding...making it believe its still present.
...and yes you do. For the backs, you have to cut the whole shield off, but for the fronts, you can just cut off the bottom half.
18" CSLs
Thank you!
-Shaun-
Flickr Photostream
Old 06-29-2012, 02:36 PM   #4
Snik
Snik's Avatar
Me likey. Thanks man. And good job again.
Post full side shots.
Old 06-29-2012, 03:31 PM   #5
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
Looks amazing buddy and so glad to see the install went smoothly. I've really loved my kit and haven't had any hiccups. Go Rotora
Timeless Motor Group
Old 06-30-2012, 01:57 AM   #6
bmw330ice
Thanks again buddy! ...and will do, just waiting on one more thing and then I'm getting new tires and rolling the fenders this next week. So then I shall post full side shots!
Thanks again buddy! I'm glad it went well too!
-Shaun-
Flickr Photostream
Old 06-30-2012, 01:56 PM   #7
LeontiyZHP
My Ride: '04 330Ci ZHP
Great DIY! And nice pics!
Leo
2015 BMW 335i M-sport (BSM)
2014 BMW x3 28i M-sport (BSM)
2004 330Ci ZHP SOLD and very much missed.
DIY Facelift Angel Eyes | AVIC-D3 Install | flickr
LeontiyZHP is offline   Reply With Quote
Old 07-01-2012, 01:52 PM   #8
blazedxjan
My Ride: 01 325ci
sexy hardware
Shout Out cowmoo
RIP Edgar F. Glavez 4/19/89-10/19/2014
blazedxjan is offline   Reply With Quote
Old 07-01-2012, 04:35 PM   #9
djnekkon
My Ride: MB3ci & z33 HR
Great looking BBK. Love your car.
Old 07-02-2012, 09:43 AM   #10
johnca
Modded ///Member
johnca's Avatar
My Ride: E46 Slow CSL
Nice BBK upgrading it looks amazing!!
johnca is offline   Reply With Quote
Old 07-02-2012, 07:47 PM   #11
bmw330ice
Thank you x2!
Originally Posted by blazedxjan View Post
sexy hardware
Thank you!
Thanks buddy! Love your car too, very unique!
Thank you, John!
**update. Just took it out (after not driving it for a month. ) to break in the new brakes and I must say, they were very easy to break in and they work fantastic! I will post more shots, including full side shots once I get the new tires on, fenders rolled and get it washed!
Stay tuned!
-Shaun-
Flickr Photostream
Old 07-07-2012, 04:36 PM   #12
bmw330ice
Well, been a crazy week to weekend, but finally got some new shots taken. Still have a lot to go through, but here's an update!
BMW 330Ci with ATL Skyline by Center SpotLight Media (SoloEuro), on Flickr
Rotora Stopping Power by Center SpotLight Media (SoloEuro), on Flickr
330Ci Stanced by Center SpotLight Media (SoloEuro), on Flickr
....only thing left to do for the Exterior, is M3 Rep Front bumpers, CSL 1-piece front lip, ZHP M-Tech 2 rear bumper, CSL boot lid and M3 Rep Mirrors with Auto-Fold. Then on to performance!
Thanks for looking!
-Shaun-
Flickr Photostream
Old 07-07-2012, 05:41 PM   #13
LoveBeingUseless
My Ride: 2003 325i Sedan
Looks awesome! so jealous
Front:18x10 et12 Rear: 18x10 et20
Check Out My Build Thread:
For more updates, Follow me on Instagram! @LoveBeingUseless
LoveBeingUseless is offline   Reply With Quote
Old 09-02-2012, 12:22 AM   #14
bmw330ice
Thanks, buddy!
Update: Waiting on my Carbon Fiber CSL trunk to arrive from ECS tuning...
...in the meantime, decided to take a few shots after I was done working on my dad's car for the day. Plus, I wanted to try out my new lens that I picked up a couple of weeks ago.
haha I promise not to over-do the bokah next go-round, but my primary purpose to get this lens was to get that great natural background blur with the sharpness where I wanted it instead of having to do so in Photoshop.
Enjoy! ...I'll post more when I install my CSL bootlid!
BMW 330Ci & BMW M5 by Center SpotLight Media (SoloEuro), on Flickr
Rotora BBK by Center SpotLight Media (SoloEuro), on Flickr
BMW 330Ci w/ Rotora BBK by Center SpotLight Media (SoloEuro), on Flickr
Red Hot Stopping Power. by Center SpotLight Media (SoloEuro), on Flickr
Like a Boss. by Center SpotLight Media (SoloEuro), on Flickr
///M = More Power, More Fun! by Center SpotLight Media (SoloEuro), on Flickr
BMW 330Ci in the shadows by Center SpotLight Media (SoloEuro), on Flickr
-Shaun-
Flickr Photostream
Old 10-05-2012, 10:58 AM   #15
bmw330ice
New carbon fiber CSL Bootlid. ....one more part for the 3er is on the way, and should be installed before 4ngiefest'12 ....lol the new part was a last minute decision and a b-day gift from my parents for my 21st.
"BMW 3 Series Love" 330Ci & 335is by Center SpotLight Media (SoloEuro), on Flickr
Carbon Fiber CSL Bootlid by Center SpotLight Media (SoloEuro), on Flickr
-Shaun-
Flickr Photostream
Old 10-14-2012, 01:35 AM   #16
bmw330ice
Well, this will probably be my last mod for a bit. It's been a fun modding season and did a lot of stuff this year.
Here's the recently installed Carbon Fiber M3 GTR style hood w/ vents.
e46 330Ci w/ CF GTR Style Hood by Center SpotLight Media (SoloEuro), on Flickr
Rotora BBK w/ new CF M3 GTR Style Hood by Center SpotLight Media (SoloEuro), on Flickr
Next up when I get more cash:
- M3 front bumper w/ 1 piece CSL lip
- M-Tech II rear bumper
- M3 Mirrors (Maybe, only if I find nice OEM ones)
- Repaint whole car
- Exhaust (most likely going quads on the outer most part of the rear bumper. Unlike the M3 middle setup)
Enjoy! Thank you for looking!
-Shaun-
Flickr Photostream
Old 12-07-2012, 03:21 PM   #17
vassilisvot
My Ride: E46 Convertible
Send a message via MSN to vassilisvot
Excellent...
The new rotors are 355x ? ... You did't told us ....
vassilisvot is offline   Reply With Quote
Old 12-07-2012, 04:07 PM   #18
jM2.me
My Ride: BMW
Where did you get these?
jM2.me is offline   Reply With Quote
Old 12-07-2012, 04:19 PM   #19
2000_328CI
2000_328CI's Avatar
Originally Posted by vassilisvot View Post
Excellent...
Yeah 355 6 pot front and 355 4 pot rear
Rotora.
Old 12-07-2012, 04:21 PM   #20
vassilisvot
Yeah 355 6 pot front and 355 4 pot rear.
355x ????? 34, 36, 32 ????
