Thread Tools Search this Thread Rating: Thread Rating: 168 votes, 5.00 average. Display Modes
Old 06-30-2012, 04:56 PM   #661
yenghead
My Ride: 325i Msport
I got another pair of wires and I tried again but this time using the headphones port but the same result.
I wonder if the wire I got is the problem but don't see how!? the wire I bought is headphone jack to stereo ( red & white) connector. Ideas anyone
yenghead is offline   Reply With Quote
Old 06-30-2012, 06:48 PM   #662
ltx325i
My Ride: 2004 325i
Can you take another close up picture of your soldered connections without the tape?
"My formula for success is rise early, work late, and strike oil." - J.Paul Getty (1892-1976)
ltx325i is offline   Reply With Quote
Old 06-30-2012, 07:00 PM   #663
yenghead
I won't be able to cause I cut them, then today when tried again I just crossed them & taped it up. What was you thinking might be the problem!? Thanks for your response
Old 06-30-2012, 07:06 PM   #664
ltx325i
My Ride: 2004 325i
Looking at the pic you posted of the soldered wires sitting on your work table, it just looked like you stripped the wires far back. Especially the red one. I thought maybe the solder was creating a short. It is better to strip the cable's outer insulation back far enough so that you have plenty of Red, White, and Shielding cable to work with which allows the solder connections to be away from each other and taped well.
I'm not implying this was not the case, it just looked like they where very close in that picture.
Luckily for you, I am at work now. I will show you what I mean. One minute.
Old 06-30-2012, 07:18 PM   #665
ltx325i
My Ride: 2004 325i
Example
I didn't have a cable with both left and right in the same cable. Here is the red one. Just as a reference though.
Old 06-30-2012, 07:18 PM   #666
yenghead
Ok cool, look forward to see what u mean exactly...
Old 06-30-2012, 07:22 PM   #667
yenghead
Yeah I see, but today when I tried I did not bother to solder them just tied them and then taped them. Do you think the wire style I'm using could be the problem? It's just I don't see how it could cause I have tried 2 different wires & types!!?
Old 06-30-2012, 07:24 PM   #668
yenghead
1 sec I found the pic on my phone from when I soldered them....
Old 06-30-2012, 07:25 PM   #669
yenghead
Sorry for crap pic...
Old 06-30-2012, 07:28 PM   #670
ltx325i
My Ride: 2004 325i
Here is something I put together just real quick. Not the best job as I was rushing.
Old 06-30-2012, 07:30 PM   #671
ltx325i
My Ride: 2004 325i
Sorry, just noticed your previous post.
To answer your question, without knowing anything else....NO, I don't think it is the wiring that you are working with.
Old 06-30-2012, 07:31 PM   #672
yenghead
You see the wire your using is different from my one, would that make a difference?
Old 06-30-2012, 07:32 PM   #673
yenghead
This thing is driving me mad...
Old 06-30-2012, 07:38 PM   #674
ltx325i
My Ride: 2004 325i
It shouldn't matter. You have a red and white RCA cable with all 4 wires in one cable. I just happen to have them separate. On your cable, you will run the red wire to the + of one speaker (usually right speaker), and the white to the + of the other speaker (usually left speaker). However, which one you choose doesn't really matter technically. If you find that when you adjust your balance to the right and it goes left, then you can just swap them at the solder point, or at the connector.
Now, for the shielding or (-)part of the cable. On most vehicles, they are tied together. I think this is the case with the BMW...or at least it was with mine. So, I believe you have all your connections right. I would check the points where you plug them into the radio again.
Old 06-30-2012, 07:44 PM   #675
yenghead
Ok i will but just to clarify I unplug my cd changer and plug the black wire to the second pin on top far right & red to the left of black wire and my yellow(copper)wire underneath the black wire as shown on the first post! Sound wright to you??
Old 06-30-2012, 08:20 PM   #676
ltx325i
My Ride: 2004 325i
Looking at the first post pictures and the pin out diagram, yes, you are correct. Just to clarify...looking at the back of the radio, you have 3 connectors. 1 big on on the top, 2 below it. It should be the one on the right.
Old 06-30-2012, 08:25 PM   #677
ltx325i
My Ride: 2004 325i
Originally Posted by white46 View Post
have to try push the music note button? button between "-" and "+".
While aux is connected, press music note button. it will show input level which will control input volume level.
Here is something else you might try. This is from earlier in the thread. Page 3 maybe.
Old 07-01-2012, 06:11 AM   #678
yenghead
In response to this post I unplug the cd changer and put my wire there..
Old 07-08-2012, 08:06 AM   #679
AquaRelliux
My Ride: 330ci 03 M-sport
I have a 03/03 build date car and my car has HK sound and mode button. I made a cable like this and plugged it in but I dident get it to work I cant cycle my radio to AUX even with the phone conected and running music. I have a iphone btw if that makes a difference?
AquaRelliux is offline   Reply With Quote
Old 07-08-2012, 11:28 AM   #680
AquaRelliux
After trying it today I dident get it to work what are my options then?
bmw aux in, diy aux input, input cable
