Old 10-07-2009, 04:15 PM   #21
superfestiva
My Ride: BMW 318i 2000
Send a message via MSN to superfestiva
The radiator fan is my problem...I just received the fan and don't want to mess something up...
My car is auto btw
superfestiva is offline   Reply With Quote
Old 10-07-2009, 04:48 PM   #22
Daemonix
My Ride: '99 328i
Send a message via AIM to Daemonix
The fan is pretty easy to take out. If you're looking at the front of the engine, there is a screw on the backside of the radiator fan shroud on the top left that needs to be removed. Then on the right side, there is a small plastic rivet that you need to remove as well. After those are out, unplug the connector from the top left side of the radiator fan shroud and life the fan shroud straight up and out.
Thats it!
Daemonix is offline   Reply With Quote
Old 01-20-2012, 01:57 PM   #23
MyE461234
My Ride: 2000 323CI
@D I'm dealing with the same problem now, follow your steps fan is engaging now. So I'm wondering if payed for a new fan for no reason? what if I don't have to replace the fan I just need to do the bleeding properly? What do you think? It's $400 bucks I can use for something els!!!!
MyE461234 is offline   Reply With Quote
Old 01-20-2012, 10:46 PM   #24
blackbrotha
My Ride: 323i bmw 2000
Send a message via Yahoo to blackbrotha
your head gasket maybe gone or the head warp n air is getting into the system ! it the hoses hard the minute u turn the car on ? look into it
blackbrotha is offline   Reply With Quote
Old 07-03-2012, 09:31 PM   #25
Lethal_Zen
My Ride: 2001 BMW 316
Originally Posted by Daemonix View Post
Greetings all! Update here!
I fixed it!
Here's what happened:
I replaced the thermostat and filled the system back up with coolant/distilled water. Turned the car on and it still overheated.
Went back to the boards and read some more about how to "bleed" the cooling system. It turns out that if the heater isn't blowing hot air after you turn the car on, that there is air trapped in the system, and that I didn't bleed the cooling system properly.
I decided to go against taking the coolant plug out from the passengers side exhaust manifold area. That left one bleeder screw, 2 inches to the right of the main coolant fill hole in the top of the radiator reservoir.
I looked at the coolent level, which was full to the brim, and then loosened that screw. Within seconds, the level dropped down with a noticeable air purge coming out of the bleeder screw hole.
I then poured a good gallon or so of distilled water and coolant (50/50) into the resevoir until it filled it.
Turned on the car and squeezed the upper and radiator hoses and few times to push out air. I then replaced the bleeder screw and put the radiator cap on.
This time, the upper radiator hose got super hot which meant that the water was indeed travelling through the block and into that hose... unlike before. This is a good thing.
Within about 10 minutes of idle, my fan came on as noticeable heat was now coming off of the engine.
Took the car for a test drive and had no further issues with the cooling system. After letting it sit overnight from it's run, I refilled the resevoir another 1/4 gallon or so (from air moving out of the system) and capped it back up.
No further issues whatsoever.
Turns out the 10 step instructions for bleeding your cooling system is actually important. It's not like filling up an old truck radiator...
Just wondering where i can find the 10 step bleeding instructions?
Lethal_Zen is offline   Reply With Quote
Old 07-03-2012, 09:32 PM   #26
Lethal_Zen
Hi where do i find this 10 step bleeding guide? Cheers
coolant, fan, overheating, radiator, switch
