Thread Tools Search this Thread Rating: Thread Rating: 33 votes, 4.88 average.
Old 07-08-2012, 05:33 PM   #381
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
Cleaned oil valve and install into new valve body.
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 07-08-2012, 05:37 PM   #382
being3
Modded ///Member
being3's Avatar
Installed vanos selinoid to new valve body and torqued e5 torx bolt to 4Nm in a few passes. Also new seals in vanos plate
Old 07-08-2012, 05:45 PM   #383
being3
Modded ///Member
being3's Avatar
All assembled with vanos plate sitting on top. Now put back reversed way of torquing the five 5mm bolts to 10Nm in multiple steps. The thin plate can be slipped on once u get the main value body as selinoid is repositioned underneath top vanos unit.
Start up after plugging in vanos cable. Check for leaks. Reset codes
Old 07-08-2012, 06:35 PM   #384
being3
Modded ///Member
being3's Avatar
Ok started it up. The afr was 12 to 13 right away. Before the change the afr started at 14.7 and worked its way down to 11s. The car had way more power from 2 to 4 grad rpm. It was a whole new car. Way more power uptop as well and noticiby revved much faster.
Before the value body change it was like it didn't want to rev high yet pulled hard Tells me the cams r now working properly or at least better than they were. The afr at high boost is still 10.5 or 10.9. Which is still troubleing. I'm glad I'm on the right track.
Old 07-08-2012, 06:49 PM   #385
being3
Modded ///Member
being3's Avatar
Now just waiting for batt backup harness and crank sensor so I can see if thats a contributing factor and then send in the logs to be evaluated. The connector has been a while now.
Old 07-08-2012, 08:06 PM   #386
turboi
My Ride: sh1tbox
Are you absolutely there are no boost leaks? It def sounds like its sucking air in through a leak causing a rich condition.
You can make a home made boost leak tester for about 30 bucks with home depot materials
turboi is offline   Reply With Quote
Old 07-08-2012, 08:42 PM   #387
InDiGlOM3
My Ride: HPF M3 stg 2.5
whats the temps outside? its hot here in texas so im running 10.5 to 10.9 under high boost, normal is 10.8 - 11.2
Old 07-08-2012, 08:44 PM   #388
Commanderwiggin
My Ride: 900rwhp Turbo M3
This is what you want! Anything >11.5 would be considered bad. You want it rich in boost.
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Old 07-08-2012, 08:55 PM   #389
being3
Modded ///Member
being3's Avatar
New development. I was refilling the meth tank and ran the test / purge jumper. The car now runs afr at idle 10.5 jumps around to 12s. Messed with the jumper box and harness going into the dme and seems to make some difference when it went in the high tens again. I even seen it at 10 as well So I think I have some cable issues as well somthing else. Man this can be disheartening
Old 07-08-2012, 08:57 PM   #390
being3
Modded ///Member
being3's Avatar
Thanks that's refreshing
Old 07-08-2012, 08:58 PM   #391
being3
Modded ///Member
being3's Avatar
Temps were in the 25c to 28c range. Thanks for ur info that makes me
Feel the high boost is normal
Old 07-08-2012, 09:56 PM   #392
being3
Modded ///Member
being3's Avatar
I'm running 20 inches of vacume and 22 to 24 when hot. I'm don't think I have a bost
Leak. My erratic idle is what's got me Concerned. I'm also seeing high idle rpm above 1100 and takes a while for it to settle down even when it's warm or hot. ???
Old 07-08-2012, 10:01 PM   #393
being3
Modded ///Member
being3's Avatar
Car is very close to Being sent down to HPF again.
Old 07-08-2012, 10:44 PM   #394
being3
Modded ///Member
being3's Avatar
Car is at afr at idle 12s then down to 11a and 10s. And 10.0 at high boost sometimes it's 10.5
Old 07-08-2012, 11:11 PM   #395
being3
Modded ///Member
being3's Avatar
I let the car sit and I resorted the wiring harness and put the top back on loosely. Afr back to 12 at idle.
I ll have to drive a bit to see how it holds up. It could also be the used vanos valve body being flaky.
Old 07-09-2012, 03:34 AM   #396
BMW E465
My Ride: 1dirty5
How'd you go?
BMW E465 is offline   Reply With Quote
Old 07-09-2012, 12:18 PM   #397
HPF Chris
Past Site Sponsor
My Ride: 2002 M3, 2006 530i
That's fine.
HPF Chris is offline   Reply With Quote
Old 07-09-2012, 02:54 PM   #398
being3
Modded ///Member
being3's Avatar
Originally Posted by BMW E465 View Post
How'd you go?
Car goes into 10 at idle and smells bad. Cleaned the ICV and put back the old vanos value body and the car does the same. ???
Old 07-09-2012, 02:55 PM   #399
being3
Modded ///Member
being3's Avatar
Originally Posted by HPF Chris View Post
That's fine.
It seems that 10 at idle is bad and it's sitting that way a lot of the time. Once and a while it is in the 11s
Old 07-09-2012, 03:03 PM   #400
turboi
My Ride: sh1tbox
High idle, rich conditions etc are all signs of boost leaks, test it with a home made boost tester to make sure 100% there are no leaks, or take it to a performance shop and they can test it there.
With that said i love how hpf just sits back and watches you suffer while you pour countless of hours and dollars into the car, after they ok'd it and said it was fine to leave.
e46 m3, hpf, stage 2.5, turbo
Rate This Thread
