The Showroom
This is the place to show off your BMW to other members of the community. Post pictures and videos of your car and the modifications you have done to it. If you need a picture of something on a coupe, sedan, convertible or touring you will probably find it here! |
Rating:
Display Modes |
#161 |
My Ride: Jet Black 1999 323i
Need Help!
My car has been vibrating realllllly bad. Could it just be the tires? I'm ordering some new rear tires tomorrow and hopefully that will take care of it. Yes i'll get an allignment once I get the new tires. Can I get 205/50/16 tires for the rear or do they need to be 55 like the front? Do I have to get the same tread pattern as the front? FRONT: ![]() ![]() REAR: ![]()
MY PROGRESS THREAD: HERE STUFF FOR SALE: SEDAN M3 STYLE REAR BUMPER : SEDAN SEIBON CSL CARBON FIBER TRUNK ![]() GET A CUSTOM GRAFFITI PHONE CASE DESIGNED BY ME: CLICK HERE FOR PHONE CASES POST YOUR E46 IN THESE THREADS IF YOU HAVE.. 18" WHEELS : 19" WHEELS |
#162 |
My Ride: MB3ci Regensburg Bav
The thread pattern doesn't have to be the same, but I recommend you to get 55 too for the rear. Otherwise, it would be like having 16's wheel at front and 15's at rear.
#163 |
Nice tread
Jordan
![]() My Build Thread EuroSpec CSL V1 Bumper l CSL One-Piece Lip l 18x10 Square HyperBlack APEX ARC-8 l Black Grills/Gills & Emblems l Carbon Fiber Roundels Status Rear Section l Carbon Fiber Intake Duct l Gruppe M Intake l OEM JB Hardtop l Drilled/Slotted Rotors l D2 Coilovers w/Camber Plates l VIS CSL Trunk |
#164 |
'a certain moderator'
Tires dead? Buy useless shifter instead of new tires.
#165 | |
If so then what tires do you guys recommend for the rear? http://www.onlinetires.com/user/vehi...allbrands.html Cheaper the better but I don't want ones that are going to be hella loud or die quick Thanks!
#166 |
Yea since that shift knob/beer tap took up all my money?
I have plenty of money to get tires.
#167 | |
#168 | |
#169 |
Please let me know if you know of one! I've decided to fix up my interior before other things.
http://forum.e46fanatics.com/showthr...7#post14545737
#170 |
got new tires because I needed them and to hopefully get rid of the bad vibrations.
![]() ![]() ![]() ![]() got the tires on and drove around, the really bad vibrations were still there. ![]() Took the car to the shop to get diagnosed. It sounds like it might be my left rear wheel bearing. I just had the right rear one replaced. They haven't had time to look at it yet. ![]() Interior work will have to wait.
#171 |
the bearing also sound stupidly loud whee running. Did you check your control arms/bushings?
#172 |
Also could be a minor bends in your wheels, might want to check those as well.
#173 | ||
I didn't check those, it's at the shop already so they'll take a look. Thanks for the heads up though. I need the car fixed asap so I can get to work and not have to take my moms car lol ![]() Quote:
Thanks for the words of advice guys. When the mechanic tells me what's wrong, i'll ask you guys to see if I can fix it on my own.
MY PROGRESS THREAD: HERE STUFF FOR SALE: SEDAN M3 STYLE REAR BUMPER : SEDAN SEIBON CSL CARBON FIBER TRUNK ![]() GET A CUSTOM GRAFFITI PHONE CASE DESIGNED BY ME: CLICK HERE FOR PHONE CASES POST YOUR E46 IN THESE THREADS IF YOU HAVE.. 18" WHEELS : 19" WHEELS Last edited by domcreates; 07-12-2012 at 10:16 PM. |
#174 |
The problem was the hub. Spent about $500 to fix it. Hopefully i'll be able to start the interior after my next pay check. GF is coming to visit at the end of July so I need to start saving money for that also lol
I wish all my hubs looked like this one we replaced Before: ![]() After:
#175 |
+1 on saving money. I am Glad you found the problem and it got fixed fast. Enjoy brosky!
#176 | |
also my cars handling has either turned to **** or its a lot better than it has been and i'm not used to it. I'm guessing this is because of the new tires of course, but why exactly? I start taking a hard turn and it feels normal, then all of a sudden it cuts hard and I'm not turning the wheel anymore than I was... Is it because of the different tread patterns? Because the tires were inexpensive? Or just that i'm not used to having a lot of tread on my rear tires since I came home from college and have been driving with barely any tread until now?
#177 |
The handling got worse or better? Should be better because of new tires. Cheap new tires are better then used bald tires regardless.
#178 | |
I would also visually check the Control Arms, Sway Bar Links, Tie Rods, Strut mount points or a worn spring pad. I do this a lot, I just remove my wheels and look very carefully. as an example check this guy videos
#179 | ||
#180 |
My rear right window decided to crap out on me now. how do I find out what's wrong with it? I'm guessing it's the motor?
| Tags |
| -*nga*- |
