Old 07-12-2012, 05:59 PM   #21
smolck
My Ride: 2004 ZHP Sedan
Originally Posted by Mctwist77 View Post
Haha yeah they have saved me a lot of money and time. I'm just getting in, finally graduated college.
As for the fans, I need a pusher or a puller fan? Since I have a manual I only have one fan and its the pusher right?
Thanks for your service to our country and freedom!
I have seen several early model E46 manuals with both aux and mechanical fans. If you have one with only the electric fan it would be a puller fan.
Check out my BMW Blog
http://smolckbmw.blogspot.com/
Check my Youtube channel for DIY's and fun stuff
http://www.youtube.com/user/flipfinish?feature=mhee
smolck is offline   Reply With Quote
Old 07-12-2012, 06:03 PM   #22
Platinum Plus Quality
My Ride: M54B30
Originally Posted by smolck View Post
You could say the same thing about speeding, drinking and driving, drugs, or anything else. Of all which are MUCH more dangerous (and common) than venting a tiny bit of r-134a.
Right and I'd agree with you. I do say the same for all of those things. Releasing R-134A into the atmosphere is harmful and should be avoided, if at all possible (which it is).
http://www.epa.gov/ozone/title6/608/
And re: maintenance-wise, why it's a good idea, the oil contained in R-134a is hydroscopic and is corrosive to the entire system as it absorbs moisture and breaks down.
Cooling | Maintenance | Vacuum | Suspension | Costs
"Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs
Old 07-12-2012, 06:14 PM   #23
smolck
Clean Air Act was a joke (as is MOST "legislation" these days). Just a way to increase taxes on industry based on "global warming" science that is not accurate and widely disputed. That is another topic for another forum, but I doubt the .5 sec worth of venting r-134 is going to result in the ozone layer blowing up and solar wind eating our faces off.
Old 07-14-2012, 03:03 PM   #24
Mctwist77
My Ride: '99' BMW 323i
Quick bump before I go buy a new fan. So again, my electric fan is spinning but I don't think it's blowing hard enough. Could this be an issue with the temp sensor located on the lower radiator hose? Additionally, my AC blows cold at idle when outside temps are below 85 degrees.
Photobucket
BMW 323I 5 Speed
Mctwist77 is offline   Reply With Quote
Old 07-14-2012, 04:32 PM   #25
kaboo0m
My Ride: 04 325xi
Send a message via AIM to kaboo0m
you sure it is not your condensor? what are the pressures and how's your vacuum. parallel flow condensors, unlike the older tube and fin style, are more susceptible to clogging because of their thin pathways. In fact, they cannot be flushed and must be replaced once it is clogged.
kaboo0m is offline   Reply With Quote
Old 07-14-2012, 04:38 PM   #26
325guy
Banned User
My Ride: 2003 325i stick
Oh look another AC thread
325guy is offline   Reply With Quote
Old 07-14-2012, 04:53 PM   #27
afstud
My Ride: 02 & 04 325xi sports
had the same problem with my 99 328i couple years back (first e46) and just bought a can of the recharge stuff and put in a bit and was super cold all the time after that...
afstud is offline   Reply With Quote
Old 07-14-2012, 04:58 PM   #28
wacuna
My Ride: BMW 323i
The problem is the fan... I'm 100% sure, all symptoms you mentioned I had the same problem and it was the fan. I bought it for $144 on ebay... yes the fan is spinning but not at the right speed, the controller is bad but the controller is part of the fan so you have to buy the whole thing.
wacuna is offline   Reply With Quote
Old 07-14-2012, 05:55 PM   #29
Mctwist77
What the hell is the point of saying that? Yah it is about my AC.
Sent from my DROID2 using Bimmer App
Photobucket
BMW 323I 5 Speed
Old 07-14-2012, 06:27 PM   #30
afstud
the fan on my last e46 wasnt working full speed either and still had ice cold a/c at idle...i still believe its low on r134
Old 07-14-2012, 06:35 PM   #31
Stinger9
My Ride: '04 330Ci
The amount of damage to the ozone from a can of r134a is less than the can of Aqua Net my granny uses to keep her beehive nice and tall.
Pics of granny? I dig beehives.
Old 07-15-2012, 12:00 AM   #32
ptrcd003
My Ride: .
Yes, "disputed" . Hundreds of thousands of scientists vs a few politicians who are getting paid off. As long as they keep calling it "disputed", people like you will will believe it, since doing nothing is the path of least resistance.
ptrcd003 is offline   Reply With Quote
Old 07-15-2012, 12:21 AM   #33
Stinger9
My Ride: '04 330Ci
Relax, from what I've seen you could use things a little warmer up there in Canada. Maybe with a different climate you'll finally be able to grow tasty vegetables! Increase tourism with that, and who knows? Even pay for national health care with waits shorter than three months!
