Rating:
#761 | |
#762 |
I have windows 7 64bit running PA soft. theres a DIY somewhere in this big thread. Its on bimmerforums. Do a google search, you will see it.
.:Eugene:. I used to be an e46 owner. I love this one more. ![]() |
#763 |
so i havent been able to find anything that says this is possible through coding... was wondering if anybody has tried a relay between the door lock/unlock button in the center console and the shifter... so when you put car in park it will trigger relay to throw unlock???
#764 | |
http://www.ulozto.net/xssDoKA/bmw-sc...iver-64bit-rar Last edited by deeterry13; 07-07-2012 at 11:57 AM. |
#765 |
took a while but i read this thread...........ive seen it passed over a few times but not really sure still.
i ordered it from X360 on a E46 m3 is it at all possible to get live data using PA SOFT 1.4? if so what pins should be soldered together to get live data in pa soft! Is it possible to do the vanos test?
![]() Mods: [] Section 1 Dual AR20's[] B&B Exhaust[] Led interior [] SSBL []KW V3 [] Eibach F&R Sways[] BMC Filter |
#766 | |
How do you disable auto-lock? The options seem to be "terminal R" (when you go through reverse?) or various speeds, but not disable. |
#767 |
If I can't read live data what does that mean about my cable I can code lcm but not the cluster also
#768 |
Banned User
BMW Scanner V1.3.6 is a new version of BMW scanner intended to work with BMW 3, 5, 7 series and X3, X5 SUV cars.
BMW 1.36 diagnostic interface is used to read/clear error codes and read/write certain memories of devices in the diagnostic chain. It connects your computer by RS232 COM port, support all E38/E39/E46/E53/E83 upto 2004. Workable Models This interface works on all BMW E38/E39/E46/E53/E83 upto 2004 E38 - 7 Series E39 - 5 Series E46 - 3 Series E53 - X5 Series E83 - X3 series Some of the systems accessible with this device DME-Digital Motor Electronics E38/E39/E46/E53 up to 2004 EGS-Electronics gearbox control E38/E39/E46/E53 up to 2004 EWS-Electronics car immobilisation system E38/E39/E46/E53 up to 2004 ABS-antilock-braking system with ASC/DSC E38/E39/E46/E53 up to 2004 EHC-electronic height control E38/E39/E46/E53 up to 2004 A/C-E38/E39/E46/E53 up to 2004 FGB-Rear compartment blower E38/E39/E46/E53 up to 2004 SRS-Supplemental restraint system E38/E39/E46/E53 up to 2004 IKE-instrument cluster electronics E38/E39/E46/E53 up to 2004 Mileage correction on E38/E39 with 93s56/66 chips AND mileage correction on E46 to sw15 LCM-Light check modules E38/E39/E46/E53 up to 2004 GR2-Cruise control E38/E39/E46/E53 up to 2004 PDC-Park distance control E38/E39/E46/E53 up to 2004 AIC-Automatic interval control E38/E39/E46/E53 up to 2004 RAD-Radio E38/E39/E46/E53 up to 2004 SZM-Switching centre, centre console E38/E39/E46/E53 up to 2004 NAV-Navigation system E38/E39/E46/E53 up to 2004 MID-Multi-info dispaly E38/E39/E46/E53 up to 2004 ZKE-Central body electronics E38/E39/E46/E53 up to 2004 SMB-Passenger seat memory E38/E39/E46/E53 up to 2004 LSM-Seat/steering wheel memory E38/E39/E46/E53 up to 2004 EDC-Electronic damper control E38/E39/E46/E53 up to 2004 LEW-Steering angle sensor E38/E39/E46/E53 up to 2004 RDC-Tyre pressure check E38/E39/E46/E53 up to 2004 MFL-Multi-function steering wheel E38/E39/E46/E53 up to 2004 DSP-Digital sound processor E38/E39/E46/E53 up to 2004 BMBT-On-board monitor, control panel E38/E39/E46/E53 up to 2004 VID-Video Mdule E38/E39/E46/E53 up to 2004 SES-Language input system E38/E39/E46/E53 up to 2004 Tel-car telephone E38/E39/E46/E53 up to 2004 HKM-Boot lid module E38/E39/E46/E53 up to 2004 LRA-Automatic headlight vertical aim control E38/E39/E46/E53 up to 2004 FID-Multi info display rear E38/E39/E46/E53 up to 2004 NAJ-Japanese navigation system E38/E39/E46/E53 up to 2004 |
#769 |
Not sure actually.....I had mine done a couple of years ago at an indy shop. I seem to remember that it can be done with this software though. Maybe someone else will be able to answer your question here.
#770 | |
You can get live data from the DME module, just double click on it and you'll see a "Live Data" button on the left column. No VANOS test afaik, but it will tell you if its engaged, ready, etc. |
#771 |
My Ride: too many to list
I started to code some stuff on my 02 m3 the other day and it asked me to save a copy before I recode. I read the LCM, and thought I saved it, but it gave the warning again. Where do I need to save the copy to?
#772 |
I hope someone can help me out, so I'm gonna pick everyone's brains for a second.
![]() My car has the factory xenons with automatic vertical aim. It has a bad front sensor (more like broken pivot arm), so I disconnected it, aimed them how I like them ... it still does the sweep when I turn them on, but honestly how much can it know what the hell to adjust when all it's reading off is the rear. Anyway, I went to disable the feature, and as soon as I uncheck "automatic" or "vertical headlight control" in LCM recoding, the checkbox to the left where it says "xenons" gets unchecked. Is this a problem? I am scared to actually recode fearing I might wreak havoc on the LCM given the car actually has xenons and I am effectively turning the feature off ... can anyone shed some light on the situation?
#773 |
Wow, after scanning 39 pages of this thread I forgot what I was looking for..
I got my top up/down with the key, played with some light settings, and lock settings. I thought I wanted the auto lock at a certain speed but I don't like having to double pull the handle to get out. Is there a setting to auto unlock with turning the key off or something? |
#774 |
Did you get this figured out? I was scanning the thread and didn't see a direct answer. I've got mine working and am getting ready to take some screen shots of how I've got it set. Let me know if you still need it.
#775 | |
Slightly Modded ///Member
Where do I find the light settings?
All I have is a bunch of crap about my alarm and locks. Quote:
I want to change it so my locks unlock when I turn off my car. And also so that all my door locks lock and unlock with one button press.
#776 |
post up some screen shots, i'd love to see how to make all my doors unlock with one push
![]() | VF Supercharged | Southbend Stage 2 Clutch | ZHP Cams | Technik Headers | |
#777 |
The light settings are under LCM-Light Check Module.
Locks, etc are under ZKE, which it sounds like you found. Some cars have different screens, my 04 M3 Vert looks like this. ![]() Daytime running light US turns on the round lights (not sure exactly what they're called) anytime the key is on. Daytime running light turn sign. turns on the corners when the key is on. I think I'm actually going to disable both of these when I put angel eyes on. I played with some of the other settings but most didn't seem to do anything. ![]() I had to play with the lock settings but set up like this I have all locks locking and unlocking with 1 press, and auto locking at 28 km/h. The 1 touch locking is the settings that are "Entr. aid". The One-touch functions settings let me put the top up and down from the remote. I may have some extra stuff checked that I don't need but through playing with different settings I've got what I wanted. I haven't found a way to unlock when turning the car off yet. Not sure it's possible on these cars at this point. |
#778 |
My Ride: 325ci / 350Z / LS400
I just got my PA Soft today!
I hope I don't mess something up
#779 |
i am always annoyed by having to press the unlock button to open the back doors and the boot, or pulling the lever twice to open the door. Is there any way to use pasoft to unlock the car when putting in park, or turning off the engine? Or can the auto-locking be disabled?
#780 | |
Great thread and kudos to OP and all other contributors.
I've just spent 2 days reading through 40 pages in this thread before even plugging in my scanner.... only to find a problem, the same as boongsin12 posted below. Appreciate some help with 2 issues... 1. My scanner seems to read everything except for the DME and some other modules (which are essential!). My key is in position 1 and I have also tried position 2. 2. In order to access the EWS do I need to erase and unlock it? By doing this will it mean that I can successfully code to the EWS? I know this must seem elementary to you all - I would rather ask than make a mistake on this ![]() Please see attached pics for more info.... thanks! Quote:
![]() I can help with * Reading Codes / Coding your car * R&R FCAs, Tie Rods, Sway links.... * RTABs Need an RTAB tool? Or clutch fan and water pump tools? PM me. |
| Tags |
| bmw scanner, diagnostic tool, error message, pa soft |
| Rate This Thread | |
