Thread Tools Search this Thread Rating: Thread Rating: 1996 votes, 4.91 average.
Old 07-17-2012, 01:02 AM   #10861
MrGL2
My Ride: 2000 323Ci
Installed new radiator fan since old one was cracked
MrGL2 is offline   Reply With Quote
Old 07-17-2012, 01:14 AM   #10862
zhenkaaaM3
My Ride: Fst'r then your e46
ordered another ps pump. lets hope this fits.
Eugene
Former E36 M3 Owner + E46s
zhenkaaaM3 is offline   Reply With Quote
Old 07-17-2012, 01:15 AM   #10863
illestminimike
My Ride: Project Drama
Ugh I just wanna get the damn AC belt tomorrow so i can stop sweating out a medium size lake every time I get in my car.
Old 07-17-2012, 02:15 AM   #10864
sweetbro858
Banned User
My Ride: BMW
I aired up my tires. They were all at 22psi
*flame suit ON*
sweetbro858 is offline   Reply With Quote
Old 07-17-2012, 10:11 AM   #10865
ngillan
My Ride: Is in a salvage yard
I dropped it off at the shop for new window regulator, water pump, and oil grommets..
'07 328i - Montego Blue
ngillan is offline   Reply With Quote
Old 07-17-2012, 10:17 AM   #10866
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Diy!!!
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 07-17-2012, 10:20 AM   #10867
ngillan
Originally Posted by Solidjake View Post
Diy!!!
I wish I had the time and skill...im sort of a mental midget when it comes to working on mechanical issues like this. Main issue with the regulator is putting the door back together . I am DIYing my interior though (CF wrap), and also did DIY on turn signals and tail lights (I know these are easy things but its a start).
Old 07-17-2012, 10:26 AM   #10868
Schlag96
Slightly Modded ///Member
Schlag96's Avatar
My Ride: 1999 323i
I bought one of these for Betsy
I frequently bring my buddy on base to surf here because we have some of the best waves in SoCal, but I had to put his board inside my car, which was getting a bit of sand and salt water on her seats.
This will fix that.
Also am spending a few hours today figuring out what to get for a suspension refresh and whether I need a fuel pump or not.
Schlag96 is offline   Reply With Quote
Old 07-17-2012, 10:27 AM   #10869
aeorozco
My Ride: 2000 323i
Send a message via Yahoo to aeorozco
Just replaced my fuel pump, F.P. Relay, and replaced the front window cowl last night Car looks and runs like a champ!! I have to admit that replacing my fuel pump got rid of the hesitation on hot days driving in the city, and it seems the throttle response is better, Now just waiting for my intake boots (Upper and Lower) to come in so I can replace those
2000 323i ........Stock for now
aeorozco is offline   Reply With Quote
Old 07-17-2012, 10:27 AM   #10870
Skins45
My Ride: 2001 330xi
Blacked out grille
Started custom shift knob project (dremmeled down block of wood to rough shape)
Average 24mpg for last tank
This weekend,
put cashmire leather throughout interior
Cashmire enamel on trim (w/clear coat)
45mi of twisties!!! (SE Ohio)
Skins45 is offline   Reply With Quote
Old 07-17-2012, 10:32 AM   #10871
jneumann
My Ride: 323i, 530i, Z4 3.0i
Send a message via AIM to jneumann
Should help the can't-fully-use-first-gear problem a bit.
For the Z, not E46, but I run the same awesome tires on my E46, albeit in slightly thinner size.
Sent from my SCH-R530U using Bimmer App
E46 323i Sport/5 speed | 243k miles
E85 Z4 3.0i Sport/6 speed | 117k miles
E83 X3 3.0i M-Sport/6 speed | 130k miles
E39 530i M-Sport/5 speed | 237k miles
Member, Three Pedal Mafia | Long informative article on oil | BITOG German Castrol FAQ
jneumann is offline   Reply With Quote
Old 07-17-2012, 10:37 AM   #10872
boostedisbetter
boostedisbetter's Avatar
My Ride: 2008 S2000, 2009 CBR
Almost have all of the parts needed
Hey man, I am doing the same thing soon and my parts bin looks exactly like that haha.... Have you heard any bad things about Beisan Systems vanos repair kit? I've heard people going with DRVANOS instead, but I really don't wanna spend the $250+$150 core charge they charge...
Also, what parts are you missing from that pic? Looks like you have everything needed for VCG and VANOS... Maybe ur replacing the bolts too? Do the bolts usually break-I've heard of this happening.
Originally Posted by Green_Shine View Post
(2/14/2017)Trump, by definition is a nitwit. He has every opportunity to make sound decisions, and he is incapable. I can't see this guy lasting 4 years without resigning or being impeached.
boostedisbetter is online now   Reply With Quote
Old 07-17-2012, 10:54 AM   #10873
aeorozco
My Ride: 2000 323i
I replaced everything when i did my Vanos with the Besian kit, I didnt want to have to deal with broken bolts, and I figured if i spent the extra 30 for the other parts, i wouldnt have to worry about replacing them later on. I also changed my plugs and wires when I was doing my Vanos. Just remember that if you use a little bit of RTV to hold the vcg in place, make sure you let it sit for like atleast 12hrs to let the silicone cure and dry before you drive it
Old 07-17-2012, 11:00 AM   #10874
ryannel2003
My Ride: '04 Cadillac Deville
New front license plate
ryannel2003 is offline   Reply With Quote
Old 07-17-2012, 11:23 AM   #10875
ngillan
just got the call from the shop $366.60 was the bill, plus I need some work in the engine oil department: Valve cover gasket, engine pressure wash, and new vacuum line for $290 installed plus new oil line for $56 installed. Does this sound right?
Old 07-17-2012, 11:53 AM   #10876
boostedisbetter
[IMG]http://i109.photobucket.com/albums/n46/ryannel2003/217b3e8b.jpg[/IMG
Didn't want the block off?
Old 07-17-2012, 12:51 PM   #10877
CT Bimmer
My Ride: 09' e90 zmp 335i
finally got new headlight lenses and seals..no more condensation and yellow film. night and day difference, especially driving at night. the angel eyes even look more crisp and less fuzzy.
CT Bimmer is offline   Reply With Quote
Old 07-17-2012, 01:14 PM   #10878
Schlag96
Schlag96's Avatar
My Ride: 1999 323i
Mango recommended to me that I do the oil line along with the 4 crush washers when in there doing vanos.
Old 07-17-2012, 01:32 PM   #10879
Wolrab
My Ride: 330Ci MT, 545i SMG
....especially if you're also going to do the OFHG. Look like a chore to get the VANOS oil line off with the OFH in place.
Engineers do it with a torque wrench
Wolrab is offline   Reply With Quote
Old 07-17-2012, 01:36 PM   #10880
My Ride: Lexus
Yep it's a dirty messy chore. Better to only get dirty once. (in the context of cars, of course)
Rate This Thread
