Thread Tools Search this Thread Rating: Thread Rating: 1996 votes, 4.91 average.
Old 07-18-2012, 10:48 AM   #10921
Guest021715
Account closed.
Great review Jake. I'm pushing my dad to buy an F30!
Originally Posted by serdar255 View Post
So how about that video
My dashcam wasn't on
I'll have to retake it tonight. The lights are incredible, they put my xenons to shame.
Old 07-18-2012, 10:52 AM   #10922
ryannel2003
My Ride: '04 Cadillac Deville
Originally Posted by ngillan View Post
Yes, I absolutely loved that car. Probably the most comfortable vehicle I've ever been in. Unfortunately it was wrapped around a tree about a year and a half ago (will post pics from my phone). When I get promoted at my job to "baller status" I will buy another one as an every day driver.
I feel your pain...
I will give that car one thing though... it was a damn tank. My stupid ass flipped mine in a ditch because I was going around a corner too quickly. I too will buy another one in the future as a DD because it was expensive to keep on the road. I don't think my 323 will cost as much in the long run and that's saying something. I don't know if you had to deal with any oil leaks or headgasket issues on yours, but mine was all done before I bought it. Garage kept, 1 owner and in nearly perfect shape. My Bimmer isn't half as nice as the STS, but at least I bought a car that can take a corner well. Glad everybody came out of that wreck ok... looks alot worse than mine. I had a large cut on my head and was in the hospital for a few days.
ryannel2003 is offline   Reply With Quote
Old 07-18-2012, 12:53 PM   #10923
Skins45
My Ride: 2001 330xi
Detailed washing and 2 coats of wax. Going to detail the wheels this evening. Now throwing another clear coat on the grille. Throttle boost switch is coming in today hopefully so that might have to go on tonight as well.
Skins45 is offline   Reply With Quote
Old 07-18-2012, 02:07 PM   #10924
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Cleaned out all of my camping gear from the trunk.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 07-18-2012, 03:13 PM   #10925
zhenkaaaM3
My Ride: Fst'r then your e46
The e46 is back on the road also attempted to fix my trunk handle with the broken pieces of plastic that the torx screws were holding down after it broke off, and alot of epoxy. Hopefully it holds
Eugene
Former E36 M3 Owner + E46s
zhenkaaaM3 is offline   Reply With Quote
Old 07-18-2012, 03:23 PM   #10926
Marinerd
My Ride: 04 xiT, 09 328i
Originally Posted by deadwood83 View Post
Now why would you go and buy an SES light? That's a foolish purchase
I know. What a waste.
Marinerd is offline   Reply With Quote
Old 07-18-2012, 05:37 PM   #10927
///MPR77
My Ride: 02 ///M3 Tri-Ped
Discovered a leak in the back corner of the VCG...*cough* the new VCG at that.
I loosened all the bolts just a tad, and hand torqued them Corner to corner, and worked my way through all the bolts in that same fashion. I went back with a torque wrench set at 6ftlbs and checked each one that I could get to with the torque wrench.
Wiped down the oil leaks in the engine bay,on the garage floor, and took it for a quick spin around the block, and parked again.
Hoping that takes care of it.
Old 07-18-2012, 06:02 PM   #10928
dknightd
My Ride: 2002 330 cic
Ordered a new key $200
Had dealer do an alignment $200
Drove to and from the dealer on a curvy road - priceless
dknightd is offline   Reply With Quote
Old 07-18-2012, 06:30 PM   #10929
Crestwood1001
My Ride: 2001 325xi
That just happened to me to
Crestwood1001 is offline   Reply With Quote
Old 07-18-2012, 06:45 PM   #10930
dknightd
Was the old gasket leaking?
Old 07-18-2012, 06:52 PM   #10931
Hollywood516
My Ride: 02 330i
Rolled my passenger side window down this morning and "BANG" there goes another window regulator.I had to wedge the window up till I change it..We just had some nasty T-storms roll thru,so I guess I'll be changing it tomorrow.. Props to Finaltouch Motorsports . He got me one in 2 hrs..
Hollywood516 is offline   Reply With Quote
Old 07-18-2012, 06:56 PM   #10932
serdar255
My Ride: '01 325ci / '90 325i
I took your word and ordered them I hope they are good!
For coding, custom shift knobs, and vinyl stickers: PM me
serdar255 is offline   Reply With Quote
Old 07-18-2012, 06:57 PM   #10933
Solidjake
Zero. Leaks.
Solidjake's Avatar
The dashcam?
Old 07-18-2012, 07:17 PM   #10934
Slopestyle
My Ride: E46 '02. 330Ci Coup
Took my car for a test spin after flex disk and center sleeve bearing. also shift arm bushings. . . and res delete. hmmm what else. haven't washed her yet but its thunder storming an atrocity right now so i guess not a bad call. Does any one have any opinions and Rear diff bushings? I feel I may leave that to a mechanic friend of mine. I hate getting stuck without the proper tools, can turn a one day job into a "well I'll get back to it next week. "
Slopestyle is offline   Reply With Quote
Old 07-18-2012, 07:30 PM   #10935
S85FTW
My Ride: E60 M5 & F30 328XI
Send a message via AIM to S85FTW
Since you are in CT, take it to JG technik in Branford. I have been going there for a year now and never had to leave my car overnight. I have done headers, rtabs, control arms, cabs, diff fluid, tranny fluid, O2 bypass, water pump, pulleys, belts, vcg all there and was always done same day. If they needed a part they always got it same day.
S85FTW is offline   Reply With Quote
Old 07-18-2012, 07:32 PM   #10936
///MPR77
Originally Posted by Solidjake View Post
The dashcam?
The F30?
Old 07-18-2012, 07:47 PM   #10937
Slopestyle
to SH330CI-
It's the fact that a mechanic hasn't had to touch my car. Along with the help of good friends on occasion, I've done everything so far. It's hard to give my car up and hand over hard earned cash for something that I should be able to do myself. Like always Tools Tools Tools. Need the right ones to get the job done. I've Heard of JG in branford I'm actually right down the street from them. I'll take a ride over there I guess since your not the first person to reccommend them. Thanks for reminding me.
Old 07-18-2012, 07:56 PM   #10938
S85FTW
to SH330CI-
No problem, I understand that, If I had my own driveway I would do my own work as I have done in the past. Brian and Jim are very good guys.
Old 07-18-2012, 08:34 PM   #10939
Guest021715
Account closed.
You'll love them. I heard the guy just sold out
If I'm not dead tired I'll take a dashcam vid tonight.
Old 07-18-2012, 08:54 PM   #10940
zhenkaaaM3
epoxy worked great on trunk handle. It stays still. I am too scared to pull on it though.
Eugene
Rate This Thread
