General Off-Topic
Closed Thread
Old 08-03-2012, 02:43 AM   #881
mkodama
mkodama's Avatar
Originally Posted by nikkeiS2K View Post
I am going to take over the Bay Area in one year. Get ready, b!tches.
One year?
Yeah, one year? why u no take over nao?
/asian parent
mkodama is offline
Old 08-03-2012, 02:49 AM   #882
325inthe510
My Ride: 152ci of madness
Do it fgt
http://www.calguns.net/calgunforum/s...d.php?t=603524
http://www.sigsauer.com/CatalogProdu...g556-swat.aspx
325inthe510 is offline
Old 08-03-2012, 02:53 AM   #883
v8 5
My Ride: 6 speed BMW
fake
Gutted with a Getrag
We have 4 websites within the family.
v8 5 is offline
Old 08-03-2012, 03:13 AM   #884
DJ RaMiN
My Ride: 02 325I,03 M3
ID:	463215   Click image for larger version
BMW driver complaining about $250? That's lunch!
Originally Posted by 323ci newbie View Post
Man, you all is best!
Here is my Facebook page, Like me maybe:
https://www.facebook.com/DJRaMiNUS
DJ RaMiN is offline
Old 08-03-2012, 03:42 AM   #885
mkodama
mkodama's Avatar
Successor to the carburetor, predecessor to mechanical fuel injection, Bosch K-Jetronic mechanical fuel injection system. When fitted with an engine driven fuel pump, can run without any electricity, and offered improvements in power, emissions, and mileage over a carburetor. Fitted to many sports cars that could afford the system, including Porsche, Ferrari, Mercedes-Benz, BMW, Audi, VW, Delorean, and others.
The downside, is that the system was entirely mechanical and relied on the precise dimension of many small parts, no debris or corrosion within the system, and the mechanical and chemical properties of all parts remaining the same. Designing something like this, is an entirely German engineering mindset, and is also horrible in terms of real life usage where parts will be exposed to unexpected temperatures, corrosion, and debris. Also, the system is immensely complex compared to electronic fuel injection, which in contrast only varies injector pulse duration to do the function of the many different devices.
This overly complex system is why my 190E doesn't run right. The KE-Jetronic of the 190E 2.3-16V differs from the video in a few ways, making it a few steps closer to EFI.
-Separate fuel pressure regulator with vacuum reference for system pressure(just like EFI).
-ECU controlled warmup valve which allows the ECU to adjust based on inputs from altitude sensors, coolant temperature sensors, and oxygen sensors, of which my 190E only has the coolant temperature sensor.
-ECU controlled idle control valve that eliminates the need for the auxiliary air valve (just like EFI).
-ECU controlled cold start valve, still with on-off function, eliminates thermo-time switch.
This system really makes me love how simple modern EFI is. When moving parts are kept to a minimum, reliability goes way up.
-Fuel injectors are the only fuel regulating devices.
-An electronic throttle body is the only air regulating device.
mkodama is offline
Old 08-03-2012, 03:45 AM   #886
albeee
My Ride: MKVII GTI
I wish Miles had a regulating device.
Originally Posted by VALMONT View Post
stancewerks is for dudes who pick up dudes for a little stretch and poke.
albeee is offline
Old 08-03-2012, 03:47 AM   #887
cyberkaa
My Ride: E46 332i,M3;E30 325i
Originally Posted by a s u r a 0 s 9 View Post
parents sold the house in norcal.... and planning to move to socal
That brings back memories. I remember when you moved there and you shared your backseat with me.
-Kalim
(klx photo studio)
cyberkaa is offline
Old 08-03-2012, 03:49 AM   #888
cyberkaa
Originally Posted by mtnbound View Post
lawlz....
"Miles, you look a bit different - did you get a haircut?"
And that's about as far as the inquiry would go. Because -____-
Waisis.
-Kalim
(klx photo studio)
cyberkaa is offline
Old 08-03-2012, 03:50 AM   #889
cyberkaa
-Kalim
(klx photo studio)
cyberkaa is offline
Old 08-03-2012, 03:51 AM   #890
mkodama
mkodama's Avatar
How about my hand regulating your face?
mkodama is offline
Old 08-03-2012, 03:52 AM   #891
albeee
My Ride: MKVII GTI
Too many moving parts.
albeee is offline
Old 08-03-2012, 03:52 AM   #892
cyberkaa
If only...
-Kalim
(klx photo studio)
cyberkaa is offline
Old 08-03-2012, 03:52 AM   #893
cyberkaa
How can she slap?
-Kalim
(klx photo studio)
cyberkaa is offline
Old 08-03-2012, 03:55 AM   #894
mkodama
mkodama's Avatar
It happens so fast and with such precision it won't even look like it's moving.
mkodama is offline
Old 08-03-2012, 03:55 AM   #895
mkodama
mkodama's Avatar
Hmm... Do want to change all my car's incandescent lighting to LED:
mkodama is offline
Old 08-03-2012, 03:56 AM   #896
albeee
My Ride: MKVII GTI
Knowing you, your hand would have appalling tolerances and would require a rebuild right after. It will also require too much energy, so not very efficient.
albeee is offline
Old 08-03-2012, 03:58 AM   #897
albeee
My Ride: MKVII GTI
Fix the CAR, not the ancillaries.
albeee is offline
Old 08-03-2012, 04:05 AM   #898
mkodama
mkodama's Avatar
Well, we'll find out this weekend.
mkodama is offline
Old 08-03-2012, 04:07 AM   #899
albeee
My Ride: MKVII GTI
You want to regulate my face this weekend? Flattering, but I have prior engagements.
albeee is offline
Old 08-03-2012, 04:07 AM   #900
mkodama
mkodama's Avatar
I bolted the water pump pulley, power steering pump, alternator, and belt tensioner back on the engine last weekend. Stuff gets done. I think the crank bolt is really all that's left to put on the engine.
I am somewhat unhappy with with some of the mismatched bolt colors though. I want to replace all the shiny blue zinc plated fasteners with the dull grey zinc coated allen fasteners.
mkodama is offline
Closed Thread
Rate This Thread
