Reinforced Subframe EPIC Failure - Page 7 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 33 votes, 5.00 average. Display Modes
Old 08-03-2012, 12:00 PM   #121
Bdave
My Ride: M3 HPF Stage 3
Originally Posted by ChrisRedmon View Post
Would you suggest getting a reinforcement kit? Or welding something serious in? Whats the average $ amount i can expect to dish out for a QUALITY job?
HPF kit is better than any other kit. get theirs.
Cost depends on a lot of things. Its a GOOD idea to replace ball joints and almost anything with wear as long as you have things apart. It a good time to install adjustable rear CAMBER arms if you have coil over suspension.
If you have NA power you can stay with the stock sub frame bushings although it is a good time to RENEW them while you have everything apart. Other choices are AKG RED or BLACK poly sub frame bushings. Never use Poweflex YELLOW poly subframe bushings. They have been shown to not FIT properly and tear. Consider AKG red poly RTABS depending on your needs.
Total cost is a rock bottom of 800usd to over 2k depending on options PLUS the price of the HPF plate kit.
I have heard of group pricing cheaper than this. It so much depends on what shops are available, what part of the country you live in and so on.
My cost was 2k with all new poly sub frame bushings,all new rear ball joints and lots of additional welding beyond the normal plate install...plus the price of the HPF plate kit. I already had RTABS and rear camber arms.
You want to inspect your GUIBO and front differential mount too!
Bdave is offline   Reply With Quote
Old 08-03-2012, 12:05 PM   #122
ChrisRedmon
My Ride: 2002 PY ///M3
The man. Thanks for that dude, project acquired!
2002 Phoenix Yellow E46 M3 l 6MT l Nappa l Nav l STG Coilovers 7k/8k l BMW Performance SSK l OEM ZCP's l Kirk Roll Bar l Motorsport Hardware l Besian Systems l CSL/GTR Carbon Fiber Hood, Trunk & Diffuser l Status Gruppe Sec. 3 l Custom Rear Brace l Rear Seat Delete l Coby Wheel Products
ChrisRedmon is offline   Reply With Quote
Old 08-03-2012, 12:09 PM   #123
E85head
My Ride: E46 M3
That is correct, but if you look at an installation-manual PDF for a reinforcement kit you will see what i mean can find some pics later. See also 02pruvs pictures and explanations on the last pages. Tey are very good
E85head is offline   Reply With Quote
Old 04-28-2014, 07:36 PM   #124
cosmos328Ci
My Ride: 398.5whp. 498.8ftlb
Originally Posted by Snik View Post
are these wicked floor tears only on boosted cars?
the stock stuff doesnt have enough torque to do that does it?
My stock E46 328Ci did. Cost 2k to fix.
M54B30, ESS TS2, Schrick Cams, S54 Cam Chain Tensioner, ATI Super Damper 6.8", 3.5" Throttle Body, XForce Headers, Custom Twin Exhaust, Quaife LSD 2.93:1, UUC Twin Plate and Lightened Flywheel, GSR Four-bolt Oil Pump, M56 Engine cover with Built-in CCV.
http://forum.e46fanatics.com/showthr...619&highlight=
cosmos328Ci is offline   Reply With Quote
Old 07-14-2014, 05:40 AM   #125
v8head
My Ride: e46
hello.
I drive a BMW 99, 323i. I've been lurking here occasionally . Iv been quite surprised how much you guys spend on reinforcement subframes .
Thought i will share with some photos from time i have done reinforcement.
Everything was done at garage, exept pressing in new bushings , and the price for all in total was 150$ .
The plates was not only from bottom of the car , but from inside as well(you can see the shape of the metal plate on one of the photos).
Sorry for my english, its my 3 language. .
ID:	565337   Click image for larger version
ID:	565338   Click image for larger version
ID:	565339   Click image for larger version
v8head is offline   Reply With Quote
Old 07-14-2014, 09:02 PM   #126
cosmos328Ci
Originally Posted by v8head View Post
hello.
Nice work.
Old 07-14-2014, 09:58 PM   #127
Rob43
My Ride: 03 331Ci 5spd R1200R
hello.
Good job.
The one thing I'd tell you to add would be the Long bolt through design. As you can see in these pictures, the subframe bolts come through into the trunk .
http://forum.e46fanatics.com/showpos...6&postcount=76
Good luck,
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 07-15-2014, 07:20 PM   #128
cosmos328Ci
Originally Posted by Rob43 View Post
Good job.
Good luck,
Rob43
That is some serious load distribution.
Old 07-22-2014, 01:53 PM   #129
10psie46
My Ride: e46 non m
Once the rear subframe is damaged I would get rid of the car. My e46 323i subframe cracked 3 different times. cost me a lot of money.
10psie46 is offline   Reply With Quote
Old 07-24-2014, 11:54 AM   #130
Bino5150
My Ride: 99 323i
I just dropped my exhaust the other day to do my clutch, and noticed that my rear diff bushing is pretty much completely gone, and the left rear subframe mounting point is torn pretty good... So here we go.
Bino5150 is offline   Reply With Quote
Old 07-24-2014, 12:30 PM   #131
Rob43
Take before & after pics.
Good luck,
Rob43
Old 07-24-2014, 12:58 PM   #132
Bino5150
My Ride: 99 323i
Good luck,
Rob43
Yeah, I will. I'm going to do the reinforcement kit and the cross brace, along with poly diff and subframe bushings as well.
Old 07-24-2014, 01:04 PM   #133
Rob43
Good.
When you say "cross brace", do you mean up in the trunk with a bolt-through design ?
Weld in or Mason Engineering ?
Rob43
Old 07-24-2014, 05:59 PM   #134
Bino5150
My Ride: 99 323i
Good.
Rob43
Weld in the trunk, like what 02PRUV posted earlier in this thread.
Old 09-30-2014, 06:43 PM   #135
Ed1000
My Ride: 04 m3
Originally Posted by 02PRUV View Post
I went through this years ago. Brace it right so it never happens again
Might want to check the underneath like the last pic too. It tears all round the towers underneath.
I did mine almost the same except I used 2x2 down threw the floor right to the subframe
Ed1000 is offline   Reply With Quote
Old 01-31-2015, 11:41 AM   #136
ShakotanRon
My Ride: 2000 323i
Bringing this back! Has anyone done anything substantial about the front mounts? My left front stud, has come loose, and im assuming it is either, from over torqueing or from fatigue, if it is from fatigue, I would bet that I would find indications, when I pull the subframe.
ShakotanRon is offline   Reply With Quote
Old 02-01-2015, 05:15 AM   #137
E85head
My Ride: E46 M3
Over torqueing would only snap the bolt.
Force takes the path of least resistance, and the subframe mounts are subjected to infinite many load changes through its life. When one point starts to go or one bushing starts to fail, load on the remaining points increase.
That it the way the cookie crumbles. Don't hope for the best. Just get in there and fix everything, and don't try do do a minimum.
Old 02-01-2015, 05:35 AM   #138
ShakotanRon
My Ride: 2000 323i
My stud, moves up and down and spins freely, it seems as though over torqueing could cause this, my rear has already been reinforced, with a bolt through design, that ties into the frame rails. Im asking if anyone has done anything similar to the rear, with the front mounts? Or is my only option, the reinforcment plates, sold by the various companies out there.
Old 02-01-2015, 06:20 AM   #139
E85head
My Ride: E46 M3
The stud itself has a collar on top. When you torque the nut, you press the bushing centre between the collar and nut. The bushing only rests firmly against the mounting point. To me your problem sounds like someone forgot to torque the nut when assembling. Leting the stud destroy the mounting point.
It is not easy to explanain in a forreign language, but you will see what I mean when you get there.
One advise: repair this now. Do not drive!
Old 02-01-2015, 06:24 AM   #140
E85head
My Ride: E46 M3
There are several ways to reinforce the front mounts. What was done to mine, was epoxy the sheetmetal from an identical subframe (perfect fit that has same flex. )
Remember: when reinforcing sheetmetal thicker does not necessarily mean stronger
