Old 07-29-2012, 03:24 AM   #41
jaymemaurice
Location: Anchorage Alaska or Kitchener, Ontario, Canada
My Ride: 01 330ci, 03 Passat
Cool boss. If I were you I'd clean that engine bay the best you can, while you can...
Rain Sensor Retrofit: Here
Coupe Headline Replacement: Here
jaymemaurice is offline   Reply With Quote
Old 07-29-2012, 04:13 AM   #42
MJLavelle
My Ride: 2001 BMW 330ci
I gotta agree with that. I would also try to do some of the smaller water hoses that dont often get replaced, like the hoses for the heater core, and maybe find a way to block off all but one of them, and do a pressure test to make sure they sealed tight. You don't want to have to go back in once the engine is in the way again. But it would be a shame to have such good access, and not do them.
It would also be a shame to miss the chance to clean up that engine bay really well.
I know that it is easy to give in to the "I want to get it done!" mindset, but taking the time to hit all of the little details would make you feel better than just an engine swap.
Of course, that is easier for me to say on this end of things!
Old 08-04-2012, 04:03 AM   #43
Trashcan
My Ride: 2002 330ci
Its done!
Trashcan is offline   Reply With Quote
Old 08-04-2012, 05:35 PM   #44
threetwentyfizzle
My Ride: '00 323i, 07 TL-S
Congratz on the swap!
threetwentyfizzle is offline   Reply With Quote
Old 08-05-2012, 04:13 AM   #45
MJLavelle
Originally Posted by Trashcan View Post
Its done!
Great! No leftover parts, I hope (except the old engine, of course).
Are you going to post any pics, maybe write up some lessons learned, and let us know if you followed any advice from anyone who posted.
Were there any surprises, good or bad? Anything you would have done differently? Any tools that made the job easier? Any tools that you wish you would have had?
Projects like this can help add to the collective knowledge of the site. Everyone experiences something a little different, or posts details that were left out of other write ups. So, I know you just want to get in and drive, but try to post some details while they are fresh in your mind.
I'm not trying to pressure you, but this kind of first hand info is somewhat rare, so it is good to write up as many details as possible, for the good of the forum.
Old 12-29-2012, 11:51 PM   #46
Trashcan
My Ride: 2002 330ci
Never saw this post until now.
Things that would have made it way better would be an lift. Lol. This isn't something that should be attempted without a well stocked shop to work in. I also wouldn't recommend this project for beginners. If you're not a good MacGyver and lack problem solving skills, again, this isn't something for you to attempt.
Removing the engine from the transmission wasn't to bad, but getting the new engine to fit into the transmission properly took a good 2 hours and some loud cursing .
We kept the old clutch, and i believe when i removed it the springs in the self adjusting mechanism needed to be reset. I'm not sure but i believe not resetting them was cause for a clutch failure about a month later. The clutch was good still but had to remove the transmission and reset the springs, and put in a new master (or slave? Idk) cylinder and a pivot bushing. The tool to reset the clutch is expensive but a hydraulic press on the fingers in the center of the clutch and a flat head to set the springs back did the job
I would highly recommend turning the engine over for a while without spark or fuel to build oil pressure before first start.
We put anti seize copper paste on all the exhaust nuts, which made for a very strong and scary smell initially, and under hard acceleration for about 2 weeks after.
The first start was smokey and stinky and very nerve racking and scary.
All in all, it was a very interesting learning experience that i never want to do again, lol.
Hope i could be of some help to someone!
Old 12-30-2012, 12:05 AM   #47
Trashcan
My Ride: 2002 330ci
Here's some more pictures as long as I'm reminiscing.
The last one is from when the clutch issue arose. I towed it to a shop i could use a hoist at, which made it a million times easier!
Sorry for all cell phone pictures...
ID:	483942   Click image for larger version
ID:	483943   Click image for larger version
ID:	483944   Click image for larger version
Old 05-03-2013, 02:22 PM   #48
2003silver330i
My Ride: 03 BMW 330i
Well done. I'm getting ready to do an engine swap as well in my very tight spaced garage. Do you recommend leaving the intake manifold off of the new engine when installing it back into the car?
2003silver330i is offline   Reply With Quote
Old 05-04-2013, 10:16 AM   #49
Trashcan
My Ride: 2002 330ci
Re: Engine swap help
If it's already off i would wait until you have the engine in and attached completely before putting it back on.
Make sure you read the part about the clutch in my last comment if it's a manual.
Good luck
Old 05-04-2013, 12:26 PM   #50
2003silver330i
Good luck
Unfortunately I own an automatic. I'm still trying to find good instructions how to detach that from the engine and what gear the tranny should be in, if it matters at all. Thanks.
Old 05-04-2013, 02:05 PM   #51
Trashcan
My Ride: 2002 330ci
I'd assume it would be best to have it in neutral, although I'm not completely sure. If you don't have one I'd highly recommend getting a Bentley service manual. I can check mine later and see if it notes anything for automatics.
Old 05-04-2013, 02:33 PM   #52
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
You will have to put it in neutral because you have to rotate the engine so you can get to the 3 bolts that attach the tranny torque converter to the flywheel.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 05-04-2013, 03:51 PM   #53
2003silver330i
What is the best way to rotate the engine?
Edit: Looking thru the Bentley has no mention of these 3 bolts only the 11 bolts that surround the bell housing.
Old 05-04-2013, 10:47 PM   #54
BMWCaptain
Only.supposed to rotate it clockwise. You will be facing the engine and using a hatchet wrench to rotate it clockwise.
BMWCaptainE46.com
