Old 08-05-2012, 10:11 PM   #1
farukh
My Ride: BMW 325i 2002
Is it worth to replace Vanos Seals?
Hey friends!
I have been thinking about this for some time now and just cannot make up my mind. The thing is, I have to replace my valve cover gasket very soon and I thought about replacing Vanos Seals... But is it really worth the hustle? I mean, there are so many things I can mess up while doing that lol the timing, the bolts... I have some mechanical experience and watched several DIYs on vanos seals... What do you guys think? Did anyone replace it? Any reasonable improvements? Please share your experience
farukh is offline   Reply With Quote
Old 08-05-2012, 10:18 PM   #2
bikeaddict
My Ride: e46 330ci
as far as i know, you dont have to mess with the timing at all on the e46 to do the vanos seals..i say go ahead and do it.
bikeaddict is offline   Reply With Quote
Old 08-05-2012, 10:25 PM   #3
MercForHire
Sh1tty Advisor
My Ride: 323Ci 5 Speed Black
it's not hard. do it
might feel no difference though
Oops! My Water Pump Broke Again .................... Coolant in a Bottle
Old 08-05-2012, 10:25 PM   #4
farukh
Really? Because I was watching one of the youtube DIYs and the guy was like "ok, carefully unscrew the bolts not to mess up the timing..." lol
Old 08-05-2012, 10:26 PM   #5
MercForHire
Sh1tty Advisor
read the guide on the offcial site. No youtube video needed
Old 08-05-2012, 10:26 PM   #6
farukh
Well, I always listened to my fellow E46fanatics and they never let me down... So I guess I'll do it!
Old 08-05-2012, 10:27 PM   #7
farukh
You mean the beijian one?
Old 08-05-2012, 10:27 PM   #8
MercForHire
Sh1tty Advisor
yes
hardest part is cutting the old seals out. I lost a couple of fingers doing that one
Old 08-05-2012, 10:29 PM   #9
farukh
yes
Ooooh.... But really, if thats the hardest part... lol Are you happy with the result? Improvement?
Old 08-05-2012, 10:31 PM   #10
MercForHire
Sh1tty Advisor
Not sure didn't notice much.
But the old seals were clearly plastic when they should be like rubber.
I fixed something I guess.
Old 08-05-2012, 10:34 PM   #11
jasonbimmer
My Ride: 2001 BMW 330xi
actually no. the vanos seals are two sets of seals. the rubber goes inside and the teflon hard seal goes outside.
OP, you wont even close to touch timing. dont worry about it.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 08-05-2012, 10:38 PM   #12
MercForHire
Sh1tty Advisor
yes then i guess nothing was fixed at all. i got scammed out of $70
i had the suspicion that someone is riding on million of dollars out of these seals...
Old 08-05-2012, 10:39 PM   #13
farukh
lmao that's what I am afraid of!
Old 08-05-2012, 10:39 PM   #14
djsilver
My Ride: '01 330Ci Vert
the Vanos seals in my wife's 330ci hadn't failed yet at 125k but I could definately hear them popping and jerking. The bejian kit was complete and well explained. The car doesn't drive noticeably different because it was still working when I took it apart, but it certainly is a lot quieter!
djsilver is offline   Reply With Quote
Old 08-05-2012, 10:43 PM   #15
jasonbimmer
idk what you are saying or being sarcastic cuz I dont like sarcasm.
either you didnt do the job properly or you received the wrong kit.
the dual vanos has four rubber orings and four teflon hard orings.
2009 Mazda RX-8 R3
2008 YAMAHA YZF-R6
Old 08-05-2012, 11:40 PM   #16
swaggerwagon
My Ride: 2005 330i
the timing is fixed by the bolts that are connected to the camshaft taking the vanos bolts out will not mess up the timing. replacing the vanos seals is a good idea just like changing the oil. seals dont last forever and should be changed out to improve overall longgevity of the engine
330i ZHP
3 Pedals FTW
BMW ADP student
Ebay headers | Long tube CAI | modbargains ///M pedal covers | SS clutch line | CDV removed | Turner camber arms | Meyle HD FCABs | uuc poly motor/trans mounts | Eurospec Muffler | Clutch masters Stage 2 with aluminum flywheel | Coilover kit | CSL front bumper | Z4m shifter
swaggerwagon is offline   Reply With Quote
Old 08-05-2012, 11:57 PM   #17
Marek555
My Ride: E46 328i
+1
For me also was hardest part cutting old seals without damaging vanos pistons. I reccomend get some small fishing hook and pull with it old lover seals off.
Marek555 is offline   Reply With Quote
Old 08-06-2012, 03:30 AM   #18
Solidjake
Mod
Solidjake's Avatar
My Ride: 2002 330i
OP, if you're in NYC and need help let me know. I did the seals about two weeks ago. No idea why the hell I waited so long...
Follow my cross country drive to Bimmerfest West 2013
http://forum.e46fanatics.com/showthread.php?t=987217
Pics from post 505 on!
Youtube - Electric Fan Swap/Aux Fan Removal - Projector Retrofit - E46 Bulb Guide
Old 08-06-2012, 03:32 AM   #19
farukh
Thanks man, but I am in Florida! How's your car now? You feel improvement?
Old 08-06-2012, 03:34 AM   #20
Solidjake
Mod
Solidjake's Avatar
My Ride: 2002 330i
Yup right away I noticed it. I'm about 400 miles in already.
Slight fuel economy improvement, quieter idle, rpm doesn't bounce back when you're in neutral press the gas hard and let go, definitely more power in the low rpm range. I swear, I don't even push the gas so hard and it can hit 100 like that. Really is worth doing. I'm a believer.
