Old 08-06-2012, 11:28 PM   #1
zhenkaaaM3
My Ride: Fst'r then your e46
Power Steering leak?
I replaced my pump. Install went smoothly. A few days later, it seems to be dripping from the line to the pump where it goes into the pump. I am referring to the line that goes to the pump that you need a semi-big wrench for (18mm or 19mm), not sure what size it is.
I believe I tightened it to death. Then, drove 45miles to another fanatics place to meet up with him. He says I just made a line of fluid about 10feet long. I see the line got loose. Luckily he had an adjustable wrench. So I tightened it, topped off the fluid and went on with my day. Now, seems to have gotten slightly loose. There are drops coming down from the lower line.
Is there supposed to be an o-ring, maybe a crush washer that goes on the line before it screws to the pump?
Eugene
Former E36 M3 Owner + E46s
zhenkaaaM3 is offline   Reply With Quote
Old 08-07-2012, 12:17 PM   #2
zhenkaaaM3
Tttt
Eugene
Old 08-07-2012, 12:21 PM   #3
nlav26
My Ride: 2001 330i
Make sure not to over tighten. Can cause stripped bolts
stahlgrau ~ tannin
nlav26 is offline   Reply With Quote
Old 08-07-2012, 01:05 PM   #4
zhenkaaaM3
Is there an o-ring that needs to be there?
Eugene
Old 08-07-2012, 01:31 PM   #5
Jaundiced Outlook
My Ride: has a tailgate
Yes, there's supposed to be an o-ring where the high pressure line bolts to the pump. You can probably pick one up at your local dealer's parts counter for a buck or two. Hopefully that's the only problem, and the line itself isn't messed up.
2001 325iT 5-Speed
Jaundiced Outlook is offline   Reply With Quote
Old 08-07-2012, 01:32 PM   #6
nlav26
My Ride: 2001 330i
yes sorry there should be an o ring there creating the seal
stahlgrau ~ tannin
Old 08-07-2012, 06:26 PM   #7
zhenkaaaM3
Would they sell at autozone?
Eugene
Old 08-18-2012, 09:09 PM   #8
swordsman11868
My Ride: 2003 325i
I seem to have developed a leak at the bottom of my power steering pump where the line goes in to the pump. But I'm not 100% sure that is the location of the leak.
OP, did you replace the O-ring that is in there? Was there an O-ring to replace?
Did that solve the problem?
My car has 117k miles and has recently developed this leak. I'm hoping that it's a simple fix.
TIA
-Dan
I'm just here to change the world.
BMW Wiki: http://www.bimmerfest.com/wiki/index.php
E46Fanatics inspiration Robolop: http://forum.e46fanatics.com/showthr...87566&page=101
2016 Beheadings in Saudi Arabia: 92.
swordsman11868 is offline   Reply With Quote
Old 08-18-2012, 09:10 PM   #9
Zell
Zell's Avatar
My Ride: so turbo wow
They have an "A/C O-ring Set," which contains tons of various-sized o-rings. It's really cheap and more than likely contains the right one in it. I found the right one for an obscure o-ring I needed for my washer pump.
Old 08-18-2012, 09:36 PM   #10
swordsman11868
My Ride: 2003 325i
Part # for O-ring -
Is #4 the O-ring on the fitting that attaches to the bottom of the PS pump?
If so it's part number: 64508390601
