Old 08-07-2012, 05:11 PM   #1
BimmerKid37
My Ride: 2004 325i
Passenger Window Problem
I have a 04 325i, I recently had my windows tinted professionally and now my passenger window is in bad shape. The service guy promised that it was a bad window bushing. It just seems like bad timing to me because no other window has any problem.
What happens- I roll the window down, it makes more of a popping sound a third of the way down and two thirds of the way down. When I roll it up, same thing happens as well and it sounds like something is resisting it. And once it is all the way up, it makes a snapping sound when it is all the way up because it is on the wrong side of the seal. If it is pushed gently it goes right up it to the correct spot.
My predicament is, does this sound like the company that did my windows fault, and demand they fix it, or is this a common problem, and can it be somewhat easily fixed?
Help is much appreciated.
Cheers
BimmerKid37 is offline   Reply With Quote
Old 08-07-2012, 05:27 PM   #2
jdstrickland
My Ride: '94 325iC & '00 323i
My crystal balls predict a new window regulator in your future. Put the window up and LEAVE it there, else it will be stuck down in the rain.
jdstrickland is online now   Reply With Quote
Old 08-07-2012, 05:28 PM   #3
jdstrickland
And...
No, the window tint has nothing to do with it.
Old 08-07-2012, 05:30 PM   #4
jgold47
My Ride: 2004 X5 3.0
Cheers
No, it sounds like your window regulator is broken, and unles they took out the window, they probably had nothing to do with it. They break all the time on e46's. Google window regulator zip tie fix and fix it temporpermanently(I made that word up), or replace the regulator. Some of our sponsors have them for as cheap as 50 bucks without a motor (which you dont need). It takes probably about an hour to fix (I just did both mine this weekend). I would just be VERY careful with your freshly tinted windows becuase the window does get moved around a lot during this fix...
Religion, Politics, and which oil is the best to use. Three things never to be discussed in polite company...
my about me link
http://forum.e46fanatics.com/showthread.php?t=791566
jgold47 is offline   Reply With Quote
Old 08-07-2012, 05:50 PM   #5
BimmerKid37
My Ride: 2004 325i
Thanks guys! I just watched BavAuto do a whole demo on how to do it. Looks pretty simple.
Old 08-07-2012, 07:00 PM   #6
bratliff
My Ride: 330i
It is. I've had to do two now. First my passenger side then, a month later, the driver side.
'02 330i
'97 318i
'95 325 Vert
'76 280z
bratliff is offline   Reply With Quote
Old 08-07-2012, 09:44 PM   #7
scottjoh
Modded ///Member
My Ride: '99 323i & '02 540i
It's easy as long at it fits! Bought an aftermarket regulator and tried to bolt the sucker in and one of the studs was about 1/4" off. I could not get it to fit and it was clear that I would need to doing some grinding to elongate one of the holes. Even though the BMW regulator will break again eventually buy OEM, at least it fits. It turned out my regulator wasn't bad so I reinstalled the original instead of modifying the door to fit the piece of crap aftermarket regulator.
scottjoh is offline   Reply With Quote
e46 325i, window, window problem, window regualtor
