Save yourself up to $200 and some headaches - Electric Fuel Pump PM - Page 10 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 268 votes, 4.97 average.
Old 07-23-2012, 08:35 PM   #181
jfoj
My Ride: 330CiC, M5, X5, E93
I do not think it is so much weather related as I have had just as many die in the dead of Winter as well.
The fuel cools the pump anyway, but it is more an issue of age, mileage does not factor in as much on the pumps, probably more running hours, but this is really hard to track or calculate.
If you are in stop and go traffic all day you may only go 10 miles in 1 hour, however, if your on the highway for 1 hour, you are likely to go 60 miles.
The pumps usually fail to start after the car is shut down, usually due to a brush/communicator problem.
Old 07-25-2012, 06:14 PM   #182
jfoj
One more reason to take my recommendations seriously!
http://forum.e46fanatics.com/showthread.php?t=934197
Old 08-01-2012, 11:31 AM   #183
CONTINOBSM
My Ride: bmw 330ci
Hey guys might be a stupid question, but I am aware that my fuel pump has a "soft failure" where the car will not turn on if I have under a 1/4 tank. The car is a 2001 330ci. I have not bothered to fix it as I just never let it get close to 1/4 tank. Call me stupid or whatever but I just dont have the money at the moment to fix it. I have just recently noticed a huge loss in power in my car like it is struggleing at lower rpm and no longer get that "kick" in power when i step on the gas. Feels like it has no "vtec" if it were a honda civic ( excuse my poor correlation)
My question is : does this have anything to do with the "soft fuel pump failure" or is is something entirely different. Please respond any advice you have THANK YOU
CONTINOBSM is offline   Reply With Quote
Old 08-01-2012, 11:36 AM   #184
jfoj
Replace your fuel pump now, it will cost you more when it leaves you stranded. Yes, soft fail pump can impact performance.
Old 08-01-2012, 01:47 PM   #185
CONTINOBSM
My Ride: bmw 330ci
Thanks, I have CAA so not too worried about it leaving me stranded, but any others on how exactly it would impact the performance and cause this "struggle" or "choke"/ loss in power?
much apprecciated!....
Old 08-01-2012, 03:51 PM   #186
cgrizzly888
My Ride: 00 328i
Send a message via AIM to cgrizzly888
I'm beginning to believe the 99/00 pumps were more robust. I have a 00 328i with 244k miles running on the original fuel pump.
cgrizzly888 is offline   Reply With Quote
Old 08-06-2012, 02:22 PM   #187
stapler12345
My Ride: Mineral White F30
i was parked on the street overnight. it wouldnt start so i thought it was the battery, starter, etc. had it towed to an indy ("free" towing covered under my insurance company) and turned out to be the fuel pump.
131.5k miles
2002 330i
$522.60 (parts, labor, taxes)
Originally Posted by Penguin Koolaid View Post
I've never heard of a woman wanting more than she actually deserved. Never.
stapler12345 is offline   Reply With Quote
Old 08-06-2012, 02:30 PM   #188
jfoj
Thanks for posting with your data, sorry you had to spend more than you needed.
Just another point of reference for everyone to consider.
Old 08-06-2012, 03:34 PM   #189
My Ride: Lexus
We're fighting the good fight, JFOJ.
Old 08-06-2012, 06:27 PM   #190
e4603
My Ride: #3 bus
Curious whether those have pump failures change their fuel filters regularly.
e4603 is offline   Reply With Quote
Old 08-06-2012, 06:36 PM   #191
jfoj
Probably not, however, I doubt it has much impact on pump lifespan.
The problem is the pump is running 100% of the time that car is running. Not really a mileage item, it is an run hour item. You sit in traffic at stop lights, stop and go traffic, you do not accumulate miles, however, you accumulate run time on the pump.
The pump is a DC brush type motor and the brushes and armature just wear out over time along with the motor shaft bushings. After about 6-7 years and 60-70k miles just as a point of reference if the car is a garage queen, you are likely on borrowed time.
There may be some truth to some of the earlier pumps maybe lasting longer?? Maybe there were more than one supplier??
But for $120 it is not worth it to me to be stranded and walking.
You can see just a few posts up what happens when you are not prepared for the pump to fail, $500+!!
Old 08-06-2012, 06:46 PM   #192
TrickTizzle
My Ride: 325i
130k fuel pump is still good.
Old 08-07-2012, 04:38 PM   #193
Tangent_
My Ride: '01 330i, '11 Z435i
189,000 miles and counting on the original fuel pump...
What would happen to me is a couple of lost hours as my wife picks up the trailer from her dad, picks up me and the car, and I replace the pump myself for considerably less than $500 in my garage. If I'd been replacing my pump on this 60,000 mile schedule I'd currently be on my 3rd pump and I'd be in the hole for at least $300 or so and more hours than I'd lose doing this as a repair...
http://forum.e46fanatics.com/signaturepics/sigpic70081_4.gif
Tangent_ is offline   Reply With Quote
Old 08-07-2012, 05:10 PM   #194
My Ride: Lexus
That isn't saying much. Even though your engine may be able to run, doesn't mean its supplying adequate volume and pressure. Same goes w/ the filter. Just a heads up
Old 08-07-2012, 06:35 PM   #195
jfoj
I keep stating it is not a mileage issue, more of a time issue depending on how the car is driven. If you make it to year 8 change your fuel pump.
Old 08-08-2012, 05:54 PM   #196
Tangent_
Mine is at 12 years from the 06/00 production date, 50% beyond that 8 year recomendation...
Old 08-08-2012, 06:08 PM   #197
My Ride: Lexus
Famous last words before the O NOES IM STUCK ON THE FREEWAY BRO WAT I DO? thread.
Can't cough up $105 to ensure the reliability and peak operating performance of your vehicle?
Old 08-08-2012, 06:22 PM   #198
jfoj
I think the '99 & '00 pumps may last a bit longer. But it cracks me up that a fuel pump is about 2 oil changes worth of coin and it leaves you stranded!!
I guess you are also the kind of person that does not replace your battery every 4 years either?
But are you the original owner and do you know if your pump is original?
I guess you are a gambler and do not care if you end up like - "O NOES IM STUCK ON THE FREEWAY BRO WAT I DO?"
Old 08-08-2012, 11:28 PM   #199
///MPR77
My Ride: 02 ///M3 Tri-Pedal
Don't be complacent, and brag; for your Fuel Pump is plotting at this very moment when it will decide to leave you stranded.
Old 08-09-2012, 03:13 PM   #200
stapler12345
i'm not sure whether this is psychological, but ever since i replaced the fuel pump, there is more "kick" when i press down on the gas pedal. not talking about the timing of the throttle, but the force of the acceleration...
Rate This Thread
