Old 08-08-2012, 01:34 PM   #1
triksterut
My Ride: 05 M3 Vert
AA Stage 2 Meth Injection - E46 Vert Trunk Install
Hey all,
Installing a Stage II upgrade in my E46 Vert - and while I was installing this I noticed that the meth kit comes mounted to a stock battery cover (for a non-vert). This obviously won't fit in my car so I'm looking to see if anyone has any pictures of what they have done? I was just going to get a piece of MDF and carpet it like a sub box; then just mount everything to that. Thoughts? Advice?
triksterut is offline   Reply With Quote
Old 08-08-2012, 02:09 PM   #2
m3816
My Ride: M3 e46
I am 99% sure it will fit fine. Have you test fit it? The coupe and the vert use the same battery and the meth tank sits over the battery so it should fit with no issues.
m3816 is offline   Reply With Quote
Old 08-08-2012, 02:42 PM   #3
Bdave
My Ride: M3 HPF Stage 3
Originally Posted by triksterut View Post
Hey all,
You can mount the tank really any way you like. But my AA installed meth tank was mounted right over the battery on the right side(passenger side) of the trunk. I sold the entire kit so I cant take a photo for you.
I am CERTAIN that AA has a photo of a vert trunk mounted meth tank somewhere in their files. Just email them.
Or do your own thing. There is no wrong way as long as you are happy and it is secure. Good luck!
Bdave is offline   Reply With Quote
Old 08-08-2012, 03:03 PM   #4
Viral@ActiveAutowerke
Past Site Sponsor
My Ride: E46 M3
Hey all,
With Convertibles we typically have the methanol system mounted on the right hand side of the trunk on instead of over the battery tray. If you would like some picture diagrams please feel free to E-Mail directly at Viral@activeautowerke.com and I will be more than glad to assist you with them.
You are absolutely correct Dave thank you for sharing
Viral@ActiveAutowerke is offline   Reply With Quote
Old 08-10-2012, 07:19 PM   #5
Shakxxx
My Ride: 05 AA g6 s2 m3 vert
This is where Bimmersport mounted my meth tank!!
They built me a custom mount an it works perfect. Click image for larger version
Ill take a better pic for you later!!!
Shakxxx is offline   Reply With Quote
Old 08-10-2012, 07:44 PM   #6
performancenut
My Ride: AA s/c 3 series
They built me a custom mount an it works perfect. Attachment 464384
To refill the tank, does it need removed or do you have top access?
"Sell the 323 and buy an M, it's not worth it"
performancenut is offline   Reply With Quote
Old 08-11-2012, 01:11 AM   #7
Shakxxx
You can fill the tank easily with a flexible funnel or i can unscrew a 13mm bolt and slide it out of its bracket.
Old 08-11-2012, 10:01 PM   #8
WALKD U
My Ride: Just Fast!
What meth are you guys running?
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
Old 08-11-2012, 10:45 PM   #9
Bdave
I used M1 from VP. Mixed it 50:50 with water.
BTW, 100% water or isopropyl alcohol plus 40% or so of water will do in a pinch(if using 60% iso. More water of course for 90% iso).
I stopped an filled up at a Walgreens once!
Not too long ago, AA used ISO alcohol only because their pumps at the time were not meth safe. Methyl Alcohol does work the best but an iso mix is just fine. Try to get a 50 percent alcohol /50% water mix. Everyone knows iso already HAS some water in it already. Just pay attention to the label.
Old 08-12-2012, 06:29 AM   #10
Shakxxx
I also use m1 mixed 50:50 with water
Old 09-03-2012, 10:12 AM   #11
Shakxxx
OP let's see some pics of your tank mounted!!!
Old 09-04-2012, 02:19 PM   #12
triksterut
My Ride: 05 M3 Vert
Hey guys,
Got it in there; we actually just took the stock convertible battery tray and managed to get everything bolted to it. Had to get rid of the angle bracket that the pump was mounted too though:
Still have to get it all buttoned up but progress is being made!
Old 09-17-2012, 05:14 PM   #13
DenaliXTC
My Ride: S/C M3, 745i, X5M
Send a message via AIM to DenaliXTC
if you take the tank off the tray itll fit in under the hood in the back left compartment if its an 03.5+ i believe. Its been done... search for Maximum PSI wes stage 2 AA install.
Active Autowerkes Gen 7 Stage 2 | Evosport | Vorsteiner | DPE | Supersprint | Rogue Eng.
Brembo 6pot 355/4pot 345 | Dinan 3.91 | HKS | HPF | Custom GTR | Radar Mirror | Leatherz | Beemer Evolution
LSB/Cinn M3 490 RWHP superflow dyno
2014 335 X-Drive M Performance OEM+
2011 X5 M White/Blk Vorsteiner
2007 M5 Dinan S3 5.8L Stroker+
DenaliXTC is offline   Reply With Quote
