Old 08-10-2012, 12:56 PM   #1
2003silver330i
My Ride: 03 BMW 330i
Low coolant light on and a/c blowing warm
First thing this morning the low coolant light came on and the air conditioner is blowing warm air out of the vents. Maybe a dumb question but are these two issues related?
2003silver330i is offline   Reply With Quote
Old 08-10-2012, 12:58 PM   #2
ngillan
My Ride: Is in a salvage yard
add coolant?
in for mango's response.....
'07 328i - Montego Blue
ngillan is offline   Reply With Quote
Old 08-10-2012, 01:02 PM   #3
RPAYNE46
My Ride: '00 328ci
check to make sure your belts are still on
RPAYNE46 is offline   Reply With Quote
Old 08-10-2012, 01:02 PM   #4
2003silver330i
I know it needs some coolant. I usually need to add a little each month.
Old 08-10-2012, 01:15 PM   #5
2003silver330i
Didn't think about that one but will definitely take a look.
Old 08-10-2012, 07:29 PM   #6
2003silver330i
Well all of the belts are there.
Old 08-10-2012, 08:00 PM   #7
jfoj
My Ride: 330CiC, M5, X5, E93
Check for a slow leak in the fan switch located in the lower radiator hose. If there is a wet spot on the underbelly cover under this switch, you need to replace the O-ring.
See my signature below for the O-ring part number and it is very easy to replace. No tools required, if the is cold, leave the expansion cap on and just pull the switch out by squeezing the small wings. The vacuum in the cooling system will keep it from leaking, you will only loose a very small amount of coolant.
