Old 08-10-2012, 09:12 PM   #1
Rabe
My Ride: 330ci 2001
coolant leak?
i am suspecting a leak because dipstick is reading low but no low coolant light. also when i put some more coolant in the next few days it will go back to reading low (dipstick) but i do not see any coolant on the ground or leakage anywhere around the car. is this a normal thing to lose a bit of coolant during the summer? also the amount of coolant that i add is a very small amount about a 3/4 of a cup.
Sent from my SGH-T989 using Bimmer App
Rabe is offline   Reply With Quote
Old 08-10-2012, 09:13 PM   #2
e46_TiAG
My Ride: 2000 328ci
Maybe your coolant tank cracked. That happened to me, and the thermostat was toast. But then again, my driveway was flooded with coolant :O
e46_TiAG is offline   Reply With Quote
Old 08-10-2012, 09:15 PM   #3
Rabe
My Ride: 330ci 2001
yea i see no sign of coolant on the floor, Idk maybe i'm its fine but i just want to be safe.
Old 08-10-2012, 09:58 PM   #4
jfoj
My Ride: 330CiC, M5, X5, E93
Check the sensor in the lower radiator hose, the O-rings leak all the time.
If there is any moisture under the switch onto of the belly pan, your O-ring needs to be replaced.
See my signature below for the O-ring part number.
