Old 08-16-2012, 11:40 PM   #21
TxZHP04
My Ride: ESS TS2+ ZHP
Originally Posted by 330Cole View Post
the vibrations in the car, or it is an audible difference?
I was referring to the audible difference but they will also transmit more vibration into the car. Vibration in the car is really only noticeable at idle, more so with the a/c running or if the car is idling rough such as if you have a vacuum leak or something. I had the idle on my car bumped up to 900 rpm to reduce the SC'er rumble at idle well before upgrading the mounts though so I don't really get much vibration at idle but the lower stock idle speed will probably lead to more vibration as indicated by vI6cious.
Old 08-17-2012, 12:55 AM   #22
Steven747
My Ride: 05 330ci
this makes sense, but in concern for my own build... what wakes the dead? what exhaust is after your headers?
well my catless headers with a stock exhaust and no name muffler and 1 resonator removed it sounds very very good not too loud but when you open up it hits all the perfect notes. when i added the cams it really opened up the growl at all speeds and yes its very very mean but i really like it.
im a teenager and i dont mind loud so i dont think i will have an issue with bw mm but the vibrations i bet could get on my nerves if i start driving more city
Old 08-17-2012, 07:36 AM   #23
330Cole
My Ride: 01' 330Ci
i am also under 20... i dont mind a loud exhaust but me + loud = cops doing this--->
  • KW V1
  • Meyle HD Diff & Subframe Bushings
  • Meyle RTAB & TMS RTAB Limiter kit
  • Lemforder ZHP HD Control Arms
  • Meyle HD FCAB
  • TMS Subframe Reinforcement kit
  • TMS Swaybars F/R & Adjustable Endlinks
  • 3.38 Open Diff
  • BMW Performance SSK
  • BB Gen 3 Headers
  • Eisenmann Race Exhaust
  • 3.5" Longtube CAI
  • 3.5" Conforti Eurosport Filter
  • Shark Injector
  • Stoptech Slotted Rotors
  • TMS SS Brakelines
  • ST Sport Pads
330Cole is offline   Reply With Quote
Old 08-17-2012, 09:10 AM   #24
JohnBlaze
My Ride: Black Sunshine
If you want to upgrade, but worry the vibes will be too much do the M3 MM.
The vibes though from the BW MM, at speed are actually kinda sexy. It just sounds and feels a bit more race like compared to OEM, but it's really not over the top unless you are sitting in stop and go with your AC on. Then it can be pretty annoying
05 ZHP w/Epic tuned s54, Euro headers&Sect.1, Dinan 3.91 and a lot of other things built by Road Race Technologies
JohnBlaze is offline   Reply With Quote
Old 08-17-2012, 01:11 PM   #25
Steven747
My Ride: 05 330ci
Yup bw mm for me
Old 09-03-2012, 12:47 PM   #26
Steven747
My Ride: 05 330ci
bump for no reason. i really want to get these engine mounts now
