Old 08-16-2012, 10:38 AM   #1
AndrewCross
My Ride: 2000 323Ci
Windshield cowl clips
I just replaced my windshield cowl, is there any way that I can make it absolutely certain that all of the clips are in all the way? Thanks in advance.
AndrewCross is offline   Reply With Quote
Old 08-16-2012, 11:12 AM   #2
NIVO
My Ride: 2004 330Ci ZHP
Send a message via AIM to NIVO
notice where they all are and press as hard as you can, make sure they are straight in too as they can bend and not go into their holes.
I had 2 that continuously kept popping up until i press down right on top of them.
www.E46Turbo330Ci.com
WARNING: This modification is known to the State of California to cause cancer and birth defects or other reproductive harm due to the extreme G forces once turbo kicks in. ~ Nivo
The rest of my signature is reserved for pointless modification bits like: Halos | window Tint | carbon fiber roundels | short shifter
NIVO is offline   Reply With Quote
Old 08-16-2012, 11:20 AM   #3
AndrewCross
My Ride: 2000 323Ci
So if they aren't all the way in, will I be able to see the difference in the position of the clips that are all the way in?
Old 08-16-2012, 11:30 AM   #4
NIVO
mine made a pop/click sound when they went in. except for the 2 that seemed like they were in but I had noticed the cowl raised up in those 2 points.
Old 08-16-2012, 12:00 PM   #5
AndrewCross
My Ride: 2000 323Ci
Ah, okay, thanks! If I upload some pictures, do you think you'll be able to verify if they're in all the way or not? thanks in advance.
Old 08-16-2012, 12:07 PM   #6
MojoJoe
My Ride: leaks fluids
From what I can remember from replacing mine, if they are not clipped in properly you will see that the soft lip of the cowl is not held snugly against the glass.
MojoJoe is offline   Reply With Quote
Old 08-16-2012, 01:16 PM   #7
jdstrickland
My Ride: '94 325iC & '00 323i
The little holders (clips) should float in the cowling so they can slide into the holes in the car. They snap into place, and the rubber will be raised off of the glass if they are not snapped in right.
Old 08-16-2012, 01:17 PM   #8
Drew@Swift Motorworks
Drew@Swift Motorworks's Avatar
My Ride: Scooty Puff Jr
exactly. there will be a gap between the cowl and the windshield
p1192285638-5
.::PM me your tech questions, I'm always happy to help!::.
Swift Motorworks
Drew Powers
p: (707)702-1775
e: drew@swiftmotorworks.com
www.SwiftMotorworks.com
Drew@Swift Motorworks is offline   Reply With Quote
Old 08-16-2012, 01:27 PM   #9
rowdy lee
My Ride: 2000 323ci
hammer
I aligned all mine first visually 100% and got them started...
I used a block of wood just on top of the clips/posts and gave a light rap with a hammer to seat them. Had to be careful of the glass...
I'd buy it in a heartbeat... if only I wasn't living on the moon!
rowdy lee is offline   Reply With Quote
Old 08-17-2012, 12:58 PM   #10
AndrewCross
My Ride: 2000 323Ci
Great, I don't have any gaps, so I guess I'm good! Thanks for all the help, everyone!
