#1 |
Burning fail cylinder 1,2,6
hi guys. i have this problem recently. when i start the car, it works loud during cold starting. i have searched in the internet. everyone say the spark plug and coil pack cause this problem. but i have changed all spark plugs and coil pack last year. what should i check else ? thanks
BMW For Life
#2 |
My Ride: '06 330CiC, '03 M5
Doubt you would have 3 bad coils at the same time, also high Voltage ignition problems usually happen under heavy load, not start up.
Suggest you check the first link below in my signature. I would consider replacing the DISA O-ring and check over all other rubber and plastic hoses, especially SAP vacuum hoses if your car has the SAP system.
Fuel pump failures - http://forum.e46fanatics.com/showthread.php?t=929501 Temp Info - http://forum.e46fanatics.com/showthread.php?t=964491 Hidden OBC Menu - Check Voltage, Temps, Fuel Level - http://forum.e46fanatics.com/showthread.php?t=239619 E46/E39 GM5 Door Lock Info - www.bmwgm5.com Lower hose fan switch O-ring - BMW #13621743299 |
#3 |
thanks friend im reading now. i hope so i can solve this problem its make me annoying really
BMW For Life
#4 |
so i have checked my hoses. but it seems no problem. i have diagnosed again my car today. diagonose gave that faults. i had 3 cylinders fail. now i have 4
BMW For Life
#5 |
i have removed intake manifold,spark plugs,ignition coils, etc, and install my headers. but i have still problem. i will make a video tomorrow or today, then you can understand better. my ses light not on.
BMW For Life
#6 |
i have diagnosed yo my car now. my car have in 6 cylindes misfire. my car had 1-2 cylinders misfires last week. in 1-2-3-6 cylinders misfires 3 days ago. now all cylinders misfires. im going to set out 2 days later. i must to solve this problem until tomorrow. urgently!!!!
BMW For Life
#7 |
The last time I had 6 cylinders misfire was when my CCV caused excessive oil to be sucked into my intake. Evidence of this can be seen on the plugs for oil fouling.
