///M3 Forum
Old 08-17-2012, 10:19 PM   #1
Aioros_M_class
My Ride: 04 M3
M3 e46 wont start
hello guys here is the thing when i was leaving to do some shores with my car when i was about to started it i heard a loud click in front of the engine, well since then i thought it might be the starter engine but it works very good, then i checked the fuses in the glovebox and the one in the engine bay but neither of this things that i checked seems to solves my problems, i dont know if the key is the problem because when the ignition is on the fuel pump works can you help me dealing with this problem
Aioros_M_class is offline   Reply With Quote
Old 08-17-2012, 10:25 PM   #2
llcoolj0n
My Ride: M3
Only a click? try tapping the key a few then try to start it. See if that works!
llcoolj0n is offline   Reply With Quote
Old 08-17-2012, 10:31 PM   #3
Aioros_M_class
My Ride: 04 M3
already did and nothing
Old 08-17-2012, 10:56 PM   #4
LSM3
My Ride: E46 ///M3
Put your interior light on and turn the key again. If it dims, then its your battery - get a new one.
___________________________________________
2006 CS M3 | ESS Tune : CSL SMG tune : Eisenmann Race : Eibach : Tekarbon
LSM3 is offline   Reply With Quote
Old 08-17-2012, 11:00 PM   #5
Aioros_M_class
My Ride: 04 M3
I already checked that the battery is brand new I bought it like a month ago and I also tested so the voltage is good, the fuel pump is also working, but when I put the key in the ignition position nothing happens the only thing I hear is the fuel pump working besides that nothing happens
Old 08-18-2012, 10:57 AM   #6
MachRc
E46Fanatic
MachRc's Avatar
My Ride: 2003 Technik S1 M3
my problem was a clutch sensor when there was no click or sign of the starter. Ive also one time one the m3 had a bad BST cable.
But narrow it down until you have the starter to replace.
"Player-haters turning bitch like they have vaginas ‘Cause we see them dollar signs and let the cash blind us.
Money'll brainwash you and leave your ass mindless..When snakes slither in the grass spineless.."
MachRc is offline   Reply With Quote
Old 08-22-2012, 04:15 PM   #7
Aioros_M_class
My Ride: 04 M3
ok guys here is the following things that i have done:
Fuel pump working
Battery is new
Fuses checked and working
starter motor working
the only two things left to test ews and the clutch switch
Old 08-22-2012, 10:36 PM   #8
$ilent ///M
My Ride: 03.5 M3 smg lsb
How did you verify the starter motor is good.
$ilent ///M is offline   Reply With Quote
Old 08-23-2012, 12:40 PM   #9
Aioros_M_class
My Ride: 04 M3
well I took out the starter motor and tested it with the battery
Old 08-23-2012, 09:36 PM   #10
MachRc
E46Fanatic
MachRc's Avatar
If its not the things you listed and the clutch switch was bypassed what else can it be? So strange. I never hear of the ews or immobilizer problems that meds these cars up.
Old 08-23-2012, 11:24 PM   #11
Aioros_M_class
My Ride: 04 M3
and what if i have problems with my key how do i know if my keys are giving me the problem there is a way of testing it, the battery in the key only works for the remote or for the chip inside the key im running out of options here
Old 08-23-2012, 11:36 PM   #12
$ilent ///M
is it a crank no start problem when you try to start do you here anything from the starter?
Old 08-23-2012, 11:47 PM   #13
Aioros_M_class
My Ride: 04 M3
the starter doesn't even engage the only thing i can hear is the fuel pump working nothing else, i dont know if the key maybe the problem because i only have one key
Old 08-23-2012, 11:56 PM   #14
$ilent ///M
did you check the fuses and relays behind the glove box
Old 08-24-2012, 12:00 AM   #15
Aioros_M_class
My Ride: 04 M3
yeap all of that has been checked battery, bst, fuses, relays, fuel pump, fuses close to the ecu, starter motor
Old 08-24-2012, 12:02 AM   #16
$ilent ///M
i heard a lot of the threads saying the ignition switch fails often
Old 08-24-2012, 12:08 AM   #17
Aioros_M_class
My Ride: 04 M3
i dont think is the ignition switch because when i put the key in ignition i can hear the fuel pump working
Old 08-24-2012, 09:34 AM   #18
$ilent ///M
have you tried checking signal/connections to the starter (voltage drop test)
Old 08-24-2012, 03:40 PM   #19
tmiked
My Ride: 04 M3
Its the starter.
They fail in one specific position. If you remove it, it will work.
tmiked is offline   Reply With Quote
Old 08-24-2012, 05:12 PM   #20
MaddHatter00
My Ride: 04 M3
Mine did the same thing. It would start in the morning, I would drive it to temp then it wouldn't start again till it cooled off. I replaced the starter and has been perfect ever since. Get a new starter. And problem should be solved.
MaddHatter00 is offline   Reply With Quote
m3 e46 wont start starter
