Old 08-18-2012, 01:28 PM   #1
John,s 330 xi
My Ride: 02 330xi
size in mm of special wrench for fan blade removal
have 02 bmw 330xi waterpump failed (150,000) not bad but need special wrench to hold pully to turn hexhead shaft on fan to get fan out of the way to pull out waterpump need mm size of special wrench .theres a kit at autozone that has different sizes but dont want to buy if size is not in the kit need size in mm,s ?
John,s 330 xi is offline   Reply With Quote
Old 08-18-2012, 01:30 PM   #2
jdstrickland
My Ride: '94 325iC & '00 323i
You can borrow the kit at Autozone, no need to buy it.
You have to hold the pulley in place while you turn the nut that holds the fan clutch, and fan, on. This nut is a reverse thread, to the rule of Lefty Loosey Righty Tighty is reverse. Turn this nut to the right to loosen it.
Old 08-18-2012, 01:36 PM   #3
yetieater
My Ride: '03 330i
Fan nut is 32mm
bulletproof one piece at a time
full listing of BMW Performance parts for the E46
yetieater is offline   Reply With Quote
Old 08-18-2012, 01:47 PM   #4
computerwhiz1
My Ride: 2000 323i Sedan
It is a 32mm nut, but you can also substitute a 1 and 1/4" if you can't find a 32mm where you live. Personally I just put the wrench on the nut and give it a good whack with a mallet to avoid having to use special tools. That technique has worked for me lots of times, but use it at your own risk and be careful not to smack the side of your expansion tank with the mallet. REVERSE threads btw.
computerwhiz1 is offline   Reply With Quote
Old 08-18-2012, 01:57 PM   #5
John,s 330 xi
My Ride: 02 330xi
got wrench on fan nut/shaft need size of special tool i measured 2 1/4 from edge of nuts on pully going to AZ to get then install pump just hope I can get belt serpitien on car the right way! got manual ,just doesn,t show good diagram.
