Old 08-18-2012, 11:11 PM   #1
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
Recommendation needed: BMW shop in north Atlanta
So my brake pad sensor lit up on the dash today. Pads and rotors are original, and my car has 126k. DIY is not an option so I need to find a BMW specialist. Any recommendations in the Atlanta area? Also, what should I expect to pay for new rotors, pads and break wear sensors?
Old 08-18-2012, 11:40 PM   #2
bschillberg710
My Ride: 2002 BMW 325i
Pads and rotors are original? I highly doubt that. Anyone who's done a disc brake job before could do it on our cars, no need for a specialist. It's pretty much universal.
bschillberg710 is offline   Reply With Quote
Old 08-18-2012, 11:44 PM   #3
JohnIBarr01
My Ride: ZHP 6MT, Mk.6, Jeep
This. 16mm wrench (bracket), 10mm allen key (IIRC, slides), needlenose pliers (sensor), c-clamp (spread the piston), 9mm wrench (bleeder valve), setscrew bit, and caliper grease. 30 minute DIY with new rotors.
Can't help in Atlanta, but in Knoxville there is 129 Euro and European Auto Garage. Both are great.
Pat Summitt Foundation | VWvortex | V2Lab | Twitter | Facebook
Originally Posted by TheGreenspanator
Let me guess: This doesn't happen in Germany
JohnIBarr01 is offline   Reply With Quote
Old 08-18-2012, 11:54 PM   #4
Gus330vrum
My Ride: 330ci
I just order all rotors/ pads
Bmaparts - $360 w %10 espece30 discount went to $334 + sensors. R/F
Will be doing it this week.
Maybe we can do the job together. I teach u & do mine same time. )
But I will also be doing brake fluid flush. Pm me.
Gus330vrum is offline   Reply With Quote
Old 08-19-2012, 07:58 AM   #5
jfoj
My Ride: 330CiC, M5, X5
http://www.buckhead-imports.com/
Ask to see Jamie's supercharged E39 M5!
Old 08-19-2012, 09:45 AM   #6
LeMansteve
Yes, all original. I am the 2nd owner and have full records from the original owner. When I bought the car at 45,540 miles, I did mostly highway miles up to this point.
Old 08-19-2012, 09:54 AM   #7
LeMansteve
Thanks! I came across these guys once before but somehow couldn't find their website when Google searching last night.
