Thread Tools Search this Thread Rating: Thread Rating: 11 votes, 3.91 average. Display Modes
Old 08-22-2012, 12:09 AM   #81
CSL323
My Ride: 330Ci
Originally Posted by Sweetness View Post
DICE has a program that talks to the iBus to keep it on. Be careful buying cheap products that don't have this sort of feature that communicates with the iBus, or it'll become an expensive paperweight
It was 40 dollars. Not much of an expense
CSL323 is offline   Reply With Quote
Old 08-22-2012, 12:21 AM   #82
wsmeyer
My Ride: 330CiC
I have actual paperweights that cost more than the Kracker
I'm not sure what he's trying to say. He starts off claiming that:
"(iBus)Shuts off electronics that are not part of the OE system"
In his second reply I think he's talking about devices going into sleep mode. Not real sure. I don't think he has a good grasp on what the Kracker is and what it does.
William.
wsmeyer is offline   Reply With Quote
Old 08-22-2012, 12:44 AM   #83
CSL323
My Ride: 330Ci
William.
I was very confused by his post also... I wouldn't imagine that IBUS could do that=
Old 08-22-2012, 12:56 AM   #84
nmcclana
My Ride: 2000 323i
On late model E46's like my 2006 Convertible the head unit plays MP3's so it seems logical that with a little tweaking the Kracker could transfer those files without decoding?
William.
It's fast enough to pull the data off an SD card, although the iBus isn't fast enough to move the file over. Personally, I just use a bluetooth bridge to play tunes from my cell phone.
nmcclana is offline   Reply With Quote
Old 08-22-2012, 03:06 AM   #85
jaymemaurice
Location: Anchorage Alaska or Kitchener, Ontario, Canada
My Ride: 01 330ci, 03 Passat
Can someone plug one of these into a scrap BMW, and smack the air bag sensor when the data logger is enabled!?
Rain Sensor Retrofit: Here
Coupe Headline Replacement: Here
jaymemaurice is offline   Reply With Quote
Old 08-22-2012, 05:36 AM   #86
JasonSmithed
My Ride: 00 323i
It would be nice to have remote/push start if possible
JasonSmithed is offline   Reply With Quote
Old 08-22-2012, 07:16 AM   #87
CSL323
My Ride: 330Ci
Update: today I ripped apart my trunk for yet again another attempt at cd changer emulation on my 2006 MKIV. It did not work as of yet.
On the other hand, I updated my firmware and kustomizer and was able to control functions in my vehicle for example fog lights, tail lamps and wheel controls. A huge leap from where I was before. I have noticed some bugs for example, if I test any lighting feature, my speakers will crank up louder. I attempted reading live bus data from kustomizer with a 100% success.
I haven't been able to use pa soft or nav coder with kracker yet (possibly because I've connected through the trunk.
Suggestions:
1. Work on the changer emulation for MKIV navs as soon as possible!!!
2. Have kustomizer tell you what mode you're currently in.
Old 08-22-2012, 10:25 AM   #88
nmcclana
My Ride: 2000 323i
@CSL - I'm adding more debugging on the next release, so we can see what's keeping the MKIV from picking up the CD changer. LED's will be handled in a separate process to improve notification.
As for navcoder, I use it all the time - just set your Kracker to diagnostic mode. When you open Navcoder, select the Com port the Kracker is on. I've used it from the ibus (trunk) and OBDC.
Old 08-22-2012, 04:19 PM   #89
bropane
My Ride: nothing yet
I got mine to work and I love it. I was up until 2 am playing with it in the garage. I can't wait to learn more about this. I would really like a keyless push start using my phone for authentication via bluetooth.
bropane is offline   Reply With Quote
Old 08-22-2012, 05:53 PM   #90
CSL323
My Ride: 330Ci
Would love to have this working by next week if possible! Getting tired of burning so many CDs and tearing apart my trunk everyday so I might wait it out 'till it's confirmed we have a relation between the Kracker and MKIV unit.
As for diagnostic mode, I tried booting up the Kracker with P6 held down, and after a small time of holding it, P6 and P5 (I think) light up blue. I would imagine that this means DIAGNOSTIC MODE but when I do a scan on my MKIV, it returns saying that every unit is unresponsive even with ignition on.
I'm using COM3 at the moment and have set them to that. On NAVCODER I found it strange how it would say sleep until I refreshed in which it'd say idle.
It was really satisfying being able to turn up my radio from the trunk though
Old 08-22-2012, 10:24 PM   #91
Sweetness
My Ride: '01 325i
I'm too black for the kracker.
Even though I'm 100% white
2001 325i ZCW, ZPP
Titansilber Metallic, Black Interior
The 160,000 mile, clean daily driver
Sweetness is offline   Reply With Quote
Old 08-23-2012, 12:39 AM   #92
nmcclana
My Ride: 2000 323i
Yeah, hold up until Status tab is ready. That way if the update doesn't get it working, I should have the info needed.
Old 08-23-2012, 12:56 AM   #93
CSL323
My Ride: 330Ci
Any estimated time on that?
Old 08-23-2012, 02:12 PM   #94
wsmeyer
My Ride: 330CiC
@CSL323 - I'm glad you got yours mostly working
I'm still playing around trying to get it all figured out. I think my codes are slightly different as I have a convertible. The trunkOpen command doesn't work at all, possibly something to do with the check to make sure the top is fully up or down, And the windowOpen or windowClose will only move the window half way and you have to send the command again to move the rest of the way.
Plus I need to figure out the commands for the top open / close.
Has anyone tried deciphering the live bus data? I can post some if needed.
William.
Old 08-23-2012, 04:53 PM   #95
CSL323
My Ride: 330Ci
William.
We'll eventually get it, hopefully! The kracker is a good device just, it'll be better when it does what it's designed to! Any way I could help to getting this update pushed out faster?
Old 08-23-2012, 05:54 PM   #96
jfoj
My Ride: 330CiC, M5, X5, E93
Question about MP3 support?
Some of the amps may have an Aux input in them in the trunk, is is possible to output MP3 from the unit to the Aux input in the trunk and control the unit via Bluetooth?
If the amp cannot support it, I assume you could run a wire from the trunk to the Aux input on the head unit?
Just tossing an idea up, not sure if this has been fully covered or considered?
Old 08-23-2012, 11:51 PM   #97
JasonSmithed
My Ride: 00 323i
This module along with the other propeller based modules have a lot of potential
Old 08-24-2012, 05:18 AM   #98
jfoj
So how close are you with remote unlocking? I can see a lot of these being sold pro actively and on the spot for people that have dead keyfobs and are locked out of the car with a broken drivers door lock linkage.
If you could pop the trunk on a lockout and connect to the iBus and use your laptop or phone to unlock the car, you will have a lot of sales!
Old 08-24-2012, 10:27 AM   #99
nmcclana
My Ride: 2000 323i
@CSL - I'm plugging away, I actually just figured out a bug in the RX/TX code,it's probably what's keeping the MKV from picking up the Kracker in Music mode.
Old 08-24-2012, 10:33 AM   #100
CSL323
My Ride: 330Ci
Great to hear! Can't wait to give it a go!
