#1 |
2001 330ci, odd shutting off issue
hey gang, so on my 01 330ci, 5 speed --- 205k on it, she runs great -- no mods etc, everything up to date - only thing I know is bad is the oil level sensor, anyway, on the way to work this morning, 4th gear, about 40 mph she shuts down -- dead, then starts right back up like nothing happened. happened twice more before I got to work. The clock does reset is the only odd thing. I have not had a chance to scan for codes.
thoughts? it sounds bad (control module of some sort) ideas? many thanks Geoff
2001 330ci ZSP 5 sp, 208k and counting!!!
fancy M3 steering wheeL, 19's, clear lens set stock otherwise ![]() |
#2 |
I would go and get the codes read. That sounds like the easiest way to troubleshoot this issue.
#3 |
Yea....no codes...only thing I can find is a little standing water in the battery box....
#4 |
Please tell me you cleaned it up?
#5 |
Well yea I'm going to but I don't think that would explain what happened. The terminals are tight and clean
#6 |
Well I had more than a little water in the battery box....I had gallons of water in the battery box...water was getting in through the tail light seals I put in...so fixed those drained it and cleaned it...and it has been fine!!!
#7 |
and you doubted me
#8 |
You figure the water was shorting out the battery somehow?
#9 |
Most likely the water would cause the battery to short or cause a power surge and for safety the car would shut off.
Kind of shooting in the dark but it sounds good....right?
#10 |
I had water in my battery area as well. Not sure if the problem started when I got my EE Led tails. Need to make sure it's not happening again.
