#41 |
aren't they sort of spotlighted in the Clint Eastwood film Gran Torino?
#42 | |
My Ride: '94 325iC & '00 323i
You do not have a brake wear sensor on each wheel. You should have two sensors on the left front and right rear wheels -- one is a Wheel Speed Sensor, the other is the Brake Wear Sensor -- and one sensor on the right front and left rear wheel -- these are both Wheel Speed Sensors. Your E46 is the same as all E46s. |
#43 |
#44 |
#45 | |
#46 |
Thank you all for your help and information, i just placed an order on bmapart, now just waiting for my parts to get here, oh by the way, is there a DIY for replacing the rear wear brake sensor? hard or easy? plug & play? here what i brought
TEXTAR - Brake Pads Rear MANN - Air Filter Pex - Brake Sensor - Rear Order Total: $ 56.13 |
#47 |
No rotors is a mistake on a couple of fronts.
Just watch wear sensor as you remove it from the old pad and it will teach you how the new one goes into the new pad. Very likely you'll break the old one coming out, but that will teach you how to correctly install the new one. |
#48 |
Stay stock my friends!
Stinger, you said that using the brakes lightly will help them last longer. I'd heard the opposite and have been driving using my brakes hard for years. My last set of pads went 60K in the front...rotors were only halfway between min and max thickness, and in the rear, pads were only halfway worn.
What I'd read was that if you use brakes lightly, that pad is on rotor longer, generates more heat and also maintains that heat. With a short, hard stab, you get more braking, and less time of pad on rotor so the rotor cools off much quicker. That said, I have a manual, so will brake hard, downshift, brake hard, downshift...when possible. This hard braking also minimizes the risk of getting deposits on rotors from pads sitting on them when they're hot. Anyway, that's what I'd read so mention it here. Won't say it's the truth, just that I believed it at the time, have been driving like that for a long time, and really hope it's the truth! Comment/knowledge anyone?
![]() This huge woman, like 400 pounds comes up to me and says, "Doug, I would rock your world." I replied, "but I need to breathe." The girl in my sig:http://forum.e46fanatics.com/showthr...highlight=dmax |
#49 |
#50 |
Few facts:
I drive like an old man most of the time. Meaning that all my mileage is x-country on highways. I use cruise control at the speed limit, don't get tickets, and watch the scenery go by. Saves gas and brakes. That said, times I do brake hard; enough to prevent deposits. (light changes to red. Guy in front stopping short.) When I checked, I measured my oem pads and extrapolated for total pad life. I was on schedule to have my original pads go 150,000 miles. I changed them only because I wanted a low dust pad. Note that brake pads are cheaper than engine wear from braking, so downshifting to slow is mainly for safety, not for economy. I love my manual for mountain driving. Keeps me at the speed limit rolling downhill without risking brake fade, and no wear on the pads either. |
#51 | |
Wears carbon fiber boxers
My Ride: 330Ci ZHP 6sp
Turning a rotor is about $15-$25 each, while a new pair of rotors can cost you $60 each. If you can afford it, do it, but if not, don't fret about getting them turned. Yeah it'll reduce the cooling efficiency, but we're talking something you're not going to notice unless you track it. A lot of things on street cars are "good enough," but these same things that are "good enough" are completely unacceptable for the track. When you're pushing your brakes really hard like that, you require good cooling efficiency. I can't think of a time in which I needed optimal cooling efficiency when braking on my car. Going down a steep grade I'll downshift, if I had to stop really really hard I'll just drive without using the brakes for a few minutes.
E46Fanatic's resident mathemagician
![]() Last edited by Zell; 08-23-2012 at 10:21 AM. |
#52 |
I don't know replace your brakes or sensors
#53 |
I can accept that you don't know!
#54 | |
I've found that turned rotors never are as true or have the same great surface as new rotors. I consider $60 a corner for new cheap, but if not for others you could mike the rotors and turn if really looking to economize. You do have to take into account that the rotor will wear more as your new pads age, and guard against going under spec for the life of the pads. My advice would still be, economize in other places, but stretch to put on new rotors. I'm very conservative where brakes are concerned. I still maintain that if BMW replaces rotors every time when doing warranty work, that says volumes. |
