Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 08-26-2012, 10:15 PM   #11741
tock172
My Ride: '12 135i DCT
Originally Posted by deadwood83 View Post
Their wheel cleaner is godly.
Ordered new windshield cowl, inner control arm ball joints, and a Valentine 1 and remote display.
Yesterday I pressure tested my tubing, fixed a boost leak, changed front diff fluid, and installed the new BPV.
We all know how "lifetime: the fluid is (it lasts right up to the point your driveline fails, hence lifetime).
I've now used both Sonax and the P21S gel and I think I prefer P21S. I feel like it has a greater cleansing effect.
And great choice on the V1. Where are you going to mount the concealed the display? I have a V1 in my car but no concealed display.
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT Dinan S2
Old 08-26-2012, 10:26 PM   #11742
JT_01
My Ride: 2004 BMW 325
My 325 sedan had huge water spots all over the passenger side. After some research I found out that vinegar removes the stains. I spent the day making my car smell like a pickle, but it was so worth it. The stains came right of. I then used scratch X to remove the water etching and that worked like a charm too! I used some meguiars carnauba wax plus and now it looks awesome.
JT_01 is offline   Reply With Quote
Old 08-26-2012, 10:48 PM   #11743
tock172
Scratch X 2.0 is amazing stuff.
Old 08-26-2012, 11:10 PM   #11744
VIKTR
My Ride: 2002 330ci
Fixed the drivers side window regulator using the zip tie method
VIKTR is offline   Reply With Quote
Old 08-26-2012, 11:12 PM   #11745
deadwood83
My Ride: has an iron lung
Send a message via MSN to deadwood83
Unsure. Might do a custom gauge gluster mount.
AA Stg2+ 325xiA? Are you stupid? Maybe a little.
I can program cars fo' freeee near Salt Lake City. PM for details.
deadwood83 is offline   Reply With Quote
Old 08-26-2012, 11:18 PM   #11746
tock172
Did this over a year ago. Still holding strong
Yeah I keep considering the idea of buying the display and control panel but I haven't decided to bite the bullet quite yet.
Old 08-26-2012, 11:50 PM   #11747
VIKTR
My Ride: 2002 330ci
Good to know, I figure I can put the money saved into preventive maintenance under the hood
Not sure if I want to start with the cooling system or engine seals, gaskets.
Old 08-26-2012, 11:56 PM   #11748
Kracingti
My Ride: E46 320i Touring 02
Just replace my noisy school bus fan clutch it is engaged all the time. I got a brand new BERU Germany Fan and guess what... it still engaged all the time
Any idea of what is happening???:
Kracingti is offline   Reply With Quote
Old 08-27-2012, 12:26 AM   #11749
tock172
Cooling system is my suggestion. The slow oil leaks from the OFHG and VCG can be kept in check by adding oil when needed but the cooling system has the ability to leave you stranded (possibly with a permanently damaged engine) with absolutely no warning.
Old 08-27-2012, 12:35 AM   #11750
VIKTR
My Ride: 2002 330ci
That's true
Now to decide whether I should do a complete overhaul or just start with hoses and belts and see where that takes me.
Old 08-27-2012, 01:06 AM   #11751
///MPR77
My Ride: 02 ///M3 Tri-Ped
+1 tensioners, and pulleys while you're at it.
Old 08-27-2012, 10:58 AM   #11752
tock172
That's true
What's your current mileage? My suggestion is to go the full overhaul route. The system is only as strong as its weakest component. My car will be due for its second cooling system overhaul in about 4,500 miles. The first one experienced a partial failure at 68k and the entire system was replaced minus the radiator. This time, the rad is being replaced too.
Yes, make sure you cover all bases. I've had all these replaced on my car as well.
Old 08-27-2012, 11:11 AM   #11753
VIKTR
My Ride: 2002 330ci
Just hit 113k miles
What was the partial failure you experienced?
Old 08-27-2012, 11:18 AM   #11754
tock172
Just hit 113k miles
Water pump pulley supposedly sheared off, engine began to heat up and was immediately shut off. Then when being repaired the expansion tank was found to be compromised as well.
Old 08-27-2012, 11:27 AM   #11755
VIKTR
My Ride: 2002 330ci
Ah I see... I think my reasoning before this forum was that if I encountered any issues with the cooling system I would simply shut the car off and tow it home... then fix whatever was wrong. I had luck doing that with my last car (96 e320) and despite spending every other weekend under the hood of that thing, I only had one issue with the cooling system (a burst hose and plastic adapter). I ended up retrofitting the cheap plastic parts between the hoses with brass fittings from home depot
But going off of what I've seen on the forum the e46 seems to be much more temperamental so I'd much rather invest 750 to protect the engine than spend who knows how much on a new car
Old 08-27-2012, 11:33 AM   #11756
tock172
Good attitude! Where are you located in SD? Let me know if you ever want your codes pulled or any other type of help.
Old 08-27-2012, 11:43 AM   #11757
VIKTR
My Ride: 2002 330ci
Spring Valley
Thanks, I haven't had any codes pop up yet but I still scan regularly. I'm sure there are quite a few things I'd need assistance with though
I want to disable the automatic door lock feature. I had found a few threads explaining how to do this with the key, but it only worked temporarily.
Old 08-27-2012, 11:56 AM   #11758
tock172
Spring Valley
Yup I can disable that for you.
Old 08-27-2012, 11:57 AM   #11759
VIKTR
My Ride: 2002 330ci
You have a programming tool?
That would be awesome
Old 08-27-2012, 12:01 PM   #11760
tock172
Yes!
Rate This Thread
