Old 08-29-2012, 07:46 PM   #41
gpeterson
My Ride: 98 M3/4/5
Originally Posted by serdar255 View Post
Can you send me a link to the board you used or something you recommend?
http://e36-electronic.com/
gpeterson is offline   Reply With Quote
Old 08-29-2012, 09:52 PM   #42
serdar255
My Ride: '01 325ci / '90 325i
Originally Posted by gpeterson View Post
thanks, but i meant to reply to op, sorry.
For coding, custom shift knobs, and vinyl stickers: PM me
serdar255 is offline   Reply With Quote
Old 09-08-2012, 01:53 PM   #43
RomoGuy
My Ride: 98 M3, 01 330ci
Hey guys, E36 have a different output than e46, I sell simulators for both. I have tested on 3 different e46 with success.. work on e46 up to 03.. Email me for more info RomoGuy@aol.com selling the e46 Units for $90 shipped through paypal.
ID:	468152   Click image for larger version
RomoGuy is offline   Reply With Quote
Old 09-10-2012, 12:32 AM   #44
eneka
My Ride: 2003 325i
does this also work for the sulev m56?
eneka is offline   Reply With Quote
Old 09-10-2012, 08:13 AM   #45
RomoGuy
Yes, It should with no problem, keep in mind, within 14 days, I will issue refund if you have any issues.
Old 09-10-2012, 09:08 AM   #46
Drewfus2101
My Ride: N/A
The PCB came from Radioshack too. I'm pretty sure that all the parts came from there.
Drewfus2101 is offline   Reply With Quote
Old 02-21-2013, 10:43 PM   #47
jbielefeld
My Ride: 2003,325i
Drewfus2101,
I created your design with some changes.
I used a DPDT relay I had in my junk box.
As an Electrical Engineer who used lots of 7805 voltage regulators in noisy environments it would be a good idea to use a 1uF filter cap at the input to the voltage regulator and a 0.1uF filter cap at the output. The 7805 are prone to oscillation when using long wires at the output. You can actually use a 78xx as an audio amplifier to drive a speaker! Just put your iPod to the regulated pin and a speaker to the output pin and you can get great fidelity audio. In the lab we used 7812 and got 8 watts RMS of audio power.
You do not need a potentiometer/trimmer just use a voltage divider using a 22ohm resistor and a 560ohm resistor and power both DME pins on the relay.
I get 0.196V which is close enough to 0.20V.
Now a question to all of you. I have an M56 SULEV engine so there is a secondary air - air mass meter. How do I deal with this????? Anyone figured this one?
jbielefeld is offline   Reply With Quote
Old 02-22-2013, 12:04 AM   #48
gpeterson
My Ride: 98 M3/4/5
Originally Posted by jbielefeld View Post
Drewfus2101,
Agreed... the sims I sell have filtering caps and use a fixed voltage divider instead of pots.
As for the M56 - I've looked into building sims for cars with a SAP MAF but don't have one to test on. Many newer cars use wideband O2s as well and those will be more work to build a sim for.
Old 02-22-2013, 06:27 PM   #49
jbielefeld
My Ride: 2003,325i
M56 Sim....
Drewfus2101,
I measured the Secondary Air - Mass Air Meter output using a shop vac to simulate the moving air. This a crude test. The secondary Mass Air meter w/o air flow had 60mV output. When the shop vac was pushing air through I got 3V output.
So, for now I made a voltage divider at the plug to keep the voltage at 2.5V.
The power pin supplied 5V so I used two 10k resistors tied together. One end going to the ground pin one end to 5V pin and the signal pin went to the junction of the voltage divider. Right now I still get the P1418 code with the sim alone. P1418 is Secondary Air Hose Clamped. I am assuming the air mass meter thinks there is no air flow so it thinks the air hose is blocked ( manifold valve closed).
The O2 sensors are the 5 wire type.
Combined Narrow Band and Pump Cells (5-wire).
Red wire = Ip
Yel wire = Vs/Ip
Blk wire = Vs
Wht wire = Heater-
Gry wire = Heater+
(All on the O2 sensor side of the plug.)
The formula for the O2 sensor is:
Vs = (RT/4F)*In(pO2atm/pO2test)
so the voltage range for the sensor is 0.9V for low oxygen and 0.1V for high oxygen. Wow, this is non-linear. The most linear part of the range is between 0.7V and 0.2V
Stoich is close to 0.45V (mid-range) so 0.2V is on the Oxygen rich side.
Sorry for the rambling but, just trying to get a grip on this as I write....
Old 02-23-2013, 04:27 PM   #50
jbielefeld
My Ride: 2003,325i
Drewfus2101,
Day one, no P1418 with the air mass meeter circuit.
Old 02-23-2013, 10:05 PM   #51
rkneeshaw
My Ride: 330i ZHP
jbielefeld, to clarify, you still need to sim the O2's AND the SAP MAF? Or have you tried just doing a SIM for the SAP MAF and see if that alone is good enough to prevent an error code?
2003 BMW 330i ZHP
ESS Twin Screw Stage 2 - Wavetrac - Headers - Magnaflow - BMW Performance
Turner Motorsports - Powerflex - StopTech
Build thread: http://forum.e46fanatics.com/showthread.php?t=696662
Wheelwell: 2003 BMW 3 Series
Fuelly: 2003 BMW 330i
rkneeshaw is offline   Reply With Quote
Old 02-24-2013, 03:50 PM   #52
jbielefeld
My Ride: 2003,325i
Sim on m56 engine
For the M56 SULEV: I built/installed the sim and also fool the SAP MAF. So far still no P1418 code.
So, I needed to do both on the M56 1. Add the sim as per Drewfus2101 and 2. Add the voltage divider to the MAF connector.
O--10k--- - GND pin
O--10k--- - 5V pin
O-------- - Sig pin (2.5V)
Old 05-07-2013, 07:09 AM   #53
ams07r
My Ride: E46 325Ci
Subscribed, this is an excellent writeup.
ams07r is offline   Reply With Quote
Old 08-04-2014, 08:45 AM   #54
moiz21
My Ride: 1999 323i 5-SPD
Sorry to revive an old thread. But after looking into this and finally learning enough to attempt this myself, turns out Radioshack no longer stocks that specific relay. Does anyone on here know of an alternative? And can be specific enough that someone with no electrical background knowledge can understand? Or know of anyone who still makes these and can point me in the right direction? Everyone I've reached out to, hasn't responded as of yet or just doesn't do it anymore. Thanks in advance.
MODS
P46 Projectors + FX-R Retrofit + 6k D2S / 60 LED AE's / Smoked LED Tails / Smoked Turn and Side Markers / BSW 10" Sub /ZHP Knob / Matte Black Grills / DICE / Parrot + Connects2 / OEM Alternative Alarm Mod / Clutch Switch Delay Mod / M3 Rep Front Bumper / 3M Black CF Di-Noc Wrap / K&N Intake / 35% Tint All Around / Black Short Eurotray / 545i Shifter
moiz21 is offline   Reply With Quote
Old 08-04-2014, 09:24 AM   #55
serdar255
IF you end up doing this could you take photos of the front and back of the circuit? I've been meaning to do this, but laziness got the best of me.
