///M3 Forum
Thread Tools Search this Thread Rating: Thread Rating: 4 votes, 4.75 average. Display Modes
Old 08-29-2012, 09:51 AM   #1
roadtrip1098
My Ride: 06 STi
SMG Tips and Tricks
If you need troubleshooting, go here.
This thread is only for tips and tricks to activate features of the SMGII transmission. If you have more to add, by all means go ahead. Please try to keep the same type of formatting as below. I know a few other tricks that I will add over time, but this is a start.
Disclaimer: All information on this thread is publicly sourced and is not guaranteed or to be held liable in any way. In other words, if you break your sh** it isn't our fault.
Soft Reset: Confirmed: Travel at 40+ MPH, move the selector lever to "N", pull back on both paddles for 8-10 seconds, move the selector lever back to "D".
Winter Mode: Confirmed: Put car in "D", Traction control "On", Sports Mode "Off", Drive Logic at level 1.
Warning: This will cause premature clutch wear as the car attempts to start off in 2nd gear.
Hill Hold: Confirmed: While on a hill and in "S" mode, pull back and hold the "-" paddle until RPM's elevate. This will partially engage the clutch and hold you on the hill.
Warning: Again, pre-mature clutch wear. If you're not moving within 1-2 seconds of using this, you shouldn't be using it.
Emergency Acceleration Mode: Confirmed: "D" Mode "A" on some models. This is just a special mode BMW put in as a "safety feature" Basically just mat the gas. Traction control and clutch engagement will operate in such a way that the vehicle accelerates at its optimum ability for the given conditions.
roadtrip1098 is offline   Reply With Quote
Old 08-29-2012, 11:40 PM   #2
Westrace
My Ride: 06 G35, 04 M3 Coupe
Are you sure this will cause premature clutch wear?
Westrace is offline   Reply With Quote
Old 08-30-2012, 05:36 AM   #3
roadtrip1098
My Ride: 06 STi
Yes. The car starts off in second gear and has a longer engagement time to keep the wheels from slipping. It would be the same result as if you drove any manual car and slipped 2nd every time you took off. Unfortunately this will cause premature wearing of the clutch - mind you it's not drastic, but it does exist. In my honest opinion, the benefits of Winter Mode are worth it.
Old 08-30-2012, 07:18 AM   #4
rcsummers
My Ride: M3
Winter mode is great. But its only needed if you get caught out when its snowing. I've only had to ever use it once.
"RICH"
My Build Thread
EURO.TECHNIKS
- Status Gruppe Tuning - Broadway Static - Recaro - DTM Fiberwerkz - AutoCouture Motoring -
Instagram: @summers_e46_m3
Twitter: @rcsummers0506
Xbox One: MisterMeisterM3
rcsummers is offline   Reply With Quote
Old 09-26-2012, 09:21 AM   #5
tehcbass
My Ride: bmw e46 323i
i think its usefull, i dont need to use it since im in miami though
Long Nights and Sandy Beaches
tehcbass is offline   Reply With Quote
Old 12-17-2012, 06:04 PM   #6
///mteknikk
My Ride: 02 E46 M3
launch control: turn off traction control, put car in manual mode, sport on, smg in mode 6, hold shifter in the "-" position and hold accelerator down, rpms jump and fluctuate from 1500-2000 rpm. let go of shifter and car launches
///mteknikk is offline   Reply With Quote
Old 12-17-2012, 08:13 PM   #7
scca_ziptie
My Ride: 2006 M3 SMG Comp pkg
Really only needs to be for 5 seconds max.
It will deactivate/disengage this feature automatically after approx 4 seconds if the car doesn't move.
Both are definitely cool tips though, use them both quite often - so far no issues have arisen with the clutch (80k and going strong)
"! First rule of Italian driving, that which is in your mirror is not important !"
scca_ziptie is offline   Reply With Quote
Old 12-18-2012, 05:50 AM   #8
roadtrip1098
My Ride: 06 STi
I say 8-10 seconds because normally people are freaking out and count too fast but you are 100% correct on both accounts.
Old 12-18-2012, 02:27 PM   #9
Firstboost
My Ride: 2006 Tiag ZCP
Honestly, unless I'm losing it, you don't even have to be at 40+ MPH. I prefer to do my soft resets coasting to a stop that way it can start all over again reengaging the clutch in 1st instead of finding a gear at a given MPH.
In regards to the Uphill Assist,, or "hill hold" as you've called it.. You can easily tap the paddle again to disengage if you don't intend on moving within 1-2 seconds. It's nice for me because I have a right turn on red on my way to work and sometimes I can use it, others I have to disengage because someone will be flying down the street when I think I have an opening.
Firstboost is offline   Reply With Quote
Old 12-18-2012, 10:38 PM   #10
NICKBRUM
My Ride: 2004 M3
Sport mode on or off will not affect LC.
Current:
2006 E46 M3 ZCP silver gray on black SMG
|Stoptech BBK ST40 X 355mm| Style 219 wheels|
|Ceramic coated euro headers| Custom 200 cell section 1|
|TTFS Motor & SMG tune, 315 whp| GC coil overs |
Previous: Totaled
|Carbon Fiber Intake|AA GEN3|AC Strut Brace|Eibach/Koni's|CSL/SMG Flash|
|Victory UDP's|HPF Sub Frame Plates| PF Subframe Bushings|Rtab Limiters|PFC DD Front Rotors|
NICKBRUM is offline   Reply With Quote
Old 12-18-2012, 10:49 PM   #11
m3e46freak
My Ride: m Twee lol
What is this... last emergency acceleration? D or A mode?
Rock Hard Abs Racing
ST Coil!
BREMBO
Apex!
Agency Power Headers!
Euro Cats!
Scorza Mufflers!
FRANK!! 311RWHP-260Torque
m3e46freak@yahoo.com for outside contacting
ebay/craigslist verified 100% FEEDBACK
m3forum 96% FEEDBACK
m3post/e46fanantics Great FEEDBACK
zpost/bimmerforum Great FEEDBACK
m3e46freak is offline   Reply With Quote
Old 12-18-2012, 11:00 PM   #12
ANREC330
My Ride: C6 Vette & M3
I wish I would have known this last Saturday when I was in San Francisco. I had to constantly hold the brake and give it gas at the same time, just so I wouldn't hit the car behind me.
ANREC330 is offline   Reply With Quote
launch, modes, reset, smg, smgii
