Australia
Check out other E46Fanatics members rides in the Enthusist Directory! If you don't have your garage setup, sign up today HERE |
#1 |
E46 M3 in carsales
Really cheap and looks clean.
Anybody knows this car? http://www.carsales.com.au/private/d...ort=LastUpdate Erik |
#2 |
That is fcuken cheap. I'd look at it for sure, and i'd definitely get a reputable place to do a PPI. Sounds too good to be true.
___________________________________________
![]() 2006 CS M3 | ESS Tune : CSL SMG tune : Eisenmann Race : Eibach : Tekarbon |
#3 |
Damn that's cheap. I would check it out and get a PPI though. Good luck
#4 |
I noticed this afternoon doing my own search that there are quite a few M3s in the sub 40k segment now, I think that's too cheap. The E36 M3s keep their value very well, pristine examples are still sitting around the late 20s to early 30ks. Quite incredible actually.
![]() '04 325Ci + MYSTIC BLUE + EISENMANN RACE EXHAUST & MID-PIPE |
#5 |
Also weren't those wheels on the earlier E46 M3s? I thought 03+ got 19" standard. Would like some insight into that please somebody!
#6 |
My Ride: 325Ci ClubSport
seems legit
#7 | |
Asking and getting are two different things. BobZ
"Little knowledge is Very Dangerous"
#8 |
I will try to call him tomorrow and get bmw autowerkers for PPI. Curious why he can't just give it to dealer for that price :S
#9 |
Because dealer offered him 30K
BobZ
#10 |
If something seems to good to be true, it usually is. If the car has been hanging around for a long time, then there's a reason why it hasn't sold yet. Even still, definitely worth checking out cos it is cheap! Good luck!
![]() Evolve CSL airbox w/Alpha-N tune | KW v2 | Vorshlag Camber Plates | Rogue Engineering RSMs | BBS LM 19x9.5 19x11 | Dixis Ti exhaust | EAS Aurora 60 LED AEs |
#11 |
Serious?
Anyway I just noticed... it doesn't have sunroof and it has cloth seats |
#12 | |
BobZ
#13 |
"No engine bay oil leakage found at time of inspection****
Engine runs and sounds good also showing no internal running faults**** Engine oil is discoloured, recommend servicing**** Drive belts cracked/worn - replace**** Check engine warning light is illuminated, needs service/repair - consistent with fault in engine management system****" "Some wear visible at suspension and bushes etc but consistent for age and kilometers - monitor and replace as required**** Slight freeplay at tie rod monitor/service as required**** Brake disc rotors have wear lips, and will need machining or replacing at next brake service or at RWC check**** Tyres showing greater shoulder wear and will need replacing as listed above recommend check wheel alignment when fitting new tyres**** Minor kerb scrapes/damage to wheels****" "This car performs reasonable for age and km showing mostly consistent wear and audible wear for age/mileage**** Interior showing wear and tear - consistent with mileage**** Window washers inoperative - check water level**** Sequential M Gearbox Drivelogic Check light on dash, traction control inoperative on road test - Requires electronic diagnostic/service to further assess condition prior to purchase**** Knock evident from rear driveline/suspension on road test - requires further workshop assessment/repairs****" "Vehicle has had panel and paint repairs to various panels**** Minor chips/sandblasting to windscreen**** Minor dents/chips/scratches to various panels**** Minor scuff marks at bumpers and side panels**** Minor stone chips to paint work on panels****" kthxbye |
#14 |
Pretty sure i saw this on graysonline a few months ago sold for around 30-35 either way still cheap remember the seats and the number plates well that's if am right.
![]() '06 6s MT E87 BMW 120i M-Sport Sparkling graphite metallic' |
#15 |
Try the mobile number. Beware there are many many MANY fakes on Carsales. I experienced at least 3 a week when searching for my car. Speaking to the owner at least gets you past that stage.
#16 |
Add says it's just been serviced but the PPI says different..?
430HP | 550Nm | 6SPD
#17 |
#18 |
#19 |
VIN checks out and it really is a 2006 M3. Surprised to see it with 18s and cloth seats though.
#20 |
Probably had hectic rims before it was in the accident and he wanted to source everything cheaply?
