#1 |
So i have an issue with my 2000 323Ci.
The car once in a while idles a little odd (goes up and down but has yet to stall) However driving it for a couple minutes it is alright But it does not happen all the time but i would like the fix it before it becomes any worse. I get the following codes. E3/B1 - Ox.-s.control deviation, bank 1, too large E4/B1 - Ox.-s.control deviation, bank 2, too large Shadow-memory: E3/B1 - Ox.-s.control deviation, bank 1, too large E4/B1 - Ox.-s.control deviation, bank 2, too large 85/08 - Signal, CAN ASC 3 7F/02 - Activation, solenoid valve, suction-jet pump Could it be a possible o2 sensor, fuel pump/pressure MAF... I also just recently got the car a couple months ago and this is the first time it has done this. Any help would be appreciated |
#2 |
I would first check for vacuum leaks based on those faults. Most common source is the DISA flap seam and or the cyclone separator under intake manifold. If none found I would suspect the MAF. You'll need better test software to determine that.
Good luck! |
| Tags |
| idle, mass air flow sensor, oxygen sensor, stalling on startup |
