Old 09-01-2012, 05:46 AM   #1
zidoff
My Ride: E46
P0125 & p0141 & p0171
Dear All
I got BMW E46 316i 1.9 M43; I got the check Engine and the following errors:
P0125 signal oxygen sensor before catalytic converter DME
P0141 Oxygen-sensor control, control limit DME
P0171 please refer to vehicle service manual! DME
Any body know how to solve them.
Thanks In Advance Regards
zidoff is offline   Reply With Quote
Old 09-01-2012, 06:32 AM   #2
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Probably an air leak. Search thread titles for your codes...and search jfoj's sig for link to 'fix your bmw' thread. There are many hoses that can break, but the first is usually the lower intake boot.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 09-01-2012, 07:40 AM   #3
jfoj
My Ride: 330CiC, M5, X5
OP, check the first 2 links below in my signature for more info.
I see you likely have a 4 cylinder engine, which we do not see many here in the US and my information is mainly for the 6 cylinder engines, however, the same type of problems likely impact your engine as well.
Check for cranked, broken and rotten rubber hoses and parts on your engine first, likely you will need to replace many of the hoses before you start with hard, expensive parts.
Old 09-01-2012, 07:58 AM   #4
zidoff
My Ride: E46
Do you have a link to download a PDF for the M43 Engine Error Codes and Descriptions?
Thanks In Advance.
Old 09-01-2012, 08:03 AM   #5
dmax
dmax's Avatar
Sounds like the sort of thing you could find by googling it.
Mangofy your E46!
Old 09-01-2012, 08:06 AM   #6
zidoff
My Ride: E46
It's hard to find them since each BMW E46 Engine has it's own P codes and My Engine M43 isn't popular
Old 09-01-2012, 08:17 AM   #7
dmax
dmax's Avatar
http://realitypod.com/2012/06/bmw-co...-e90-and-more/
HTH
Mangofy your E46!
Old 09-01-2012, 08:24 AM   #8
dmax
dmax's Avatar
Oh, also, I believe the fault codes vary slightly by DME version, not the engine per se. Find the DME you have and search for the codes for it. Easiest, usually, is to search for your fault codes...although I don't have them memorized, your last two are almost always an intake leak, with an occasional badly clogged fuel filter or failing fuel pump...at least, iirc.
Mangofy your E46!
Old 09-01-2012, 09:11 AM   #9
zidoff
My Ride: E46
Thanks A lot for the information's, But how can I know my Digital Motor Electronics (DME)Version?
Old 09-01-2012, 09:17 AM   #10
zidoff
My Ride: E46
How can I download this software? is it free?
Old 09-02-2012, 09:49 AM   #11
dmax
dmax's Avatar
I haven't a clue...just found it by googling and it looked like it might help.
Mangofy your E46!
