Old 01-19-2010, 07:57 PM   #1
noway1nc
My Ride: 2004 330Ci ZHP
e46 Fuel Pump Failure
In case somebody else faces this, I wanted to share my experience and findings about my failed fuel pump... i have 04 330Ci ZHP... first the car started hesitate upon acceleration and down-shifting - very minor hesitation, but noticable as you step on the throttle.
A few days later, the car started just fine, i drove for about 10 km (6 mi), the hesitation was a little more noticable upon throttle, then the car started jerking upon acceleration, as I was stepping on the gas pedal, it would go for half a second, then it's like i released the gas for a second (eventhough it was at least 1/2 way in), then go again. Jerking, stumbling, etc. Then I shut the car off - tried to restart... felt like out of gas. would start for about 1 second, then the rpm would drop... after a few tries, it wouldn't even catch. The motor would turn, but nothing...
I spent hours researching... people mentioned many things before I stumbled upon a thread saying to check the fuel pump... the procedure is very easy:
1. have somebody put their ear to the back seat (pass. side), turn the key to ON position (do not start), the pump should prime for about 2 seconds.
The procedure can be only repeated about every 2-5 seconds, as it will not prime until the timer reached 2-5 seconds between primes.
2. take the cover off the fuel rail under the hood, there is little valve, looks like a simple tire valve. Take the cap off, put a rag around the engine, press on the valve, some fuel will come out. Then have somebody turn the engine (trying to start) while you're holding the valve pressed down see if fuel is coming out (should have some pressure to it) - cover your eyes.
I didn't have either... not priming noise, no fuel in the fuel rail. Changed the fuel pump... runs great.
I hope this helps.
Good luck.
noway1nc is offline   Reply With Quote
Old 01-18-2011, 01:34 PM   #2
MedicAndRN
My Ride: 325ci
Good info. Same thing has happened to me; symptoms sound exactly the same; only I can hear the fuel pump so I'm trying a new filter. Now to get it primed....
MedicAndRN is offline   Reply With Quote
Old 01-18-2011, 02:35 PM   #3
mikeyb74
My Ride: Jet Black 01 325xit
Send a message via AIM to mikeyb74
Thanks for the info.
The BMW e46 3er Sport Wagen...
"The station wagon thatís finally gorgeous enough, engaging enough to drive, and sufficiently
swell to lure folks out of those cumbersome utes." -Car and Driver
It's funny... people who drive anything expensive often get labeled by folks who drive less expensive cars. I have found, without exception, that douchebags cover all demographics and incomes. You can be an douchebag in either a Echo or an Escalade.
mikeyb74 is offline   Reply With Quote
Old 01-18-2011, 02:51 PM   #4
stockmwk
My Ride: 2000 323i sedan
Real easy to do, takes about 15min. Be sure to have a catch small enough to fit under with you to contain the spill. When I changed mine, towards the end of what gas I poured out of the filter itself, was black
2000 323i sedan
stockmwk is offline   Reply With Quote
Old 08-31-2012, 04:59 PM   #5
E40SICK
My Ride: 2001 330ci
sorry to bring a dead post back. searched google and this popped up
having similar issue ATM. anyone else notice the gas gauge going down faster?
E40SICK is offline   Reply With Quote
Old 08-31-2012, 07:16 PM   #6
das boots
My Ride: '90 M3 & '05 ZHP
This is one of my pet peeve with BMW. Why couldn't they have used the same fuel pump from the E39 530i on the E46 330i? Same engine. The FP from the E39 is one of the best made. The bean counters win again......
Lawrence
BMW CCA San Diego Chapter #192742
'90 M3 - Garage Queen
'91 M Technic II Cabriolet 5 Spd - OOC
'99 M540i Touring - #2 Son DD
'03 530i 5 Spd - S.O.'s
'05 330 ZHP 6 Spd - Canyon Cruiser
'09 328i 2 Dr Step - #1 Son's DD
'03 Nissan Frontier Crew Cab - My DD & Range truck
das boots is offline   Reply With Quote
Old 09-01-2012, 04:17 PM   #7
warriorpluto
My Ride: 2000 323i
Are they not interchangeable?
Sent from my Galaxy Nexus using Bimmer App
warriorpluto is offline   Reply With Quote
Old 09-01-2012, 10:01 PM   #8
das boots
Negative. I wish......
Lawrence
Old 09-01-2012, 10:31 PM   #9
jfoj
My Ride: 330CiC, M5, X5, E93
Slver46,
Suggest you check the 2nd link below in my signature for more fuel pump information.
