#1 |
Cooling system (CHECK!)
This is Harriet and she has 55,880 miles on her and is just back from the shop. She had the following done:
Water pump with metal impeller Fan switch Thermostat and thermostat housing Sealing gaskets Expansion tank & cap 1 Gallon Coolant Upper & lower radiator hoses And temp sensor The belts are in good shape and the mechanic said after looking over the car they found no surprises and that it was in very good shape.
#2 |
Wrong forum. You want "Model_T_Fanatics.com" where people can talk about cars named "Harriet", "Bessie" and "Buttercup" with a straight face.
However, we are glad you got the cooling system replaced. Let us know when you get that pimpin Chrome Hand Crank, and remove a leaf spring for an 8 inch drop. You don't need to tell me, I know I am being a d!ck tonight. I'll save you the post. |
#3 |
Sh1tty Advisor
My Ride: 323Ci 5 Speed Black
I am sure the mechanic is saving the old water pump, hoses, and expansion tank for another e46 because at those miles, these are barely broke in.
What a hand-out for the mechanic
![]() Oops! My Water Pump Broke Again .................... Coolant in a Bottle Last edited by MercForHire; 09-01-2012 at 02:41 AM. |
#4 |
Stay stock my friends!
That one gallon of coolant...I hope they added water (distilled) to make a 50/50 mix....and I hope the thermostat with housing was an OE wahler plastic housing...as the aluminum ones seem to work only days at most!
BTW, next time, the composite blade WP is fine. The panic over plastic wp blades falling apart is over...that was quite a while ago and since then bmw has made a better composite. No worries.
![]() This huge woman, like 400 pounds comes up to me and says, "Doug, I would rock your world." I replied, "but I need to breathe." The girl in my sig:http://forum.e46fanatics.com/showthr...highlight=dmax |
#5 |
You realise they don't just fail depending on mileage, its also to do with age.
AC Schnitzer Styled M3 ![]() |
#6 |
Great girl, very low miles
i'm at 85K ready to do cooling redo when weather cools down here
#7 |
Wrong.
#8 |
100% star stuff
Cool! Now you've got many more miles of peace of mind! Your car makes me want a steel grey pre-facelift coupe. So clean.
![]() Bilstein/Eibach B12 Pro-Plus Suspension System | DICE Mediabridge | Valentine One |
#9 | |
Suspension is doin fine but I want bilsteins and hr springs next. This car sticks well stock when pushed but I can only imagine it with that set Up.
#10 | |
john |
#11 | |
100% star stuff
It feels incredible. Definitely something I recommend when your stock components wear out.
#12 | |
WRONG. There is more to preventive maintenance than mileage, in fact there are plenty of people out there that would argue age is a bigger factor than mileage.
#13 |
I dare someone to roll the dice with their cooling system because of mileage
#14 |
OP is at 56k miles, my ET failed at 65k miles, all you people claiming he made the wrong decision are....
As others have mentioned the car is 10 years old, the failing of a cooling system has a lot to do with heat cycles, not just mileage.
#15 |
Sh1tty Advisor
If you habitually overfill your coolant you can pretty much blow an expansion tank every year.
![]() Oops! My Water Pump Broke Again .................... Coolant in a Bottle |
#16 | |
Sent from my DROIDX using Bimmer App
#17 | |
but hey, if you got an extra 400-600 laying around then by all means, go for it. it's not going to hurt you. john |
#18 |
^I'll be the first to lol when your "My EP tank busted" thread pops up.
#19 |
Sh1tty Advisor
The above guy is a strong case of a ZHP-Nazi who is hypnotized into thinking his car equals a Porsche 911.
Ignore him
![]() Oops! My Water Pump Broke Again .................... Coolant in a Bottle Last edited by MercForHire; 09-02-2012 at 12:19 AM. |
#20 | |
![]() Last edited by EverydayGetaway; 09-02-2012 at 12:32 AM. |
