Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 4.75 average. Display Modes
Old 08-31-2012, 07:44 PM   #321
TrippinBimmer
My Ride: Just Fast!
I'm having a hard time believing that is your N/A dyno sheet with an AT. Are you sure you didn't get them mixed up?
I got them from Brady (aggieE46). This was like 2 years ago, but the numbers are right.
-Anthony
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 09-03-2012, 11:18 PM   #322
Steven747
My Ride: 05 330ci
and hows it going?
Old 09-04-2012, 05:02 AM   #323
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
-Anthony
There is a difference between manual and automatics.
Old 09-04-2012, 11:01 AM   #324
TrippinBimmer
My Ride: Just Fast!
Me and Brady went dyno at the same time 2 years ago. He had my files for my runs and this is what he sent me.
-Anthony
Alpine White M3
MaximumPSI Stage4
Old 09-04-2012, 08:35 PM   #325
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
-Anthony
Shame on Brady.
Whatever the case, you are going to see such a big gain from the SC setup, that whether you made 217 or 200rwhp will be irrelivant. It will just be a little line marking the bottom of your graph.
Old 09-10-2012, 08:26 PM   #326
TrippinBimmer
My Ride: Just Fast!
Been having issues with filter wash. It will cause the engine to cutoff when i was coming to a stop quickly.
So I moved the MAF up the pipe and left the filter where it was. So far so good
Next is to install some new o2 and my gen3 headers. Hopefully, this fix my crazy AFR. Very similar to Jim Murphy issue but my wires aren't melted. I guess the o2 just went out. Wish me the best
Shame on Brady.
Hehe fo sho Adam
-Anthony
Alpine White M3
MaximumPSI Stage4
Old 09-10-2012, 08:39 PM   #327
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Ready to push the car off a cliff yet?
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
bigjae1976 is online now   Reply With Quote
Old 09-10-2012, 08:49 PM   #328
TrippinBimmer
My Ride: Just Fast!
Haha rofl. Man for a car that was in tip top shape N/A (mechanical). F/I is asking for a lot to be done and maintience wise...
Alpine White M3
MaximumPSI Stage4
Old 09-11-2012, 07:48 AM   #329
bigjae1976
bigjae1976's Avatar
This might be my car soon...
Old 10-12-2012, 08:28 PM   #330
Mormon
My Ride: 2001 330xi
any updates?
Mormon is offline   Reply With Quote
Old 10-12-2012, 08:36 PM   #331
TrippinBimmer
My Ride: Just Fast!
Originally Posted by Mormon View Post
any updates?
Still having AFR issues. Headers should be coming off this weekend and new o2's should be installed and M3 Rear end swap as well...
-Anthony
Alpine White M3
MaximumPSI Stage4
Old 10-30-2012, 05:13 PM   #332
TrippinBimmer
My Ride: Just Fast!
Well, I finally did some work on the boosted 330 today. Removed the F1 Autohaus Ceramic Coated Headers and Post o2 sim Unit.
After, I get the Gen3 Tig'd up and Sprayed Black. I will be installing them with New o2 Wideband Sensors. Hope these will fix my AFR if not the Kit will be coming off and going back to stock.
-TrippinBimmer
Alpine White M3
MaximumPSI Stage4
Old 11-01-2012, 08:03 PM   #333
TrippinBimmer
My Ride: Just Fast!
Partially Installed...
This was the PITA to install. I spent 5 hours messing with it and only got 1 nut on the rear header and 4 on the front header. 0.o Should finish it up tomorrow...
-Trip
Alpine White M3
MaximumPSI Stage4
Last edited by TrippinBimmer; 11-01-2012 at 08:11 PM. Reason: How hard it really is...
Old 11-01-2012, 10:09 PM   #334
Guest021715
Account closed.
noob, you need ratcheting s-shape wrenches, and a small 1.4 drive wrench with extension.
Old 11-01-2012, 10:12 PM   #335
TrippinBimmer
My Ride: Just Fast!
LOLz far from a noob. Need to Remove Motor Mount Bracket, and Front Control Arm Bushing. You will need to lift the motor up and install both headers at the same time. Can't install the front and then install rear headers. Also most people dont leave the Top Part of the Exhaust Manifold Gasket intact.
-Trip
Alpine White M3
MaximumPSI Stage4
Old 11-02-2012, 12:14 AM   #336
Guest021715
Account closed.
You only need to touch the motor mount to get rid of the original headers. Not sure what the FCAB has to do with it unless this is an Xi.
1/4" drive ratchet, with 2 inch extension and an 11mm ratcheting S-wrench from Harbor Freight will be your new best friends if you let them.
I've done this job 4 times on my car, it gets easier.
Old 11-02-2012, 09:31 AM   #337
TrippinBimmer
My Ride: Just Fast!
You installed the Techniks Gen3? These headers is like Twice the size of the BB headers you are running...
-Trip
Alpine White M3
MaximumPSI Stage4
Old 11-02-2012, 02:19 PM   #338
Guest021715
Account closed.
I highly doubt it.
Old 11-02-2012, 03:46 PM   #339
TrippinBimmer
My Ride: Just Fast!
I highly doubt it.
-Trip
Alpine White M3
MaximumPSI Stage4
Old 11-03-2012, 05:40 AM   #340
Guest021715
Account closed.
The clearance between engine mount and header is the same.
I don't see what it has to do with the FCAB.
