Old 09-07-2012, 06:51 AM   #1
sihatch
My Ride: E46 M3
e46 subframe issues
I am going to be replacing my bushings slowly in the next year (front and back) including all subframe bushings. I have not seen/found a new updated informative thread about the infamamous subframe cracks/tears/failure. I want to know how common this is and around how much each person has been charged to have it fixed. I dont have a welder/lift/space to do the subframe fix myself if I end up needing it. Please dont reply unless you have experience with these issues. Threads in the past didnt necessarily have people with this issue but people for lack of words promoting the issue as if they did have the issue. Any help is greatly appreciated!
Thanks!
sihatch is offline   Reply With Quote
Old 09-07-2012, 07:26 AM   #2
ChrisRedmon
My Ride: 2002 PY ///M3
Its not common. Its prevalent. period. There is almost a 100% chance you will have to deal with it if has not yet already been attended to. Ive heard people have paid 800-2000. Replace all bushings while everything is apart. Much easier.
2002 Phoenix Yellow E46 M3 l 6MT l Nappa l Nav l STG Coilovers 7k/8k l BMW Performance SSK l OEM ZCP's l Kirk Roll Bar l Motorsport Hardware l Besian Systems l CSL/GTR Carbon Fiber Hood, Trunk & Diffuser l Status Gruppe Sec. 3 l Custom Rear Brace l Rear Seat Delete l Coby Wheel Products
ChrisRedmon is offline   Reply With Quote
Old 09-07-2012, 07:40 AM   #3
sihatch
My Ride: E46 M3
Thanks Chris. Yes thats my plan is to drop my subframe replace all four bushigns while its down and then do detailed inspection on the surfaces. I know I can inspect with the subframe on but If its just small cracks (which im hoping and as it seems) I can see how extensive it is with the subframe off. Im hoping its not bad and I can just have it reinforced with the kits that are on the market and take car of that issue....
In for more details from others.
Old 09-07-2012, 07:41 AM   #4
sihatch
My Ride: E46 M3
And also Chris, i noticed in another thread you were saying you had small cracks. How are you going to deal with the situation?
Old 09-07-2012, 08:06 AM   #5
cposk
My Ride: 08' E90 M3
Not sure how common it is with the M3's, but you should just have the plates welded in if everything is apart for bushing replacement. The added labor is dropping the gas tank and doing the cleaning/welding. I'd say 5-6 hours max if the mechanic knows what he is doing.
You will be pretty upset if you get all the bushing done and end up having a subframe mount failure later on...
cposk is offline   Reply With Quote
Old 09-07-2012, 08:24 AM   #6
MercForHire
My Ride: M235i 6MT
For e46 M3s it mostly happen on the first year 2001 model. I saw a lot of those ones crack over the forums.
Although you can crack any unreinforced e46 m3 subframe by being a drifting king or burnout monkey
Old 09-07-2012, 08:27 AM   #7
ChrisRedmon
I plan on doing a complete overhaul. Drop the sub frame. Weld it up. New bushings for the subframe/diff and tranny. Thats when tax returns come around though. It will only get worse though so im trying to drive like a normal person.....which is hard
Old 09-07-2012, 08:31 AM   #8
MercForHire
My Ride: M235i 6MT
Install this whole kit and drift that motherf*cker with impunity
http://www.turnermotorsport.com/p-13...t-package.aspx
Old 09-07-2012, 09:05 AM   #9
ChrisRedmon
^ So much yes is embedded in that statement.
Old 09-07-2012, 12:42 PM   #10
sihatch
My Ride: E46 M3
Yes I plan to install it regardless. However just wanted to get an idea of what people pay and real expereience from people that have gotten it done or have the issue. Ive only really talked to people that know about it but cant speak from real experience.
Old 10-02-2012, 04:21 PM   #11
mEaty30
My Ride: '00 E46
Originally Posted by sihatch View Post
I want to know how common this is and around how much each person has been charged to have it fixed. Any help is greatly appreciated!
Thanks!
I think the OP had asked what was the ball park figure on parts and labor. I could use the info as I will be doing this as well. I just don't want to be ripped by a dealer.
mEaty30 is offline   Reply With Quote
Old 10-03-2012, 11:53 PM   #12
Super Sheep
My Ride: 2005 E46 325 CI
What about a 2005 E46 Coupe?
Super Sheep is offline   Reply With Quote
Old 10-04-2012, 09:26 AM   #13
Obioban
My Ride: 05 M3, 01 M5, M3iT
Send a message via AIM to Obioban
2001-2005 have identical rear floors. For 2006 they changed to the vert rear floor, which is stronger... but can still be ripped.
Best course of action is to structural foam it and epoxy on plates BEFORE you have an issue. Cheaper and stronger.
Once you've had an issue you have to weld it, no more epoxy. Once you foam it, you can't weld it.
-Ian
Current Cars: 2005 IR/IR M3, 2001 LMB/blk M5, Wife's 6mt NA RWD e91, 04 M3 wagon
Past cars: 04 M3, 96 M3, S50B32 e36 M3 CM race car
"People do not see good design." -- Claus Luthe, BMW chief designer e30-e39
Obioban is offline   Reply With Quote
Old 10-04-2012, 09:30 AM   #14
My Ride: Lexus
And by the way to anyone considering dropping the rear subframe on any E46, there's much more than the "four subframe bushings" back there. Much more. 17 more, in fact. (including the rear trailing arms) so call it 15 more. The odd number obviously comes from the rear diff (3 bushings)
Old 10-04-2012, 12:52 PM   #15
Akovski
My Ride: 323CI
i got a quote for my currently cracked subframe to be welded and reinforced for $400 but that guy is awesome and never charges anyone out the roof. Try to find your self a small shop thats a bmw fanatic like my local guy.
Akovski is offline   Reply With Quote
Old 10-04-2012, 01:09 PM   #16
Glaede
My Ride: BMW E46 323Ci
I just picked up my car today actually after reinforcement. My mechanic fixed a big ass hole and then welded the TMS reinforcement kit in and also changed four bushings in the subframe, changed the guido, brakelines, output flange seal and reset my service indicator. I paid 8000,- dkr which is around $1389,66 US dollars in labor. Remember I'm located in Denmark and everything is expensive here, so i think i got a good price..
Glaede is offline   Reply With Quote
