#21 |
Sh1tty Advisor
My Ride: 323Ci 5 Speed Black
This car is beautiful!!! I love black BMWs!
Start with getting rid of the amber side reflectors and Borla exhausts.
![]() Oops! My Water Pump Broke Again .................... Coolant in a Bottle Last edited by MercForHire; 09-08-2012 at 05:44 AM. |
#22 |
Stay stock my friends!
Damn...I'm too late!
OP, I'll just say that when you make your exhaust louder, you're masking the sound of the engine. Personally, I prefer hearing my engine...my exhaust is stock and my stereo is off. Why do all of you want to hear the sound of the exhaust? Hint...you really don't. You want others to hear it and think your car is faster, better, more special than other cars. It is as it is. 100K miles? New plugs, cooling system, CAs/CABs, probably vcg and ofhg are due too. You'll be wanting a new guibo and csb pretty soon...your icv/tb are dirty, the intake boot is probably ripped, and I bet you need a new fuel filter too. Anyway, MJ mostly beat me to this, but I prefer my own trolling!
![]() This huge woman, like 400 pounds comes up to me and says, "Doug, I would rock your world." I replied, "but I need to breathe." The girl in my sig:http://forum.e46fanatics.com/showthr...highlight=dmax |
#23 |
Weagle Weagle
#24 | |
mine is ebay headers to oem resonator and muffler then i had the rear resonator replaced with 2 glasspacks. its deeper in real life but youll have all the high end rasp you want 2004 325i |
#25 | |||||
, I have actually always modded my cars tastefully but i actually don't plan to do any real exterior mods except for maybe getting rid of the spoiler/replacing it with one of those smaller ones that looks like it's a part of the trunk. I will check on the maintenance and cooling system. Quote:
sent thanks man
#26 |
You've heard there's no such thing as engine noise? Was that from an infomercial on the Fox network?
![]() I'm pretty sure I can hear my engine. I am deaf in one ear though, so maybe I'll listen again and focus on my echolocation.
#27 |
Not true, friend. Especially not in our cars.
#28 | |
http://forum.e46fanatics.com/showthr...886&highlight= quoted in order "You're not understanding that engine noise is not a thing. You only hear two things: intake and exhaust sounds. Are you expecting to hear the combustion process or the valves lifting or something? An aftermarket exhaust doesn't have to sound a certain way. It can sound any way you'd like. But hearing "engine noise" makes no sense. It's not a thing" "I'd sure hope that you don't want to hear "engine noise". That would mean that you'd hear the affects of increased friction from an engine that wasn't operating properly. You hear 2 things: -Intake noise -Exhaust noise Hearing the engine is bad. But they are right...if you want to hear the engine, just drain some oil out. You'll hear the engine working plenty after that."
#29 | |
![]() ovation gif pics on Sodahead[/IMG]
#30 |
My Ride: 05 325ci cabrio 5spd
#31 |
At that mileage get ahead of the maintenance curve if none of these have been done within last 30k miles:
valve cover gasket oil filter housing gasket CCV and all new hoses maf to throttle body intake hoses exp tank, water pump and thermostat M3 motor mounts and new tranny mounts For almost any muffler upgrade, Eisenmann is really hard to beat. |
#32 |
Makes me miss my black one.
![]() Enjoy it.
#33 |
The reason the rear resonator alone does nothing is because of the way the single chamber is made, there is a slight cutout that diverts some of the exhaust gasses through a glass packed chamber, but 80% doesn't go through there. Plus the gasses from all 6 cylinders are pushing through t high speed.
The front resonator is where the sound is, BMW engineers aren't dumb. They damped both banks individually then merge them killing almost all the sound. To get some sound the rear resonator must be deleted then the front. The front can be a simple Y pipe or a hand made 2x1.750 to 1x2.5 collector This was a hand made collector made from 3.5" tubing worked by hand. When all is said and done, you get that signature sound. |
#34 |
And the sound inside the car doesn't change. Windows down, I hear my AFE stage 2 way more than the exhaust. I didn't want to hear the exhaust, I wanted others to hear it. It's a BMW guys, not a civic with a watermelon launcher as a muffler.
#35 |
this is similar to what im looking for, and please dont say go buy a e36 m3
#36 |
Well your 2.5 will never sound like the 3, no matter what you do, the 3l sounds much hallower compared to the 2.5.
Don't let the sound of the exhaust fool you though, that is a twin piped without cats and no resonators. That car also has a lightweight flywheel (quick rev drop when free rev at light). There is a book called "Harmonics and Flow Paths of Exhausts and Intakes". It's a engineers guide to manufacturing headers, exhaust systems, intake tubes and intake manifolds, for both turbo and n/a Last edited by drift.mechanic; 09-17-2012 at 01:19 PM. |
#37 | |
#38 |
My bad thought I remember 325ci,
#39 |
np, i forgot to update my profile, still had the 325i on there
should i replace the o2 sensor too? the car seems to accelerate slow in 1st gear, itll only go fast when i push the pedal 50% down. ive driven other 330's so i know 1st gear isnt supposed to feel like that, ive already bought a new fuel filter that im going to change, but the o2 sensor is pretty expensive so dont know if i should wait on it.
#40 |
I knew I wasn't crazy for seeing 325 somewhere
