E46 Convertible
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 1.00 average. Display Modes
Old 09-08-2012, 05:55 PM   #21
ImSoFreaknWhite
My Ride: '06 M3 SMG VERT
Send a message via ICQ to ImSoFreaknWhite Send a message via AIM to ImSoFreaknWhite Send a message via Yahoo to ImSoFreaknWhite
respect the rules of the road and you wont need the V1
Jordan
My Build Thread
l Status Gruppe One-Piece Lip l Anodized CCW Classics w/ Polished Lips l Black Grills/Gills & Emblems l Carbon Fiber Roundels
Status Rear Section l K&N 57 Series CA Intake l OEM JB Hardtop l TM Drilled/Slotted Rotors l D2 Coilovers w/Camber Plates l VIS CSL VERT Trunk
ImSoFreaknWhite is offline   Reply With Quote
Old 09-08-2012, 08:43 PM   #22
illestminimike
My Ride: Project Drama
I love you
Old 09-08-2012, 09:16 PM   #23
ImSoFreaknWhite
Originally Posted by illestminimike View Post
I love you
ditto
Jordan
My Build Thread
Old 09-08-2012, 09:38 PM   #24
///MPR77
My Ride: 02 ///M3 Tri-Ped
Originally Posted by M00P View Post
You just have to remember to turn the power off of the unit when you exit the vehicle.
FYI...You do not have to turn the power off, as your car goes to sleep mode after 15min.
Old 04-19-2013, 06:14 PM   #25
danwilz
My Ride: E46 M3 Vert 2012 X5
Well I opened up the interior light and the only wires in there is for the harness for the map lights. I dont think I can tap that for it. I wish Jake was local and could just do it for me.
What did you end up doing gotta get this done?
danwilz is offline   Reply With Quote
Old 04-19-2013, 07:44 PM   #26
danwilz
Nevermind. Figured out in the verts use the green wire with white stripe for switched power.
Old 04-20-2013, 07:19 AM   #27
PKR
My Ride: '04 330Cic
Thanks danwilz!
PKR is offline   Reply With Quote
Old 04-20-2013, 08:16 AM   #28
danwilz
Originally Posted by PKR View Post
Thanks danwilz!
Your welcome. Its in the wire loom that goes to the mirror, and I placed a self tapping screw in the frame above the light housing off to the side. You can squeeze the hardwire box in an area towards the left front of the overhead light compartment.
Old 04-20-2013, 09:08 AM   #29
Dave
Moderator
Dave's Avatar
My Ride: 323,330,M3,M3,M3
I read somewhere about that green/white wire but I had no room to work up in there. I ended up tapping into the glove box light and running it (badly - need to fix this) up the A pillar on the passenger side.
I really want to do a stealth mirror and laser jammer and headrest mount it. I hate having it in the windshield, especially with the top down.
Perhaps you think multi-million dollar ad campaigns make a beer taste better. Perhaps you're mouthing your words as you read this.
Dave is offline   Reply With Quote
Old 04-21-2013, 05:40 PM   #30
danwilz
I'm installing the remote display in my ashtray and going with a laser jammer, laser interceptor to be exact, also I removed my front plate it makes it more difficult for LEOs to get a fix with the laser it usually take 2 or 3 times.
Old 04-22-2013, 12:37 PM   #31
crazyseaman
My Ride: e30
you can definitely tap it in, ( I don't remember what color wires). hardest part is stuffing all the wiring up there and putting back the map light.
crazyseaman is offline   Reply With Quote
Old 05-24-2013, 02:07 PM   #32
vman1
My Ride: 2004 CB M3 vert
To the guys that tapped into the green and white wire, what did you guys use to ground? I do not see a screw up there for 'verts. Thanks!
vman1 is offline   Reply With Quote
Old 05-28-2013, 07:40 PM   #33
danwilz
Use a self tapping screw 1/4 in long>
Old 03-30-2015, 01:00 AM   #34
LINDW4LL
My Ride: '03 Steel Grey ///M3
Hey guys, I just picked up an M3 'vert on Saturday, and attempted to hardwire my V1 last night.
I pulled off the map light assembly, but the Homelink/mirror harness I'm supposed to tap is tight against the headliner/windshield and seems to have no slack in it whatsoever. Do I just need to give it a firmer tug and it will give me some slack/loosen up? I can barely grab at it as-is, and there's no chance of being able to tap into it given how it sits currently.
Thanks!
LINDW4LL is offline   Reply With Quote
