Sponsored by The Tire Rack
Old 09-08-2012, 02:43 PM   #1
ajai
My Ride: 330ci***65104; 328i
et 35 fender rub.. Please help
I have front et35 18x8. rear et35 18x9
BOth 225/40/18
Rear and front rub too.
Rear I could fender roll or do a little more camber to fix.
But the front.... What can I do!?!?!
missed the ci, welcome the i
ajai is offline   Reply With Quote
Old 09-08-2012, 05:57 PM   #2
tireguye46
My Ride: 2002 330i
Do you still have the stock suspension or is it lowered?
tireguye46 is offline   Reply With Quote
Old 09-08-2012, 07:27 PM   #3
Jets330
My Ride: scrapes alot
run a 215. done..
Jets330 is offline   Reply With Quote
Old 09-09-2012, 02:14 AM   #4
ajai
I am lowered. Eibach pro with sachs advantage . umm very low .
but bot stiff enough to hold up from rub.
my tires are new.. So I don't want to change .
I am really thinking why others with et 35 x 8 doesn't have any issue but I do.
will it because it's a replica so the size are not even correct..
Old 09-09-2012, 05:20 AM   #5
ajai
I see that one side of the front wheel seems to stick out more then the other. Will this cause by incorrect alignment? Since my alignment is not straight.
also I have changed new rack recently. Will the rack be install uneven, if that is possible.
Since only one side is rubbing....
