Suspension & Braking
Have some questions about suspension or brake setups for your E46 BMW? Get all your answers here! |
#1 |
Finally solved my brake dilemma. PFC Z Rated and Brembo
So I've solved my brake dilemma by ordering this front and rear set up from ecstuning. Brembo rotors and PFC Z Rated pads with ATE Super blue fluid. The pads in the picture are not the ones I bought.
![]() Last edited by PrecisionX; 09-12-2012 at 08:20 AM. |
#2 |
100% star stuff
Good job. You chose quality parts and didn't waste money on slotted/drilled rotors that you don't need.
![]() Bilstein/Eibach B12 Pro-Plus Suspension System | DICE Mediabridge | Valentine One |
#3 |
Nice
#4 |
I changed the order, ditched the pads and went with PFC Z Rated, everything else is the same.
#5 |
I've actually went through a set of OEM pads on a pair of new OEM blanks, then once the OEM jurid pads were gone I put in a pair of pfc z-rated and I absolutely love how much grip and no fade I get when I sometimes need to race for work ;-)
These pads create a black, easier to wipe off dust which when compared to the rear OEM pads (still 50% life when I put on the z-rated in front) will dust 60% while the rears will dust 40% So basically the dust on them is way down over OEM fronts and its a easier type to deal with when cleaning wheels. Overall a great everyday pad that has really great features. They warm up within Prob. 5 min within the oem grip standards, before that 5min they aren't too bad very easy to just apply a small amount more pedal and be good with stopping without worrying. After they're warm they are very crisp and easy to modulate it just adds on the the very amazing e46 engineering in pedal feel. A++ pads! They're going on rear next Sent from my DROIDX using Bimmer App |
#6 |
I have this exact setup. Just installed it a few months back.
I don't like it as much as I did the OEM setup. I don't think it has as much grip as the OEM brakes did. I went though the break-in process after the zinc coating wore off the rotors, so I'm pretty sure that isn't the problem. I'm not really sure what is. But if I do the brakes again, I'm going OEM.
For Sale: Auto Trans E-fan - http://forum.e46fanatics.com/showthr...3#post12840603 23.5mm Front Sway Bar - http://forum.e46fanatics.com/showthr...0#post13054250 18mm Rear Sway Bar - http://forum.e46fanatics.com/showthr...8#post13054258 |
