E46 Xi Forum
Thread Tools Search this Thread Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
Old 09-13-2012, 02:53 PM   #1
B-Sho
My Ride: 2004 BMW 330Xi
Question What Automatic Transmission Fluid should I use?
I have a 2004 BMW 330xi with the GM A5s390r transmission. I want to change my transmission fluid because my car has 94,000 miles now. What ATF should I use? I heard Redline D4 is good and also Valvoline VV370 DEXRON-VI. Would both of these work? And would you recommend any other ATF fluids?
Redline D4- http://www.amazon.com/Red-Line-30504...smission+fluid
Valvoline VV370 DEXRON-VI- http://www.amazon.com/Valvoline-DEXR...smission+fluid
Thank you
Edit: I also noticed there is a Redline D6 ATF... whats the difference from D4 to D6
B-Sho is offline   Reply With Quote
Old 09-13-2012, 09:42 PM   #2
Rickna
My Ride: '01 330xi - '09 IS-F
Redline D4 is preferred by most. That's what I use. Since you can't drain the trans 100% you should match the fluid as close as possible.
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 09-13-2012, 09:49 PM   #3
B-Sho
So D4> Dexron 6? why not D6? not the same stuff?
This guy in this video says to go with Dextron 6
Im torn between the two fluids... i want the best for my black beauty lol
Old 09-13-2012, 09:54 PM   #4
Rickna
I don't know enough to say which is better. However, the threads I've read through point to D4.
2001 BMW 330xi
2009 Lexus IS-F
Old 09-13-2012, 10:04 PM   #5
B-Sho
Alright thanks for your input man. I will wait for a few more replies from others before i make my decision
Old 09-13-2012, 10:12 PM   #6
Rickna
I had seen a post where different ATF's were analyzed in a lab. Redline D4 was closest to the original ATF.
2001 BMW 330xi
2009 Lexus IS-F
Old 09-13-2012, 10:14 PM   #7
ummwillprince
My Ride: 2003 330i
Bmw has superceded fluid with dexron 6
Sent from my MB860 using Bimmer App
ummwillprince is offline   Reply With Quote
Old 09-13-2012, 10:21 PM   #8
B-Sho
Would the Valvoline dextron 6 work? I have a Amazon gift card so i have to get what amazon has.. and thats either Valvoline dextron 6 or redline D4
Old 09-13-2012, 11:15 PM   #9
ummwillprince
My Ride: 2003 330i
Should be good to go, I just did mine last weekend with Valvoline's Dexron 6. Here's the link where people were discussing what fluid to replace the Texaco ETL with:
http://www.xoutpost.com/bmw-sav-foru...etl-8072b.html
I have driven 200 miles since last weekend and so far it seems smooth, and no more lag in the mornings going from Reverse to Drive. I wasn't able to do the flush last weekend, so I bought some more ATF and will do a proper flush this weekend if I can get my compression fitting off.
Just make sure to do the filling procedure correctly, I messed up and shut the car off after I filled. But to correctly fill the car has to be in Park and fluid has to be between 85 and 120 degrees. Here is the link to the flush, there is debate on whether to flush or just drain and fill:
http://forum.e46fanatics.com/showthr...smission+flush
PS: It is 8 dollars a quart at Kragen, Oreilly
Old 09-13-2012, 11:37 PM   #10
B-Sho
Thanks dude. Good info. And your BMW did the same thing mine is doing!!! like i reverse out of my driveway and i put it in drive and when i accelerate it slips for like 5 seconds and it kicks in.. after the car is warmed up it doesnt do it at all... so yours doesnt slip at all anymore? i hope this transmission fluid fixes my problem.. if not.. im going to sell it because i dont feel like messing with replacing the whole automatic transmission...
Old 09-19-2012, 05:51 AM   #11
scottyfix
My Ride: 04 BMW 325XI
Cool Pretty Simple
Go to Amzoil.com ...get the universal transmission fluid. It is fully synthetic...and it replaces all dextron synthetic types. They even have a phone number that you can call and they will make sure you get the correct fluid.
scottyfix is offline   Reply With Quote
Old 09-30-2012, 01:36 PM   #12
RCase
My Ride: 2001 325i Touring
My car exhibited the same behavior and the reprogramming TSB that was for 2003+ vehicles resolved my issue entirely. No fluid change.
2000 E46 323i Touring / JB / "BW"
2001 E46 "M3" Touring / Alpine / "WW1"
2008 E90 M3 / Jerez/ 6 Speed / FBO / "M3"
2015 F31 328d / MSport / Alpine/ "WW2"
RCase is offline   Reply With Quote
Old 09-30-2012, 03:09 PM   #13
B-Sho
Traded in My 2004 BMW 330xi for a 2012 Mazda3 skyactiv that gets 40mpg. Im tired of having a non reliable car, and bmw's parts are way to expensive. Im staying on the Japanese brands for even after my Mazda. Cheap parts, good on gas, and reliable.
Old 09-30-2012, 03:21 PM   #14
stevenluczynski
My Ride: Is Steel Blue
stevenluczynski is offline   Reply With Quote
Old 09-30-2012, 07:02 PM   #15
zwei e46
My Ride: '99 323i & '05 325xi
Could you please post which TSB this was. Went to the dealer for the 2/1 hard downshift and the SA couldn't find one for our '05 325xi.
zwei e46 is offline   Reply With Quote
Old 10-01-2012, 06:32 PM   #16
EDWAGON
My Ride: 2004 325xiT
Thank you
I have same tranny, have this in mine for about 8000 miles runs smoother and some bmwdealers are selling this at a much higher price
http://matrixsyntheticoils.com/store...on_vi_atf.html
EDWAGON is offline   Reply With Quote
Old 10-01-2012, 09:39 PM   #17
redbull 325is
My Ride: 325xit/6
Send a message via AIM to redbull 325is
i run d4
redbull 325is is offline   Reply With Quote
Old 10-08-2012, 09:45 AM   #18
yo_marc
My Ride: 05 325xi
Just changed fluid and filter this weekend - Put in close to 6 quarts of Valvoline Dexron 6.
Tranny didn't implode, explode, or go up in smoke. To the best of my knowledge, shifts just as it did before.
Personally, I didn't notice any viscosity differences between original (used) fluid (Texaco spec'd), and Dex6.
Original fluid came out looking like dirty motor oil. Perhaps not quite as black.
87,000 miles, 05 325xi.
yo_marc is offline   Reply With Quote
