Old 09-14-2012, 08:53 PM   #1
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
Who Knows About ASA SK1 Superchargers?
For those who are familiar with ASA supercharger kits, will a kit designed for a 330 work on a 328? Details can be found below. Trying to help out a fellow seller on here
Kit includes:
-ASA TM-12 blower
-FMIC (air to air)
-Extra Siemens ECU with Stage 1 tune
-Extra fuel rail with upgraded high flow injectors
-Upgraded K&N air filter with heat shield
-All hoses (with extra), pipes, bolts, belt, pulleys
| 435 HP 328Ci | RRT Racing | Designer Wraps | Active Autowerke | Vorsteiner | STATUS Racing |
Timeless Motor Group
Old 09-14-2012, 09:11 PM   #2
mcr_driver
My Ride: my favorite two feet
The tuning definitely and probably the hoses are different between the kits, I used to have a asa kit on my 330i. Probably the only things that are sure to work are the blower, CAI and FMCC. but the rails might be different between an 328i and 330i so cross check those PN#'s as well.
mcr_driver is offline   Reply With Quote
Old 09-14-2012, 09:26 PM   #3
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
Invest in a third pedal instead. You'll save weight, reduce parasitic loss, and get better gas mileage.
cowmoo32 is online now   Reply With Quote
Old 09-14-2012, 09:28 PM   #4
2000_328CI
2000_328CI's Avatar
Glad I have a manual transmissions
Old 09-14-2012, 09:35 PM   #5
kaput
My Ride: 2002 M3 SMG
Send a message via AIM to kaput
It should not work. As far as I know, the 328/325 of the early years is different enough that the 330 and 325s do not work.
2002 M3
kaput is offline   Reply With Quote
Old 09-14-2012, 09:40 PM   #6
2000_328CI
2000_328CI's Avatar
Cool kaput thanks bud
Old 09-14-2012, 09:41 PM   #7
kaput
No prob bob.
2002 M3
Old 09-15-2012, 12:45 AM   #8
BimmerBrakes
The Brake Newbie!
My Ride: 2005 ZHP BMW
Send a message via AIM to BimmerBrakes
328 and 330 is same stuff. It has a 3" TB so you be ok. If there is any difference. It will be very minor to change.
-Anthony@BimmerBrakes
BimmerBrakes is offline   Reply With Quote
Old 09-15-2012, 07:54 AM   #9
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
Really? You used to have an auto didn't you?
Old 09-28-2012, 06:37 PM   #10
Mr Paddle.Shift
Mr Paddle.Shift's Avatar
My Ride: B3 epsilon
Zolti @ Autotalent can probably confirmed the details.
Technik Engineering ASA Stage 1.
Supercharged E46 M54B25.
2011 NASA TTC So Cal Champion!
Track blog.
Technik Engineering oil cap o-ring maintenance kit available.
Mr Paddle.Shift is offline   Reply With Quote
Old 09-29-2012, 09:08 PM   #11
brodaiga
My Ride: 330ci
I have the technik kit with the smaller pulley-8psi
140mm
~8psi
6PK 2390
anyone know the belt part number
brodaiga is offline   Reply With Quote
Old 09-29-2012, 09:13 PM   #12
brodaiga
My Ride: 330ci
found it from my old thread lol, it is 6PK2375
